* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* configure.ac: Fix package name.
* src/rpc/pmap_rmt.c: Removed warnings.
* src/rpc/svc_run.c: Remove warning.
* src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c,
src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h>
to eliminate warning.
* src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate
warning.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h>
to avoid warning on ntohl().
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31
warnings about abort/exit).
* configure.ac: or32 does not currently support librpc.
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
2002-07-23 Joel Sherrill <joel@OARcorp.com>
* src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: RTEMS_TOP(../..).
2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-30 Joel Sherrill <joel@OARcorp.com>
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-22 Joel Sherrill <joel@OARcorp.com>
* src/xdr/xdr_float.c: Added A29K support.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
Add AC_PROG_RANLIB.
Add AC_PROG_RANLIB.
H_FILES.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
generated assembly from it.
