* | 2008-03-29 Chris Johns <chrisj@rtems.org> | Chris Johns | 2008-03-29 | 1 | -0/+1 |
| | | | | | | * librpc/include/rpc/clnt.h: Added the missing __BEGIN_DECLS as reported to the mailing list by Pierre Kestener (pierre.kestener@cea.fr). | ||||
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 11 | -11/+11 |
* | Include <rtems/endian.h> instead of <machine/endian.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | 2007-05-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-08 | 1 | -5/+6 |
| | | | | | | | * librpc/src/rpc/rtime.c: Use uint32_t instead of unsigned long for return value of ntohl (POSIX requirement). Use UINT32_C macros to avoid overflows on 16bit targets. Eliminate __P. | ||||
* | 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-28 | 1 | -2/+2 |
| | | | | | * librpc/src/rpc/clnt_tcp.c (clnttcp_create): Use uintptr_t for "disrupt". Remove bogus (long) cast. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | Add bfin. | Ralf Corsepius | 2006-11-09 | 1 | -1/+2 |
* | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-14 | 6 | -21/+22 |
| | | | | | | | * libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 2 | -19/+19 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 1 | -1/+3 |
| | | | | | | * libcsupport/src/utsname.c, libnetworking/libc/res_debug.c, libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c, librpc/src/rpc/svc_simple.c: Remove printf format warnings. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 1 | -0/+1 |
| | | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New port to Altera NIOS II. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 |
* | 2005-11-02 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-12-09 | 1 | -1/+1 |
| | | | | | | PR 849/networking * librpc/src/rpc/rtems_portmapper.c: Increased stack size by ARGSIZE to prevent overrun. | ||||
* | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-27 | 4 | -1/+4 |
| | | | | | | * libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings. | ||||
* | Use void* instead of caddr_t. Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-25 | 3 | -31/+49 |
* | Regenerate. | Ralf Corsepius | 2005-05-25 | 1 | -4/+0 |
* | Reflect removing auth_des.h. | Ralf Corsepius | 2005-05-25 | 2 | -7/+1 |
* | Remove (Unused, unsupported). | Ralf Corsepius | 2005-05-25 | 1 | -109/+0 |
* | Misc. fixes. | Ralf Corsepius | 2005-05-25 | 3 | -37/+31 |
* | More updates from FreeBSD. | Ralf Corsepius | 2005-05-25 | 3 | -56/+15 |
* | More updates from FreeBSD. | Ralf Corsepius | 2005-05-25 | 3 | -126/+45 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -54/+18 |
| | | | | * librpc/include/rpc/svc.h: Partial update from FreeBSD. | ||||
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -14/+17 |
| | | | | * librpc/include/rpc/clnt.h: Partial update from FreeBSD. | ||||
* | Regenerate. | Ralf Corsepius | 2005-05-25 | 1 | -16/+24 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -6/+11 |
| | | | | | | * librpc/include/rpc/clnt_soc.h, librpc/include/rpc/svc_soc.h: New (Partial update from FreeBSD). * librpc/Makefile.am: Reflect changes above. | ||||
* | New. | Ralf Corsepius | 2005-05-25 | 2 | -0/+246 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -1/+1 |
| | | | | | * librpc/include/rpc/des.h: Remove (Unused, unsupported). * librpc/Makefile.am: Reflect changes above. | ||||
* | Remove (Unused, unsupported) | Ralf Corsepius | 2005-05-25 | 1 | -120/+0 |
* | Remove (Unused, unsupported). | Ralf Corsepius | 2005-05-25 | 1 | -82/+0 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -5/+0 |
| | | | | | | | | | | | | | | | | * librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_time.c, librpc/src/rpc/authdes_prot.c, librpc/src/rpc/clnt_unix.c, librpc/src/rpc/crypt_client.c, librpc/src/rpc/des_crypt.c, librpc/src/rpc/des_soft.c, librpc/src/rpc/getpublickey.c, librpc/src/rpc/key_call.c, librpc/src/rpc/key_prot_xdr.c, librpc/src/rpc/svc_auth_des.c, librpc/src/rpc/svc_unix.c: Remove (Unused, obsolete). * librpc/Makefile.am: Reflect changes above. | ||||
* | Remove (Unused, obsolete). | Ralf Corsepius | 2005-05-25 | 12 | -3899/+0 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -3/+0 |
| | | | | | | | | | | | * librpc/src/rpc/PSD.doc/rpc.prog.ms, librpc/src/rpc/PSD.doc/rpcgen.ms, librpc/src/rpc/PSD.doc/nfs.rfc.ms, librpc/src/rpc/PSD.doc/xdr.rfc.ms, librpc/src/rpc/PSD.doc/rpc.rfc.ms, librpc/src/rpc/PSD.doc/xdr.nts.ms: Remove (Unused, obsolete). * librpc/Makefile.am: Reflect changes above. | ||||
* | Remove (unused, obsolete). | Ralf Corsepius | 2005-05-25 | 6 | -9681/+0 |
* | socklen_t. | Ralf Corsepius | 2005-05-10 | 6 | -8/+9 |
* | Cosmetical update from FreeBSD. | Ralf Corsepius | 2005-05-10 | 1 | -41/+42 |
* | socklen_t. | Ralf Corsepius | 2005-05-09 | 1 | -2/+2 |
* | 2005-05-02 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-02 | 1 | -1/+1 |
| | | | | | * libfs/src/dosfs/msdos_format.c, librpc/src/xdr/xdr.c: Added initialization to remove warnings. | ||||
* | Auto-generated update. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 2 | -83/+94 |
| | | | | | | * librpc/Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * librpc/preinstall.am: New (Generated from corresponding Makefile.am). | ||||
* | 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-03 | 4 | -28/+173 |
| | | | | | | | * librpc/include/rpc/clnt_stat.h, librpc/include/rpc/rpcent.h: New (From FreeBSD). * librpc/include/rpc/rpc.h: Partial update from FreeBSD. * librpc/Makefile.am: Reflect changes above. | ||||
* | 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-03 | 2 | -29/+42 |
| | | | | | | * librpc/include/rpc/types.h: Partial update from FreeBSD. Use stdint.h types instead of sys/types.h. * librpc/src/rpc/bindresvport.c: Partial update from FreeBSD. | ||||
* | Fix indentation. | Ralf Corsepius | 2005-01-28 | 1 | -5/+5 |
