* | 2008-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-08 | 2 | -0/+5 |
| | | | | | | * rtems/include/rtems/rtems/clock.h: #include <sys/time.h> * librpc/include/rpc/rpcent.h: #include <rpc/types.h>. * librpc/include/rpc/xdr.h: #include <rtems/bsd/sys/cdefs.h>. | ||||
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 19 | -195/+189 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-18 | 2 | -12/+16 |
* | Cleanup. | Ralf Corsepius | 2008-08-01 | 2 | -8/+8 |
* | Misc. ansifications. Add prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -36/+36 |
* | Misc. ansifications. Add prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -58/+59 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -3/+5 |
* | Remove stray local decls. Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -7/+5 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 3 | -26/+26 |
* | Remove stray clnt_perror(). | Ralf Corsepius | 2008-08-01 | 1 | -2/+0 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -7/+7 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -55/+52 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 2 | -22/+23 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -6/+6 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -3/+4 |
* | Remove register vars. | Ralf Corsepius | 2008-08-01 | 1 | -26/+26 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -36/+36 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -40/+40 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -1/+1 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -14/+14 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -4/+10 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -2/+2 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -1/+2 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -54/+55 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -6/+6 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -27/+27 |
* | More ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -23/+26 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 2 | -10/+10 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -8/+8 |
| | | | | Add missing prototypes. | ||||
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 2 | -40/+33 |
* | Fix oversight in previous patch. | Ralf Corsepius | 2008-08-01 | 1 | -1/+1 |
* | Eliminate __P(). | Ralf Corsepius | 2008-08-01 | 12 | -59/+59 |
* | 2008-03-29 Chris Johns <chrisj@rtems.org> | Chris Johns | 2008-03-29 | 1 | -0/+1 |
| | | | | | | * librpc/include/rpc/clnt.h: Added the missing __BEGIN_DECLS as reported to the mailing list by Pierre Kestener (pierre.kestener@cea.fr). | ||||
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 11 | -11/+11 |
* | Include <rtems/endian.h> instead of <machine/endian.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | 2007-05-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-08 | 1 | -5/+6 |
| | | | | | | | * librpc/src/rpc/rtime.c: Use uint32_t instead of unsigned long for return value of ntohl (POSIX requirement). Use UINT32_C macros to avoid overflows on 16bit targets. Eliminate __P. | ||||
* | 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-28 | 1 | -2/+2 |
| | | | | | * librpc/src/rpc/clnt_tcp.c (clnttcp_create): Use uintptr_t for "disrupt". Remove bogus (long) cast. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | Add bfin. | Ralf Corsepius | 2006-11-09 | 1 | -1/+2 |
* | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-14 | 6 | -21/+22 |
| | | | | | | | * libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 2 | -19/+19 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 1 | -1/+3 |
| | | | | | | * libcsupport/src/utsname.c, libnetworking/libc/res_debug.c, libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c, librpc/src/rpc/svc_simple.c: Remove printf format warnings. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 1 | -0/+1 |
| | | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New port to Altera NIOS II. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 |
