* | rpc: misaligned pointer dereference in clnt_udp.c line 363 | Jeffrey Hill | 2015-02-23 | 1 | -3/+3 |
| | | | | see #2248 | ||||
* | rpc: misaligned address exception in get_myaddress.c | Jeffrey Hill | 2015-02-23 | 1 | -15/+38 |
| | | | | updates #2249 see #1401 | ||||
* | Add .git ignore. Remove .cvsignore | Joel Sherrill | 2012-02-02 | 1 | -2/+0 |
* | 2011-11-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-11-30 | 1 | -3/+11 |
| | | | | | * librpc/src/rpc/clnt_udp.c (struct cu_data): Introduce unions _cu_inbuf, _cu_outbuf to avoid aliasing. | ||||
* | 2010-05-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-29 | 1 | -2/+2 |
| | | | | | * librpc/src/xdr/xdr_mem.c (xdr_memcreate): Cast addr to uintptr_t instead of size_t. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 2 | -6/+6 |
| | | | | | | * librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c: Revert to using u_long instead of rpcprog_t, rpcvers_t to stay bug-ward compatible to freebsd. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 1 | -4/+4 |
| | | | | * librpc/src/xdr/xdr_mem.c: Cosmetics from freebsd. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 1 | -3/+7 |
| | | | | * librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc. | ||||
* | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-27 | 9 | -72/+70 |
| | | | | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h, librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c librpc/src/rpc/pmap_getport.c: Partial merger from freebsd (portability fixes). | ||||
| | | | | * librpc/include/rpc/xdr.h: Cosmetics from freebsd. | ||||
* | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-26 | 1 | -22/+22 |
| | | | | * librpc/src/rpc/clnt_udp.c: Cosmetics from freebsd. | ||||
* | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-26 | 1 | -36/+54 |
| | | | | | * librpc/src/rpc/clnt_tcp.c: Partial merger from freebsd (Fix strict-aliasing). | ||||
* | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-26 | 1 | -10/+13 |
| | | | | | * librpc/src/rpc/clnt_raw.c: Partial merger from freebsd (Improved 16 bit compatibility; Fix strict-aliasing). | ||||
* | 2010-05-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-25 | 1 | -10/+21 |
| | | | | | * librpc/src/rpc/rpc_prot.c: Partial merger from freebsd (Improved 64 bit compatibility; bug fix). | ||||
* | 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-29 | 2 | -5/+5 |
| | | | | | * librpc/src/rpc/clnt_udp.c, librpc/src/xdr/xdr_mem.c: Use [u]intptr_t instead of [u_]long for better 16bit compliance. | ||||
* | 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-29 | 1 | -2/+2 |
| | | | | | * librpc/src/rpc/pmap_rmt.c: Use uintptr_t for better 16bit compliance. | ||||
* | Add HAVE_STRINGS_H for better POSIX compliance. | Ralf Corsepius | 2010-03-28 | 1 | -0/+3 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 45 | -0/+183 |
* | 2009-05-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-20 | 1 | -1/+1 |
| | | | | * librpc/src/xdr/xdr_float.c: Change detection logic for h8300. | ||||
* | 2009-01-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-01-08 | 1 | -3/+1 |
| | | | | | * librpc/src/xdr/xdr_float.c: M32C has no native float but GCC soft float should be IEEE format. | ||||
* | Add missing initializers. | Ralf Corsepius | 2008-12-23 | 1 | -0/+34 |
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 1 | -1/+1 |
* | #include <rpc/types.h>. | Ralf Corsepius | 2008-12-08 | 1 | -0/+2 |
* | #include <rtems/bsd/sys/cdefs.h>. | Ralf Corsepius | 2008-12-08 | 1 | -0/+3 |
* | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2008-12-04 | 1 | -0/+1 |
| | | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add Lattice Mico32 support. | ||||
* | 2008-11-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-05 | 1 | -1/+5 |
| | | | | * librpc/src/xdr/xdr_float.c: Add M32C, M32R, and Blackfin. | ||||
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 19 | -195/+189 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-18 | 2 | -12/+16 |
* | Cleanup. | Ralf Corsepius | 2008-08-01 | 2 | -8/+8 |
* | Misc. ansifications. Add prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -36/+36 |
* | Misc. ansifications. Add prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -58/+59 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -3/+5 |
* | Remove stray local decls. Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -7/+5 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 3 | -26/+26 |
* | Remove stray clnt_perror(). | Ralf Corsepius | 2008-08-01 | 1 | -2/+0 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -7/+7 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 3 | -55/+52 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 2 | -22/+23 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -6/+6 |
* | Add missing prototypes. | Ralf Corsepius | 2008-08-01 | 1 | -3/+4 |
* | Remove register vars. | Ralf Corsepius | 2008-08-01 | 1 | -26/+26 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -36/+36 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -40/+40 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -1/+1 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -14/+14 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -4/+10 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -2/+2 |
* | Cosmetics. | Ralf Corsepius | 2008-08-01 | 1 | -1/+2 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -54/+55 |
