path: root/cpukit/librpc/src (follow)
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-273-89/+0
| | | | | | | | * src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am: Removed. * Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am. Various fixes. Reformat.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-279-16/+16
| | | | | | | | | | | | * include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct rtems_rpc_task_variables into struct _rtems_rpc_task_variables (Avoid symbol conflict between struct and variable). struct _rtems_rpc_task_variables *rtems_rpc_task_variables; Reflect changes above. * src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c, src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c, src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c: Reflect changes above.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-212-3/+1
| | | | | | | * src/rpc/Makefile.am: Remove __P from AM_CPPFLAGS. Rely on sys/cdefs.h providing it. * src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS. Rely on sys/cdefs.h providing it.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-083-13/+12
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am, include/Makefile.am, src/Makefile.am, src/rpc/Makefile.am, src/xdr/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2002-11-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-041-1/+1
| | | | * src/rpc/pmap_rmt.c: Removed warnings.
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-311-0/+1
| | | | * src/rpc/svc_run.c: Remove warning.
* 2002-10-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-286-0/+7
| | | | | | | | * src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h> to eliminate warning. * src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate warning.
* 2002-08-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-201-0/+1
| | | | | * src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h> to avoid warning on ntohl().
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-0/+1
| | | | | * src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31 warnings about abort/exit).
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-302-10/+3
| | | | | | | | | | | | | * src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am. * include/Makefile.am: Merge include/rpc/Makefile.am. Merge include/rpcsvc/Makefile.am. * include/rpc/Makefile.am: Remove. * include/rpcsvc/Makefile.am: Remove. * src/rpc/PSD.doc/Makefile.am: Remove. * configure.ac: Remove duplicate AC_PROG_RANLIB. Remove include/rpc/Makefile. Remove include/rpcsvc/Makefile. Remove src/rpc/PSD.doc/Makefile.
* 2002-07-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-231-1/+1
| | | | * src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-2/+2
| | | | | * src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o. * src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-3/+1
| | | | | * src/xdr/Makefile.am: Eliminate LIBNAME. * src/rpc/Makefile.am: Eliminate LIBNAME.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-2/+1
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-254-30/+15
| | | | | | | | | | | | | | | | | * configure.ac: RTEMS_TOP(../../../..). AC_CONFIG_AUX_DIR(../../../..). Remove RTEMS_CANONICAL_HOST. Use RTEMS_ENV_RTEMSCPU. Add AC_PROG_RANLIB. * include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. ACLOCAL_AMFLAGS = -I ../aclocal. * src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-284-4/+0
| | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3115-36/+36
| | | | | | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c, src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c, src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c, src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+1
| | | | * src/xdr/xdr_float.c: Added A29K support.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+2
| | | | * src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
* Minor problems addressed with the merger and with the arm_bare_bsp.Joel Sherrill2000-07-271-1/+1
| | | | | | That BSP now has a stub clock driver so the tests can link even if they won't execute. A handful of Makefiles had to be updated and we had to account for printk.c being a shared file now.
* Added H8 as IEEE whether this is true or not.Joel Sherrill2000-06-291-0/+1
* Disabled #ident since the h8300-rtems binutils do not like theJoel Sherrill2000-06-291-1/+1
| | | | generated assembly from it.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1283-28/+28087
* Added on 4.5 branch.Joel Sherrill2000-05-032-0/+0
* Added on 4.5-branchJoel Sherrill2000-05-012-0/+0
* New files.Joel Sherrill2000-04-292-0/+4
* New files added as part of librpc upgrade.Joel Sherrill2000-04-2978-0/+0
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-1/+0
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Missed in previous automake conversion patches from Ralf CorsepiusJoel Sherrill1999-11-231-0/+36
