* librpc/src/rpc/rtime.c: Use uint32_t instead of unsigned long for
return value of ntohl (POSIX requirement).
Use UINT32_C macros to avoid overflows on 16bit targets.
Eliminate __P.
* librpc/src/rpc/clnt_tcp.c (clnttcp_create):
Use uintptr_t for "disrupt". Remove bogus (long) cast.
* libnetworking/net/route.c, librpc/src/rpc/auth_none.c,
librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c,
librpc/src/rpc/rtems_portmapper.c: Removed warnings.
* libcsupport/src/utsname.c, libnetworking/libc/res_debug.c,
libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c,
librpc/src/rpc/svc_simple.c: Remove printf format warnings.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
port to Altera NIOS II.
PR 849/networking
* librpc/src/rpc/rtems_portmapper.c: Increased stack size
by ARGSIZE to prevent overrun.
* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h,
librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c,
librpc/src/rpc/pmap_getport.c: Remove warnings.
* libfs/src/dosfs/msdos_format.c, librpc/src/xdr/xdr.c: Added
initialization to remove warnings.
* librpc/include/rpc/types.h: Partial update from FreeBSD.
Use stdint.h types instead of sys/types.h.
* librpc/src/rpc/bindresvport.c: Partial update from FreeBSD.
* librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c,
librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c,
librpc/src/rpc/svc_simple.c: Fix warnings.
* librpc/include/rpc/auth_des.h, librpc/include/rpc/xdr.h,
librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_unix.c,
librpc/src/rpc/rpc_prot.c, librpc/src/xdr/xdr.c:
Misc. ansi-fications, misc. updates from FreeBSD.
* librpc/include/rpc/xdr.h: Remove questionable comments.
* librpc/include/rpc/auth.h: Remove __P, ansi-fy.
* librpc/src/rpc/auth_none.c: Reflect changes above.
* librpc/include/rpc/types.h: Include <rtems/stdint.h>.
* librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c,
librpc/src/rpc/svc_simple.c: Misc. cast-related fixes.
Convert to ANSI.
* librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables):
Use pointers to types instead of void* to avoid casts.
* librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c,
Eliminate lvalue casts gcc-3.4 warns about.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* librpc/src/xdr/xdr_float.c: Add __AVR__.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am:
Removed.
* Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am,
src/Makefile.am.
Various fixes. Reformat.
* include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct
rtems_rpc_task_variables into struct _rtems_rpc_task_variables
(Avoid symbol conflict between struct and variable).
struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
* src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c,
src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c,
src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c:
* src/rpc/Makefile.am: Remove __P from AM_CPPFLAGS.
Rely on sys/cdefs.h providing it.
* src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* src/rpc/pmap_rmt.c: Removed warnings.
* src/rpc/svc_run.c: Remove warning.
* src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c,
src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h>
to eliminate warning.
* src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate
warning.
* src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h>
to avoid warning on ntohl().
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31
warnings about abort/exit).
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
* src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
* src/xdr/xdr_float.c: Added A29K support.
