* src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am:
Removed.
* Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am,
src/Makefile.am.
Various fixes. Reformat.
* include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct
rtems_rpc_task_variables into struct _rtems_rpc_task_variables
(Avoid symbol conflict between struct and variable).
struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
Reflect changes above.
* src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c,
src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c,
src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c:
* src/rpc/Makefile.am: Remove __P from AM_CPPFLAGS.
Rely on sys/cdefs.h providing it.
* src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* src/rpc/pmap_rmt.c: Removed warnings.
* src/rpc/svc_run.c: Remove warning.
* src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c,
src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h>
to eliminate warning.
* src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate
warning.
* src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h>
to avoid warning on ntohl().
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31
warnings about abort/exit).
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
* src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
* src/xdr/xdr_float.c: Added A29K support.
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
generated assembly from it.
converted to automake.
<corsepiu@faw.uni-ulm.de>.
