2021-04-07 | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 52 | -11416/+0 | |
Update #3850 | |||||
2018-10-04 | rpc: Use configuration header file | Sebastian Huber | 38 | -0/+114 | |
Update #3375. | |||||
2018-10-02 | Use rtems_task_exit() | Sebastian Huber | 1 | -7/+7 | |
Update #3530. Update #3533. | |||||
2017-08-25 | Include missing <string.h> | Sebastian Huber | 1 | -0/+1 | |
Update #2133. | |||||
2017-06-07 | rpc: Remove superfluous includes | Sebastian Huber | 2 | -2/+0 | |
Update #2833. | |||||
2016-01-18 | Chase Newlib sys/types.h / sys/select.h changes | Nick Withers | 5 | -1/+5 | |
2015-02-23 | rpc: misaligned pointer dereference in clnt_udp.c line 363 | Jeffrey Hill | 1 | -3/+3 | |
closes #2248 | |||||
2015-02-23 | rpc: misaligned address exception in get_myaddress.c | Jeffrey Hill | 1 | -15/+38 | |
closes #2249 see #1401 | |||||
2014-11-21 | Delete or rename MIN/MAX macros and defines | Sebastian Huber | 1 | -1/+1 | |
Include <sys/param.h> if necessary to get the MIN()/MAX() macros. | |||||
2014-03-24 | librpc: Use POSIX key instead of task variables | Christian Mauderer | 1 | -15/+45 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-11-30 | 2011-11-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -3/+11 | |
* librpc/src/rpc/clnt_udp.c (struct cu_data): Introduce unions _cu_inbuf, _cu_outbuf to avoid aliasing. | |||||
2010-05-27 | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -6/+6 | |
* librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c: Revert to using u_long instead of rpcprog_t, rpcvers_t to stay bug-ward compatible to freebsd. | |||||
2010-05-27 | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -3/+7 | |
* librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc. | |||||
2010-05-27 | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 7 | -43/+47 | |
* librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h, librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c librpc/src/rpc/pmap_getport.c: Partial merger from freebsd (portability fixes). | |||||
2010-05-26 | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -22/+22 | |
* librpc/src/rpc/clnt_udp.c: Cosmetics from freebsd. | |||||
2010-05-26 | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -36/+54 | |
* librpc/src/rpc/clnt_tcp.c: Partial merger from freebsd (Fix strict-aliasing). | |||||
2010-05-26 | 2010-05-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -10/+13 | |
* librpc/src/rpc/clnt_raw.c: Partial merger from freebsd (Improved 16 bit compatibility; Fix strict-aliasing). | |||||
2010-05-25 | 2010-05-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -10/+21 | |
* librpc/src/rpc/rpc_prot.c: Partial merger from freebsd (Improved 64 bit compatibility; bug fix). | |||||
2010-04-29 | 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* librpc/src/rpc/clnt_udp.c, librpc/src/xdr/xdr_mem.c: Use [u]intptr_t instead of [u_]long for better 16bit compliance. | |||||
* librpc/src/rpc/pmap_rmt.c: Use uintptr_t for better 16bit compliance. | |||||
2010-03-28 | Add HAVE_STRINGS_H for better POSIX compliance. | Ralf Corsepius | 1 | -0/+3 | |
2010-03-28 | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 37 | -0/+151 | |
2008-12-23 | Add missing initializers. | Ralf Corsepius | 1 | -0/+34 | |
2008-09-01 | Stop using old-style function definitions. | Ralf Corsepius | 15 | -87/+83 | |
2008-08-18 | Add missing prototypes. | Ralf Corsepius | 2 | -12/+16 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 1 | -3/+5 | |
2008-08-01 | Remove stray local decls. Misc. ansifications. | Ralf Corsepius | 1 | -7/+5 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 3 | -26/+26 | |
2008-08-01 | Remove stray clnt_perror(). | Ralf Corsepius | 1 | -2/+0 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 1 | -7/+7 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 3 | -55/+52 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 2 | -22/+23 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 1 | -6/+6 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 1 | -3/+4 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 1 | -40/+40 | |
2008-08-01 | Cosmetics. | Ralf Corsepius | 1 | -1/+1 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 1 | -36/+36 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 1 | -14/+14 | |
2008-08-01 | Cosmetics. | Ralf Corsepius | 1 | -4/+10 | |
2008-08-01 | Cosmetics. | Ralf Corsepius | 1 | -2/+2 | |
2008-08-01 | Cosmetics. | Ralf Corsepius | 1 | -1/+2 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 3 | -6/+6 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 1 | -27/+27 | |
2008-08-01 | More ansifications. | Ralf Corsepius | 1 | -23/+26 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 2 | -10/+10 | |
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 1 | -8/+8 | |
Add missing prototypes. | |||||
2008-08-01 | Misc. ansifications. | Ralf Corsepius | 2 | -40/+33 | |
2008-08-01 | Eliminate __P(). | Ralf Corsepius | 2 | -4/+4 | |
2007-05-08 | 2007-05-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -5/+6 | |
* librpc/src/rpc/rtime.c: Use uint32_t instead of unsigned long for return value of ntohl (POSIX requirement). Use UINT32_C macros to avoid overflows on 16bit targets. Eliminate __P. |
