2021-04-07 | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 1 | -502/+0 | |
Update #3850 | |||||
2018-10-04 | rpc: Use configuration header file | Sebastian Huber | 1 | -0/+2 | |
Update #3375. | |||||
2018-10-02 | Use rtems_task_exit() | Sebastian Huber | 1 | -7/+7 | |
Update #3530. Update #3533. | |||||
2010-05-27 | 2010-05-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -3/+7 | |
* librpc/src/rpc/rtems_portmapper.c: Reflect changes to librpc. | |||||
2010-03-28 | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 1 | -0/+4 | |
2008-08-01 | Add missing prototypes. | Ralf Corsepius | 1 | -2/+2 | |
2006-09-14 | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+2 | |
* libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. | |||||
2005-12-09 | 2005-11-02 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -1/+1 | |
PR 849/networking * librpc/src/rpc/rtems_portmapper.c: Increased stack size by ARGSIZE to prevent overrun. | |||||
2005-01-28 | Fix indentation. | Ralf Corsepius | 1 | -5/+5 | |
2005-01-09 | 2005-01-09 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 1 | -11/+12 | |
* librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc_simple.c: Fix warnings. | |||||
2004-11-21 | 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -27/+28 | |
* librpc/include/rpc/types.h: Include <rtems/stdint.h>. * librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c, librpc/src/rpc/svc_simple.c: Misc. cast-related fixes. Convert to ANSI. | |||||
2002-08-11 | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+1 | |
* src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31 warnings about abort/exit). | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -0/+488 | |
2000-05-03 | Added on 4.5 branch. | Joel Sherrill | 1 | -0/+0 | |
2000-04-28 | New files added on 4.5 branch. | Joel Sherrill | 1 | -0/+0 | |
1999-11-17 | New shell of a test for ITRON Mailbox Manager. | Joel Sherrill | 1 | -0/+0 | |
1999-11-10 | Combination of committing some new files which had been overlooked | Joel Sherrill | 1 | -0/+0 | |
and adding code which installed screens for itron tests. |
