* | More ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -23/+26 |
* | Misc. ansifications. | Ralf Corsepius | 2008-08-01 | 1 | -5/+5 |
* | Use void* instead of caddr_t. Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-25 | 1 | -25/+43 |
* | socklen_t. | Ralf Corsepius | 2005-05-10 | 1 | -1/+2 |
* | 2005-01-09 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2005-01-09 | 1 | -3/+3 |
| | | | | | | | * librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc_simple.c: Fix warnings. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 1 | -1/+1 |
| | | | | * src/rpc/pmap_rmt.c: Removed warnings. | ||||
* | 2002-10-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-28 | 1 | -0/+1 |
| | | | | | | | | * src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c: Add include of <sys/select.h> to eliminate warning. * src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate warning. | ||||
* | 2000-10-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-31 | 1 | -2/+2 |
| | | | | | | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c, src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c, src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c, src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -0/+415 |
* | New files added as part of librpc upgrade. | Joel Sherrill | 2000-04-29 | 1 | -0/+0 |
