2021-04-07 | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 1 | -73/+0 | |
Update #3850 | |||||
2018-10-04 | rpc: Use configuration header file | Sebastian Huber | 1 | -0/+2 | |
Update #3375. | |||||
2010-03-28 | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 1 | -0/+4 | |
2008-09-01 | Stop using old-style function definitions. | Ralf Corsepius | 1 | -3/+3 | |
2006-09-14 | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. | |||||
2005-01-09 | 2005-01-09 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc_simple.c: Fix warnings. | |||||
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 1 | -1/+0 | |
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -0/+68 | |
2000-04-29 | New files added as part of librpc upgrade. | Joel Sherrill | 1 | -0/+0 | |
2000-04-28 | New files added on 4.5 branch. | Joel Sherrill | 1 | -0/+0 | |
1999-11-17 | New shell of a test for ITRON Mailbox Manager. | Joel Sherrill | 1 | -0/+0 | |
1999-11-10 | Combination of committing some new files which had been overlooked | Joel Sherrill | 1 | -0/+0 | |
and adding code which installed screens for itron tests. |
