path: root/cpukit/librpc/include (follow)
* #include <stdint.h> instead of <rtems/stdint.h>.Ralf Corsepius2008-12-111-1/+1
* #include <rpc/types.h>.Ralf Corsepius2008-12-081-0/+2
* #include <rtems/bsd/sys/cdefs.h>.Ralf Corsepius2008-12-081-0/+3
* Cleanup.Ralf Corsepius2008-08-012-8/+8
* Fix oversight in previous patch.Ralf Corsepius2008-08-011-1/+1
* Eliminate __P().Ralf Corsepius2008-08-019-53/+53
* 2008-03-29 Chris Johns <chrisj@rtems.org>Chris Johns2008-03-291-0/+1
| | | | | | * librpc/include/rpc/clnt.h: Added the missing __BEGIN_DECLS as reported to the mailing list by Pierre Kestener (pierre.kestener@cea.fr).
* Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>.Ralf Corsepius2007-05-101-1/+1
* Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>.Ralf Corsepius2007-05-1011-11/+11
* 2005-05-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-05-271-1/+1
| | | | | | * libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings.
* Use void* instead of caddr_t. Cosmetics from FreeBSD.Ralf Corsepius2005-05-252-6/+6
* Reflect removing auth_des.h.Ralf Corsepius2005-05-251-5/+0
* Remove (Unused, unsupported).Ralf Corsepius2005-05-251-109/+0
* Misc. fixes.Ralf Corsepius2005-05-252-34/+27
* More updates from FreeBSD.Ralf Corsepius2005-05-252-53/+12
* More updates from FreeBSD.Ralf Corsepius2005-05-252-122/+41
* 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-05-251-54/+18
| | | | * librpc/include/rpc/svc.h: Partial update from FreeBSD.
* 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-05-251-14/+17
| | | | * librpc/include/rpc/clnt.h: Partial update from FreeBSD.
* New.Ralf Corsepius2005-05-252-0/+246
* Remove (Unused, unsupported)Ralf Corsepius2005-05-251-120/+0
* Remove (Unused, unsupported).Ralf Corsepius2005-05-251-82/+0
* Cosmetical update from FreeBSD.Ralf Corsepius2005-05-101-41/+42
* 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-033-23/+159
| | | | | | | * librpc/include/rpc/clnt_stat.h, librpc/include/rpc/rpcent.h: New (From FreeBSD). * librpc/include/rpc/rpc.h: Partial update from FreeBSD. * librpc/Makefile.am: Reflect changes above.
* 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-031-9/+13
| | | | | | * librpc/include/rpc/types.h: Partial update from FreeBSD. Use stdint.h types instead of sys/types.h. * librpc/src/rpc/bindresvport.c: Partial update from FreeBSD.
* 2005-01-09 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2005-01-091-6/+6
| | | | | | | * librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc_simple.c: Fix warnings.
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-082-52/+54
| | | | | | | * librpc/include/rpc/auth_des.h, librpc/include/rpc/xdr.h, librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/rpc_prot.c, librpc/src/xdr/xdr.c: Misc. ansi-fications, misc. updates from FreeBSD.
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-072-39/+32
| | | | | | | * librpc/include/rpc/xdr.h: Remove questionable comments. * librpc/include/rpc/auth.h: Remove __P, ansi-fy. * librpc/src/rpc/auth_none.c: Reflect changes above. Partial update from FreeBSD.
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-072-82/+82
| | | | | * librpc/include/rpc/svc.h, librpc/include/rpc/xdr.h: Remove __P(xx).
* 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-11-211-0/+2
| | | | | | | | * librpc/include/rpc/types.h: Include <rtems/stdint.h>. * librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c, librpc/src/rpc/svc_simple.c: Misc. cast-related fixes. Convert to ANSI.
* 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-11-211-13/+13
| | | | | | | | | | * librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables): Use pointers to types instead of void* to avoid casts. * librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c, librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c, librpc/src/rpc/svc_simple.c: Eliminate lvalue casts gcc-3.4 warns about.
* 2004-10-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-291-1/+1
| | | | | | * score/src/coremsg.c: Eliminate unsigned32. * score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99. * librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype.
* No kernel/user distinction.Eric Norum2004-10-251-1/+1
* Remove stray white spaces.Ralf Corsepius2004-04-155-6/+0
* Remove stray white spaces.Ralf Corsepius2004-04-151-1/+0
* Unused.Ralf Corsepius2004-03-083-6/+0
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-271-6/+6
| | | | | | | | | | | | * include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct rtems_rpc_task_variables into struct _rtems_rpc_task_variables (Avoid symbol conflict between struct and variable). struct _rtems_rpc_task_variables *rtems_rpc_task_variables; Reflect changes above. * src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c, src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c, src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c: Reflect changes above.
* 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-241-30/+0
| | | | | * Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am: Remove.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-1/+1
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am, include/Makefile.am, src/Makefile.am, src/rpc/Makefile.am, src/xdr/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-303-41/+23
| | | | | | | | | | | | | * src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am. * include/Makefile.am: Merge include/rpc/Makefile.am. Merge include/rpcsvc/Makefile.am. * include/rpc/Makefile.am: Remove. * include/rpcsvc/Makefile.am: Remove. * src/rpc/PSD.doc/Makefile.am: Remove. * configure.ac: Remove duplicate AC_PROG_RANLIB. Remove include/rpc/Makefile. Remove include/rpcsvc/Makefile. Remove src/rpc/PSD.doc/Makefile.
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-253-4/+4
| | | | | | | | | | | | | | | | | * configure.ac: RTEMS_TOP(../../../..). AC_CONFIG_AUX_DIR(../../../..). Remove RTEMS_CANONICAL_HOST. Use RTEMS_ENV_RTEMSCPU. Add AC_PROG_RANLIB. * include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. ACLOCAL_AMFLAGS = -I ../aclocal. * src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+0
| | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-1/+1
| | | | * include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-2/+5
| | | | | * include/rpc/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* Corrected prototype for xdrrec_endofrecord to match C body.Joel Sherrill2000-06-291-1/+1
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1248-310/+7502
* Added on 4.5-branchJoel Sherrill2000-05-012-0/+0
* New files added as part of librpc upgrade.Joel Sherrill2000-04-2913-0/+0
* New directory added as part of librpc upgrade.Joel Sherrill2000-04-2923-0/+0
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-132-0/+4
| | | | adds .cvsignore.
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-2/+2
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
