The XDR library has a problem on architectures with short enums like the
default ARM EABI. Short enums means that the size of the enum type is
variable and the smallest integer type to hold all enum values will be
selected. For many enums this is char. The XDR library uses int32_t
for enum_t. There are several evil casts from an enum type to enum_t
which leads to invalid memory accesses on short enum architectures. A
workaround is to add appropriate dummy enum values.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* librpc/include/rpc/clnt.h, librpc/include/rpc/rpc_msg.h,
librpc/src/rpc/clnt_generic.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c,
librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c
librpc/src/rpc/pmap_getport.c:
Partial merger from freebsd (portability fixes).
* librpc/include/rpc/xdr.h: Cosmetics from freebsd.
* librpc/include/rpc/clnt.h: Added the missing __BEGIN_DECLS as
reported to the mailing list by Pierre Kestener
(pierre.kestener@cea.fr).
* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h,
librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c,
librpc/src/rpc/pmap_getport.c: Remove warnings.
* librpc/include/rpc/svc.h: Partial update from FreeBSD.
* librpc/include/rpc/clnt.h: Partial update from FreeBSD.
* librpc/include/rpc/clnt_stat.h, librpc/include/rpc/rpcent.h:
New (From FreeBSD).
* librpc/include/rpc/rpc.h: Partial update from FreeBSD.
* librpc/Makefile.am: Reflect changes above.
* librpc/include/rpc/types.h: Partial update from FreeBSD.
Use stdint.h types instead of sys/types.h.
* librpc/src/rpc/bindresvport.c: Partial update from FreeBSD.
* librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c,
librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c,
librpc/src/rpc/svc_simple.c: Fix warnings.
* librpc/include/rpc/auth_des.h, librpc/include/rpc/xdr.h,
librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_unix.c,
librpc/src/rpc/rpc_prot.c, librpc/src/xdr/xdr.c:
Misc. ansi-fications, misc. updates from FreeBSD.
* librpc/include/rpc/xdr.h: Remove questionable comments.
* librpc/include/rpc/auth.h: Remove __P, ansi-fy.
* librpc/src/rpc/auth_none.c: Reflect changes above.
* librpc/include/rpc/svc.h, librpc/include/rpc/xdr.h:
Remove __P(xx).
* librpc/include/rpc/types.h: Include <rtems/stdint.h>.
* librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c,
librpc/src/rpc/svc_simple.c: Misc. cast-related fixes.
Convert to ANSI.
* librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables):
Use pointers to types instead of void* to avoid casts.
* librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c,
librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c,
librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c,
Eliminate lvalue casts gcc-3.4 warns about.
* score/src/coremsg.c: Eliminate unsigned32.
* score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99.
* librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype.
* include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct
rtems_rpc_task_variables into struct _rtems_rpc_task_variables
(Avoid symbol conflict between struct and variable).
struct _rtems_rpc_task_variables *rtems_rpc_task_variables;
* src/rpc/clnt_perror.c, src/rpc/clnt_raw.c, src/rpc/clnt_simple.c,
src/rpc/rpcdname.c, src/rpc/rtems_rpc.c, src/rpc/svc.c,
src/rpc/svc_auth.c, src/rpc/svc_raw.c, src/rpc/svc_simple.c:
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
