2012-12-28 | Header File Doxygen Enhancement Task #2 | Mathew Kallada | 1 | -2/+5 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-04-23 | PR1908: consolidate libqos code and fix installed header location | Gedare Bloom | 4 | -255/+188 | |
2012-04-16 | libqos: generate preinstall.am | Gedare Bloom | 1 | -0/+28 | |
2012-04-15 | PR1908: QoS library for CBS scheduler | Petr Benes | 3 | -0/+307 | |
Add the lipqos and sptest. |
