2022-03-22 | cpukit/libpci: Change license to BSD-2 | Joel Sherrill | 22 | -66/+484 | |
Updates #3053. | |||||
2021-05-26 | cpukit/libpci: fix potential buffer overflow in pci_cfg_print_code.c | Harrison Edward Gerber | 1 | -2/+2 | |
See also CID 1399721 Closes #4442 | |||||
2021-03-05 | pci_cfg_read.c: Fix Missing break in switch (CID #1399723) | Ryan Long | 1 | -0/+1 | |
CID 1399723: Missing break in switch in pci_read_addressable(). Closes #4279 | |||||
2019-01-07 | Fix format warnings | Sebastian Huber | 3 | -18/+24 | |
2018-10-10 | build: Merge libpci/Makefile.am | Sebastian Huber | 1 | -35/+0 | |
2018-04-04 | build: Remove EXTRA_DIST | Sebastian Huber | 1 | -1/+0 | |
A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am. | |||||
2018-01-25 | Remove make preinstall | Chris Johns | 14 | -2895/+0 | |
A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254. | |||||
2018-01-02 | sparc: Remove BSP specifics from <pci/irq.h> | Sebastian Huber | 1 | -6/+16 | |
Update #3254. Update #3260. Update #3269. | |||||
2018-01-02 | sparc: Remove BSP specifics from <pci/access.h> | Sebastian Huber | 1 | -93/+0 | |
Update #3254. Update #3260. | |||||
2017-09-29 | libpci: fix pci device allocation | Daniel Hellstrom | 5 | -37/+32 | |
The refactoring of pci_dev_create() was incorrect since the code relied on different defines before including pci/cfg.h. This reverts back to the original code having two pci_dev_create() one in auto and one in read library. confdefs.h selectes between the two libraries so both there is no link conflict. Updates #3029 | |||||
2017-08-25 | libpci: Use calloc() | Sebastian Huber | 1 | -2/+1 | |
Update #2133. | |||||
2017-08-25 | Include missing <string.h> | Sebastian Huber | 1 | -0/+1 | |
2017-05-02 | leon, GR-CPCI-GR740: Added peripheral PCI driver | Javier Jalle | 2 | -0/+2 | |
2017-03-06 | libpci: code cleanup | Daniel Hellstrom | 1 | -3/+1 | |
2015-04-17 | DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY | Daniel Hellstrom | 1 | -1/+1 | |
2015-04-17 | DRVMGR: renamed info_dev to get_info_dev | Daniel Hellstrom | 1 | -1/+1 | |
2015-04-17 | DRVMGR: change name of freq_get to get_freq | Daniel Hellstrom | 1 | -3/+3 | |
2015-04-17 | LIBPCI: updated license to rtems.org | Daniel Hellstrom | 32 | -32/+32 | |
2015-04-17 | LIBPCI: new implementation private header file | Daniel Hellstrom | 7 | -45/+56 | |
- new implementation private header file - moved double implementation of pci_dev_create used by read & auto cfg libraries to common pci_dev_create.c - moved declaration of pci_bus_cnt to private header file so avoid extern in .c files | |||||
2015-04-17 | LIBPCI: various comment/unsed clean-ups | Daniel Hellstrom | 1 | -14/+9 | |
2015-04-17 | LIBPCI: use enum with pci_system_type | Daniel Hellstrom | 2 | -3/+3 | |
2015-04-17 | LIBPCI: use RTEMS_INLINE_ROUTINE | Daniel Hellstrom | 2 | -35/+40 | |
2015-04-17 | LIBPCI: moved comment out of license header | Daniel Hellstrom | 1 | -4/+9 | |
2015-04-17 | PCI BUS: moved comment out of license header | Daniel Hellstrom | 2 | -24/+22 | |
2015-04-17 | LIBPCI: added license and auto-gen comment to pci/ids.h | Daniel Hellstrom | 1 | -1/+26 | |
To be Merged. | |||||
2015-04-17 | LIBPCI: clean-up pci_for_each_child() search arg | Daniel Hellstrom | 1 | -1/+4 | |
2015-04-17 | LIBPCI: remove $Id in makefile.am | Daniel Hellstrom | 1 | -4/+0 | |
2015-04-17 | LIBPCI: converted to BSD header | Daniel Hellstrom | 14 | -1158/+1833 | |
2015-04-17 | DRVMGR: PCI BUS converted to BSD header | Daniel Hellstrom | 1 | -8/+8 | |
2015-04-17 | LIBPCI: moved pci_bus copyright into a single line | Daniel Hellstrom | 2 | -4/+2 | |
2015-04-17 | LIBPCI: moved copyright into a single line | Daniel Hellstrom | 27 | -54/+27 | |
2015-04-17 | LIBPCI: removed unused changes file | Daniel Hellstrom | 1 | -46/+0 | |
2015-04-17 | LIBPCI: fixed RES2DEV in pci/cfg.h | Daniel Hellstrom | 1 | -2/+5 | |
2015-04-17 | NGMP PCI: added support for NGMP prototype boards | Daniel Hellstrom | 1 | -0/+1 | |
2015-04-17 | GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device | Daniel Hellstrom | 2 | -0/+2 | |
Interrupts have not been test yet | |||||
2015-04-17 | LIBPCI: added DRVMGR model for PCI bus | Daniel Hellstrom | 4 | -0/+740 | |
2015-04-17 | LIBPCI: added PCI layer to cpukit/libpci | Daniel Hellstrom | 34 | -0/+4786 | |
