line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3260.
Update #3269.
Update #3254.
Update #3260.
The refactoring of pci_dev_create() was incorrect since the code relied on
different defines before including pci/cfg.h. This reverts back to the
original code having two pci_dev_create() one in auto and one in read library.
confdefs.h selectes between the two libraries so both there is no link
conflict.
Updates #3029
Update #2133.
Update #2133.
- new implementation private header file
- moved double implementation of pci_dev_create used by read & auto cfg
libraries to common pci_dev_create.c
- moved declaration of pci_bus_cnt to private header file so avoid extern
in .c files
To be Merged.
Interrupts have not been test yet
