* | leon, GR-CPCI-GR740: Added peripheral PCI driver | Javier Jalle | 2017-05-02 | 2 | -0/+2 |
* | libpci: code cleanup | Daniel Hellstrom | 2017-03-06 | 1 | -3/+1 |
* | DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | DRVMGR: renamed info_dev to get_info_dev | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | DRVMGR: change name of freq_get to get_freq | Daniel Hellstrom | 2015-04-17 | 1 | -3/+3 |
* | LIBPCI: updated license to rtems.org | Daniel Hellstrom | 2015-04-17 | 32 | -32/+32 |
* | LIBPCI: new implementation private header file | Daniel Hellstrom | 2015-04-17 | 7 | -45/+56 |
| | | | | | | | | - new implementation private header file - moved double implementation of pci_dev_create used by read & auto cfg libraries to common pci_dev_create.c - moved declaration of pci_bus_cnt to private header file so avoid extern in .c files | ||||
* | LIBPCI: various comment/unsed clean-ups | Daniel Hellstrom | 2015-04-17 | 1 | -14/+9 |
* | LIBPCI: use enum with pci_system_type | Daniel Hellstrom | 2015-04-17 | 2 | -3/+3 |
* | LIBPCI: use RTEMS_INLINE_ROUTINE | Daniel Hellstrom | 2015-04-17 | 2 | -35/+40 |
* | LIBPCI: moved comment out of license header | Daniel Hellstrom | 2015-04-17 | 1 | -4/+9 |
* | PCI BUS: moved comment out of license header | Daniel Hellstrom | 2015-04-17 | 2 | -24/+22 |
* | LIBPCI: added license and auto-gen comment to pci/ids.h | Daniel Hellstrom | 2015-04-17 | 1 | -1/+26 |
| | | | | To be Merged. | ||||
* | LIBPCI: clean-up pci_for_each_child() search arg | Daniel Hellstrom | 2015-04-17 | 1 | -1/+4 |
* | LIBPCI: remove $Id in makefile.am | Daniel Hellstrom | 2015-04-17 | 1 | -4/+0 |
* | LIBPCI: converted to BSD header | Daniel Hellstrom | 2015-04-17 | 14 | -1158/+1833 |
* | DRVMGR: PCI BUS converted to BSD header | Daniel Hellstrom | 2015-04-17 | 1 | -8/+8 |
* | LIBPCI: moved pci_bus copyright into a single line | Daniel Hellstrom | 2015-04-17 | 2 | -4/+2 |
* | LIBPCI: moved copyright into a single line | Daniel Hellstrom | 2015-04-17 | 27 | -54/+27 |
* | LIBPCI: removed unused changes file | Daniel Hellstrom | 2015-04-17 | 1 | -46/+0 |
* | LIBPCI: fixed RES2DEV in pci/cfg.h | Daniel Hellstrom | 2015-04-17 | 1 | -2/+5 |
* | NGMP PCI: added support for NGMP prototype boards | Daniel Hellstrom | 2015-04-17 | 1 | -0/+1 |
* | GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device | Daniel Hellstrom | 2015-04-17 | 2 | -0/+2 |
| | | | | Interrupts have not been test yet | ||||
* | LIBPCI: added DRVMGR model for PCI bus | Daniel Hellstrom | 2015-04-17 | 4 | -0/+740 |
* | LIBPCI: added PCI layer to cpukit/libpci | Daniel Hellstrom | 2015-04-17 | 34 | -0/+4786 |
