CID 1399723: Missing break in switch in pci_read_addressable().
Closes #4279
The refactoring of pci_dev_create() was incorrect since the code relied on
different defines before including pci/cfg.h. This reverts back to the
original code having two pci_dev_create() one in auto and one in read library.
confdefs.h selectes between the two libraries so both there is no link
conflict.
Updates #3029
- new implementation private header file
- moved double implementation of pci_dev_create used by read & auto cfg
libraries to common pci_dev_create.c
- moved declaration of pci_bus_cnt to private header file so avoid extern
in .c files
