* | Regenerate. | Ralf Corsepius | 2005-05-24 | 1 | -4/+0 |
* | Remove (Unused, Non-POSIX/SUSV3). | Ralf Corsepius | 2005-05-24 | 1 | -342/+0 |
* | Reflect changes to libnetworking/arpa/nameser.h. | Ralf Corsepius | 2005-05-24 | 1 | -1/+1 |
* | Update from FreeBSD. | Ralf Corsepius | 2005-05-24 | 1 | -25/+30 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-24 | 1 | -10/+7 |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-24 | 1 | -9/+14 |
| | | | | | Add __packed. Partial update from FreeBSD. | ||||
* | Add "ICMP panic avoided" diagnostic counter. | Eric Norum | 2005-05-24 | 2 | -2/+7 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-21 | 2 | -57/+45 |
* | 2005-05-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-21 | 1 | -31/+45 |
| | | | | | * libnetworking/netinet/ip_icmp.h: Update from FreeBSD. Abandon BYTE_PACK. | ||||
* | Update from FreeBSD. | Ralf Corsepius | 2005-05-21 | 1 | -46/+56 |
* | 2005-05-20 Sergei Organov <osv@javad.ru> | Joel Sherrill | 2005-05-20 | 1 | -1/+1 |
| | | | | | | PR networking/772. * libnetworking/rtems/rtems_select.c (socket_select): fixed bug setting SB_WAIT flag of so_rcv instead of so_snd when FWRITE. | ||||
* | 2005-05-20 Sergei Organov <osv@topconrd.ru> | Joel Sherrill | 2005-05-20 | 1 | -1/+1 |
| | | | | | PR 749/networking * libnetworking/rtems/rtems_showroute.c: Avoid NULL dereference. | ||||
* | 2005-05-20 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2005-05-20 | 1 | -3/+4 |
| | | | | | | PR 793/networking * libnetworking/netinet/ip_icmp.c: Malicious ICMP packet causes panic. Just ignore it. | ||||
* | 2005-05-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-14 | 2 | -50/+28 |
| | | | | | * libnetworking/netinet/tcp_usrreq.c: Cosmetics from FreeBSD. * libnetworking/netinet/tcp_subr.c: Partical update from FreeBSD. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-12 | 1 | -17/+14 |
* | Update from FreeBSD, add __packed. | Ralf Corsepius | 2005-05-12 | 1 | -42/+63 |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-12 | 1 | -9/+9 |
* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 1 | -32/+44 |
| | | | | * libnetworking/netinet/if_ether.c: Partial update from FreeBSD. | ||||
* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 2 | -76/+91 |
| | | | | | * libnetworking/netinet/tcp_var.h: Partial update from FreeBSD. * libnetworking/netinet/tcp_input.c: Reflect changes to tcp_var.h. | ||||
* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 1 | -20/+31 |
| | | | | | * libnetworking/netinet/tcp.h: Partial update from FreeBSD. Remove BYTE_PACK. | ||||
* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 1 | -28/+29 |
| | | | | | * libnetworking/netinet/ip_var.h: Partial update from FreeBSD. Remove some useless BYTE_PACKs. | ||||
* | Define BYTE_PACK. | Ralf Corsepius | 2005-05-12 | 5 | -1/+17 |
* | Abandon AF_NS, PF_NS. | Ralf Corsepius | 2005-05-11 | 1 | -2/+2 |
* | Abandon AF_NS. | Ralf Corsepius | 2005-05-11 | 1 | -4/+0 |
* | socklen_t. | Ralf Corsepius | 2005-05-10 | 3 | -3/+3 |
* | Remove if_ipending (obsolete, unused). | Ralf Corsepius | 2005-05-10 | 1 | -2/+1 |
* | Remove IFI_* (obsolete, unused). | Ralf Corsepius | 2005-05-10 | 1 | -6/+0 |
* | 2005-05-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-09 | 1 | -9/+20 |
| | | | | | * libnetworking/sys/un.h: Partial update from FreeBSD. Remove non-implemented functions/variables. | ||||
* | Ansification. | Ralf Corsepius | 2005-05-09 | 1 | -29/+28 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-09 | 3 | -23/+49 |
* | Regenerate. | Ralf Corsepius | 2005-05-09 | 1 | -9/+0 |
* | New. | Ralf Corsepius | 2005-05-09 | 1 | -0/+44 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-09 | 1 | -83/+56 |
* | in_addr_t. | Ralf Corsepius | 2005-05-09 | 5 | -7/+7 |
* | socklen_t, PRIu32. | Ralf Corsepius | 2005-05-09 | 1 | -3/+4 |
* | Ansify, socklen_t. | Ralf Corsepius | 2005-05-09 | 1 | -5/+5 |
* | socklen_t. | Ralf Corsepius | 2005-05-09 | 1 | -2/+2 |
* | Include <sys/types.h>. | Ralf Corsepius | 2005-05-08 | 1 | -8/+12 |
| | | | | Remove in_port_t. Misc. updates from FreeBSD | ||||
* | Sync in_port_t with arpa/inet.h. | Ralf Corsepius | 2005-05-08 | 1 | -1/+1 |
* | Add in_addr_t, in_port_t. | Ralf Corsepius | 2005-05-08 | 1 | -2/+10 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-08 | 1 | -4/+13 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-08 | 1 | -25/+40 |
* | Add BYTE_PACK. | Ralf Corsepius | 2005-05-08 | 1 | -0/+4 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-08 | 3 | -8/+19 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-08 | 1 | -5/+5 |
* | Cosmetical updates from FreeBSD. | Ralf Corsepius | 2005-05-07 | 1 | -5/+5 |
* | More partial updates from FreeBSD. | Ralf Corsepius | 2005-05-07 | 1 | -2/+25 |
* | 2005-05-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-07 | 1 | -8/+8 |
| | | | | | * libnetworking/rtems/rtems_bsdnet.h: Eliminate rtems_* fixed size types. | ||||
* | * libnetworking/rtems/rtems_showifstat.c: Remove warning. | Joel Sherrill | 2005-05-06 | 1 | -0/+1 |
* | 2005-05-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-06 | 1 | -2/+0 |
| | | | | | * libnetworking/net/if.h: Revert include of sys/mbuf.h in this .h file since it causes other problems. |
