* libnetworking/Makefile.am: Reflect changes below.
* libnetworking/net/slcompress.h: New (from FreeBSD).
* libnetworking/net/slcompress.c: New (from FreeBSD).
* libnetworking/kern/kern_sysctl.c: Remove uintptr_t.
Cosmetics.
* libnetworking/opt_compat.h: New.
* libnetworking/opt_atalk.h, libnetworking/opt_bdg.h,
libnetworking/opt_inet.h, libnetworking/opt_inet6.h,
libnetworking/opt_ipx.h, libnetworking/opt_mac.h,
libnetworking/opt_netgraph.h: New (Stubs).
* libnetworking/net/if_loop.c: Cosmetical update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Update from FreeBSD.
* libnetworking/net/if.h: Update from FreeBSD.
* libnetworking/net/ethernet.h: Remove BYTE_PACK.
* libnetworking/net/ethernet.h: Update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Cosmetical updates from FreeBSD.
Add ether_sprintf.
* libnetworking/net/if.h; Cosmetical updates from FreeBSD.
Remove if_poll* (Not implemented in RTEMS, abandoned by FreeBSD).
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
PR 626/networking
* libnetworking/rtems/rtems_showifstat.c: Use unsigned char to avoid
printing leading FFFFFF for byte values > 127.
* libnetworking/kern/kern_sysctl.c: sysctl_register_all cannot be
static with RTEMS.
* libnetworking/netinet/in.c: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial updates from FreeBSD.
* libnetworking/netinet/igmp_var.h: Cosmetic updates from FreeBSD.
* libnetworking/sys/sysctl.h: Update from FreeBSD.
* libnetworking/sys/socketvar.h: Update from FreeBSD.
* libnetworking/sys/protosw.h: More partial updates from FreeBSD.
* libnetworking/net/route.c: Reflect changes to radix.h.
* libnetworking/net/radix.h, libnetworking/net/radix.c: Partial
* libnetworking/sys/socket.h: Further update from FreeBSD
(Add sa_family_t).
* libnetworking/sys/protosw.h: Partial update from FreeBSD.
* libnetworking/sys/socket.h: Partial update from FreeBSD.
* libnetworking/rtems/rtems_syscall.c: Reflect changes to socket.h.
* libnetworking/kern/uipc_socket.c: Partial update from FreeBSD
(Remove adv-clause from copyright notice).
* libnetworking/netinet/igmp_var.h: Partial update from FreeBSD.
* libnetworking/Makefile.am: Add -D_KERNEL to CPPFLAGS.
* libnetworking/net/bpf.h: Partial update from FreeBSD.
* libnetworking/sys/sysctl.h: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial update from FreeBSD.
* libnetworking/Makefile.am: AM_CPPFLAGS += -I$(srcdir).
* libnetworking/rtems/rtems_bsdnet_internal.h: Remove USHRT_MAX.
* libnetworking/Makefile.am: Fix typo.
* libnetworking/poll.h: Replace with sys/poll.h wrapper.
* libnetworking/sys/poll.h: New (Original FreeBSD file).
* libnetworking/Makefile.am: Don't install opt_ipfw.h,
opt_mrouting.h, opt_tcpdebug.h. Add sys/poll.h.
* libnetworking/lib/ftpfs.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/lib/tftpDriver.c, libnetworking/machine/endian.h,
libnetworking/net/if_ppp.c, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/rtems/rtems_glue.c,
libnetworking/rtems/rtems_syscall.c: Convert to using c99 fixed size
types.
* libnetworking/net/radix.c: Remove warning.
* libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* libnetworking/Makefile.am: Remove ACLOCAL_AMFLAGS.
PR pppd/564
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the
system use a slow baudrate for the modem or the tcp/ip-packet is
fragmented.
* ChangeLog: Merge-in libnetworking/ChangeLog.
* libnetworking/ChangeLog: Remove.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* netinet/in_cksum.c: #include netinet/in_cksum_<cpu>.h.
PR/549 networking
* netinet/in_cksum_powerpc.h: New (copy of in_cksum_powerpc.c).
* netinet/in_cksum_powerpc.c: Remove.
* netinet/in_cksum_i386.h: New (copy of in_cksum_i386.c).
* netinet/in_cksum_i386.c: Remove.
* netinet/in_cksum_arm.h: New (copy of in_cksum_arm.c).
* netinet/in_cksum_arm.c: Remove.
* netinet/in_cksum_m68k.c: New (copy of in_cksum_m68k.c).
* netinet/in_cksum_m68k.c: Remove.
* netinet/Makefile.am: Reflect changes above.
* Makefile.am: Include compile.am, again.
Cleanup.
