2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -7/+22 | |
2006-01-12 | Remove all-local. | Ralf Corsepius | 1 | -12/+16 | |
2006-01-08 | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -14/+15 | |
* libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting. | |||||
2005-11-14 | removed a few spaces... | Till Straumann | 1 | -2/+2 | |
2005-11-14 | Reflect mii.h and if_media.h having moved. | Ralf Corsepius | 1 | -3/+2 | |
2005-11-14 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -0/+733 | |
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h: New (Moved from c/src/libchip). | |||||
2005-11-08 | 2005-11-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+6 | |
* libnetworking/net/if.h: Add forward reference declaration to struct mbuf so ifru_tap callback is properly typed. * libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE which needs to be defined so various pieces of the .h files are visible to device drives. | |||||
2005-11-06 | Eliminate obsolete types. | Ralf Corsepius | 2 | -3/+3 | |
2005-11-03 | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 3 | -0/+421 | |
* libnetworking/Makefile.am, libnetworking/preinstall.am: Added simple implementation of ethernet media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys. * libnetworking/rtems/rtems_mii_ioctl.c, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c: New files. | |||||
2005-11-02 | 2005-11-02 Fredic Praca <freebsd-fr.org> | Joel Sherrill | 1 | -7/+7 | |
PR 842/networking * libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename dprintf to debugprintf(). | |||||
2005-11-02 | 2005-11-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -6405/+0 | |
* libnetworking/net/zlib.c: Remove. * libnetworking/net/zlib.h: Remove. * libnetworking/Makefile.am: Reflect changes above. | |||||
2005-10-27 | Update from FreeBSD. | Ralf Corsepius | 2 | -39/+58 | |
2005-10-27 | Remove. | Ralf Corsepius | 1 | -11/+0 | |
2005-10-27 | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -21/+28 | |
* libnetworking/Makefile.am: Don't install loop.h. | |||||
2005-10-27 | New. | Ralf Corsepius | 1 | -0/+11 | |
2005-10-25 | Don't sign-extend address components. | Eric Norum | 1 | -2/+2 | |
2005-09-19 | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -218/+11 | |
* libnetworking/sys/mount.h: Cosmetical update from FreeBSD. Remove non-implemented interfaces (vfs, nfs, fsstat, etc.). | |||||
2005-09-16 | Cosmetics | Ralf Corsepius | 1 | -8/+6 | |
2005-09-16 | Update from FreeBSD | Ralf Corsepius | 1 | -46/+15 | |
2005-09-16 | Remove superfluous includes. | Ralf Corsepius | 1 | -4/+1 | |
2005-09-16 | Partial update from FreeBSD. | Ralf Corsepius | 2 | -29/+27 | |
2005-09-16 | Partial update from FreeBSD. | Ralf Corsepius | 1 | -77/+60 | |
2005-08-06 | 2005-08-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+0 | |
* libnetworking/nfs/bootp_subr.c: Don't include nfs/nfs.h, nfs/krpc.h. | |||||
2005-08-05 | Regenerate. | Ralf Corsepius | 1 | -4/+4 | |
2005-08-05 | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -490/+33 | |
* Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h | |||||
2005-08-01 | Partial update from FreeBSD. | Ralf Corsepius | 1 | -16/+15 | |
2005-07-06 | 2005-07-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+1 | |
* libnetworking/lib/syslog.c: Fix spelling mistake. * libnetworking/sys/uio.h: Partial update from FreeBSD. * libnetworking/kern/kern_subr.c: Reflect changes above. | |||||
2005-07-06 | Fix spelling mistake. | Ralf Corsepius | 1 | -1/+1 | |
2005-07-06 | Partial update from FreeBSD. | Ralf Corsepius | 1 | -13/+20 | |
2005-06-30 | The DHCP header. | Chris Johns | 1 | -0/+47 | |
2005-06-30 | DHCP server for RTEMS. | Chris Johns | 1 | -0/+1133 | |
2005-06-17 | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+2 | |
* libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended dependencies added by the RTEMS specific tap interface. | |||||
2005-05-27 | Partial update from FreeBSD. | Ralf Corsepius | 1 | -2/+3 | |
2005-05-27 | Remove BYTE_PACK. | Ralf Corsepius | 2 | -14/+8 | |
2005-05-27 | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* librpc/include/rpc/clnt.h: Partial update from FreeBSD. | |||||
2005-05-27 | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -3/+3 | |
* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings. | |||||
2005-05-24 | Regenerate. | Ralf Corsepius | 1 | -4/+0 | |
2005-05-24 | Remove (Unused, Non-POSIX/SUSV3). | Ralf Corsepius | 1 | -342/+0 | |
2005-05-24 | Reflect changes to libnetworking/arpa/nameser.h. | Ralf Corsepius | 1 | -1/+1 | |
2005-05-24 | Update from FreeBSD. | Ralf Corsepius | 1 | -25/+30 | |
2005-05-24 | Cosmetics from FreeBSD. | Ralf Corsepius | 1 | -10/+7 | |
2005-05-24 | Remove BYTE_PACK. | Ralf Corsepius | 1 | -9/+14 | |
Add __packed. Partial update from FreeBSD. | |||||
2005-05-24 | Add "ICMP panic avoided" diagnostic counter. | Eric Norum | 2 | -2/+7 | |
2005-05-21 | Partial update from FreeBSD. | Ralf Corsepius | 2 | -57/+45 | |
2005-05-21 | 2005-05-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -31/+45 | |
* libnetworking/netinet/ip_icmp.h: Update from FreeBSD. Abandon BYTE_PACK. | |||||
2005-05-21 | Update from FreeBSD. | Ralf Corsepius | 1 | -46/+56 | |
2005-05-20 | 2005-05-20 Sergei Organov <osv@javad.ru> | Joel Sherrill | 1 | -1/+1 | |
PR networking/772. * libnetworking/rtems/rtems_select.c (socket_select): fixed bug setting SB_WAIT flag of so_rcv instead of so_snd when FWRITE. | |||||
2005-05-20 | 2005-05-20 Sergei Organov <osv@topconrd.ru> | Joel Sherrill | 1 | -1/+1 | |
PR 749/networking * libnetworking/rtems/rtems_showroute.c: Avoid NULL dereference. | |||||
2005-05-20 | 2005-05-20 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 1 | -3/+4 | |
PR 793/networking * libnetworking/netinet/ip_icmp.c: Malicious ICMP packet causes panic. Just ignore it. | |||||
2005-05-14 | 2005-05-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -50/+28 | |
* libnetworking/netinet/tcp_usrreq.c: Cosmetics from FreeBSD. * libnetworking/netinet/tcp_subr.c: Partical update from FreeBSD. |
