Install the network headers only if --enable-networking is specified.
Update #3254.
Update #2843.
Update #2843.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3117.
Update #3182.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
For whatever reason FreeBSD renames several functions provided by
<arpa/inet.h> and uses weak references to provide the standard function
names. This causes problems on targets lacking proper support for weak
references. We do not need this function renaming on RTEMS.lk:x
Update #2833.
Close #2877.
Move legacy network stack implementation specifics to
<rtems/rtems_bsdnet_internal.h>. Include missing header files. Add
interface flags compatibility.
Update #2833.
Update #2833.
Update #2833.
Prevent accidental use of legacy network header files.
Update #2833.
Move RTEMS specifics to <rtems/rtems_bsdnet.h>.
Introduce rtems_tap_ifreq. The interface tap support is RTEMS-specific
and only available in the legacy network stack.
Update #2833.
Do not rely on indirect includes via other header files.
Update #2833.
Some kernel-space header expect that <sys/param.h> is present.
Update #2833.
Update #2833.
Update #2833.
Do not use the MSIZE for the legacy network stack. Instead use
_SYS_MBUF_LEGACY_MSIZE.
Update #2833.
Update #2833.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
These kernel space header files must be provided for Newlib
172e2050d95b41861db858dd9bc43a3fb4a28987.
Use the Thread_Control::resource_count for the no protocol mutexes.
Merge the no protocol and priority inherit CORE mutex seize/surrender
operations.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
Import the <sys/socket.h> from current FreeBSD. This allows to build
some current software (e.g. libressl).
Close #2748.
This is necessary for new <sys/socket.h>.
Import the <arpa/inet.h> from current FreeBSD. Necessary due to changes
in <netinet/in.h>. Remove BSD hack from <arpa/inet.h>.
Clean up problems with htonl(). These functions are defined in
<arpa/inet.h>. This lead to some problems because they are defined in
<rtems/endian.h> too. Add NTOHL, ... to
Import the <netinet/in.h> from current FreeBSD. This allows to build
Add legacy support like
* prototype for in_cksum(),
* IPPORT_USERRESERVED,
* deprecated IPCTL_RT* defines,
* ip_fw_chk_t and ip_fw_ctl_t,
* ip_nat_... (IP NAT hooks), and
* IP_NAT option for get/setsockopt()
to new <rtems/rtems_netinet_in.h>.
Import the <netinet6/in6.h> from current FreeBSD. This allows to build
Import the <sys/_sockaddr_storage.h> from current FreeBSD. Necessary
for <netinet/in.h> update.
This implementation just falls back to giving a string representation of
the IP. It supports IPv4 only.
Add test for getnameinfo().
Import the <netdb.h> from current FreeBSD. This allows to build some
Add __h_errno().
Update gethostent_r() API. Linux and FreeBSD use a common API now.
Adapt the RTEMS one to provide the same one.
Match gethostbyname_r() with prototype.
Move prototypes of non-portable _get*by*name/addr and _set/end*ent
functions. This makes it easier to update <netdb.h>.
