* libnetworking/Makefile.am, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getservbyname.c,
libnetworking/libc/getservbyport.c: Add initial versions of
getservbyport_r(), gethostbyaddr_r(), and getservbyport_r(). At this
point they are just simple weappers for the version without the _r in
the name.
* libnetworking/netinet/ip_output.c: when fragmenting
multicast packets M_MCAST must be set on all fragments.
This was fixed in FreeBSD ip_output.c 1.82 on 1998/8/23 !
(see my email to rtems-users from 2008/5/15).
* libnetworking/rtems/rtems_dhcp.c: Removed panic()s. Added
interface for rtems_dhcp_failsafe.
* libnetworking/rtems/rtems_dhcp.h: Added interface for
2008-05-01 Arnout Vandecappelle <arnout@mind.be>
* libnetworking/nfs/bootp_subr: Allow some errors for sosend() and
return on timeout in bootpc_call(). Removed panic()s.
* libnetworking/rtems/rtems_glue.c: Fix the cast for the
SIOCAIFADDR ioctl call.
* libnetworking/rtems/rtems_dhcp_failsafe.c,
libnetworking/rtems/rtems_dhcp_failsafe.h: New.
* libnetworking/Makefile.am, libnetworking/preinstall.am: Added
rtems_dhcp_failsafe.c and rtems_dhcp_failsafe.h files.
PR 1277/networking
* libnetworking/netinet/in_cksum_i386.h: Use q instead of r in
constraint for assembly language. This restricts the register choice
to the a-d registers.
* libnetworking/kern/uipc_socket2.c,
libnetworking/netinet/tcp_usrreq.c,
libnetworking/netinet/udp_usrreq.c,
libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c:
Add configuration parameters for network stack efficiency multiplier
and default socket buffer sizes. Change default multiplier from 8 to
2 to match GNU/Linux. This has no impact on performance on the BSPs
tested.
* configure.ac: fixed bug that always enabled strict order
mutexes.
* score/inline/rtems/score/coremutex.inl: Fixed coding standard.
* score/src/coremutex.c: Add the holder's thread to the lock_mutex
list if the mutex is initialised locked.
* libnetworking/rtems/rtems_glue.c: Changed semaphore error
message to show the error is an rtems-net error.
* libmisc/monitor/mon-network.c: Removed warnings.
* telnetd/icmds.c: Changed shell_* to rtems_shell_*.
* score/Makefile.am: Fixed typo that stopped 'make tags' working.
* libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c,
libmisc/shell/extern-cp.h, libmisc/shell/fts.c,
libmisc/shell/fts.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c, libmisc/shell/verr.c,
libmisc/shell/verrx.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: New. Ported from BSD.
* libmisc/shell/shellconfig.h: Add the cp command.
* libmisc/Makefile.am: Add the new files to the shell.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting
support.
* libblock/src/flashdisk.c: Fixed disk drive count size setting
bug.
* libnetworking/rtems/tftp.h: Provide a decl to the TFTP file
system opts table.
* libnetworking/rtems/ftpfs.h: Provide a decl to the FTP file
system opts table.
* libmisc/Makefile.am: Add the mount command and supporting files.
* libmisc/preinstall.am: Rebuilt.
* libmisc/shell/cat_file.c, libmisc/shell/cmds.c,
libmisc/shell/main_alias.c, libmisc/shell/main_cat.c,
libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c,
libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c,
libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c,
libmisc/shell/main_dir.c, libmisc/shell/main_exit.c,
libmisc/shell/main_help.c, libmisc/shell/main_id.c,
libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mallocdump.c, libmisc/shell/main_mdump.c,
libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c,
libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c,
libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c,
libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c,
libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c,
libmisc/shell/shell.c, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/str2int.c,
libmisc/shell/write_file.c: Move all shell_* types, variables and
functions to rtems_shell_* to avoid namespace clashes with
applications. The is an RTEMS shell after all.
* libmisc/shell/shell.h, libmisc/shell/internal.h,
libmisc/shell/shellconfig.h: Move all shell_* types, variables and
applications. Add the mount command supporting types.
* libmisc/shell/main_mount.c, libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_nfs.c,
libmisc/shell/main_mount_tftp.c: New.
* libnetworking/netinet/in_cksum.c: ARM optimized version does not
support Thumb.
* libnetworking/rtems/rtems_glue.c: let rtems_bsdnet_ifconfig
(SIOCGIFMEDIA) pass the user parameter down to the ioctl
so that it knows what PHY they want to look at.
Ralf Corsépius <ralf.corsepius@rtems.org>
* libnetworking/ifaddrs.h, libnetworking/libc/getifaddrs.c,
libnetworking/libc/if_indextoname.c,
libnetworking/libc/if_nameindex.c: New (from FreeBSD)
* Makefile.am: Add files above.
* libnetworking/net/if.h: Add if_nameindex (from FreeBSD).
PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* libnetworking/Makefile.am: Add dummy socketpair() implementation to
document what is required to provide a fully functional
implementation.
* libnetworking/rtems/rtems_socketpair.c: New file.
* libnetworking/net/ppp_defs.h: Include rtems/stdint.h.
Use uint32_t for ext_accm.
PR 1248/networking
* libnetworking/rtems/rtems_glue.c: Luke Stras <luke@spacequest.com>
reported that when no interfaces are successfully attached, the
default route is broken and may result in a jump to an illegal
address.
* libnetworking/netinet/in_cksum_m68k.h: Use __mcoldfire__ to
identify coldfire cpus.
* libnetworking/rtems/rtems_syscall.c: Remove RTEMS versions of send()
and recv(). We already had the BSD versions and these conflict
sometimes when linking.
* libnetworking/rtems/mkrootfs.h, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h: Add extern __cplusplus.
* libnetworking/machine/endian.h: Remove
CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* libnetworking/machine/endian.h: Convert htons, htonl, ntohs, ntohl
to inline functions, using uint[16,32]_t.
* libnetworking/netdb.h: Change netent->n_net to uint32_t to comply
with SUSv3.
* libnetworking/Makefile.am: Move libc/send.c to libc_a_SOURCES.
* libnetworking/Makefile.am: Move libc/recv.c to libc_a_SOURCES.
Remove libc/iso_addr.c, libc/iso_addr.3.
* libnetworking/netinet/ip.h: Add FreeBSD's alignement macros.
* libnetworking/net/netisr.h: Partial update from FreeBSD.
* libnetworking/libc/strsep.c: Don't build if provided by libc.
