* libnetworking/rtems/rtems_showipstat.c: Print IP input queue drops.
* libnetworking/lib/ftpfs.c: Fixed reply parsing.
PR 1381/networking
* libnetworking/netinet/ip_output.c: If a null or unreachable gateway
is specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno 118 Host
* libnetworking/rtems/tftp.h, libnetworking/lib/tftpDriver.c: Fixed
prototype.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libnetworking/sys/signalvar.h: Cosmetics from FreeBSD.
Comment out psignal().
* libnetworking/Makefile.am: Reformat.
* librpc/Makefile.am: Reformat.
* libnetworking/rtems/rtems_bsdnet_internal.h: Move
#include <rtems.h> out of C++-guard.
* libnetworking/sys/linker_set.h: Add local versions of __used
and __CONCAT macros.
* libnetworking/rtems/rtems_mii_ioctl_kern.c: Do not use IFM_ACTIVE
and IFM_AVALID in the media word.
* libnetworking/net/if_media.h: Hack to get libbsdport interface
drivers working.
* libnetworking/netinet/ip_icmp.c, libnetworking/netinet/ip_icmp.h:
Misc. changes from FreeBSD.
* libnetworking/netinet/tcp_var.h: Include <netinet/tcp_timer.h>.
* libnetworking/netinet/in_systm.h,
libnetworking/netinet/tcp_debug.c,
libnetworking/netinet/tcp_debug.h, libnetworking/netinet/tcp_seq.h,
libnetworking/netinet/tcp_var.h, libnetworking/netinet/tcpip.h:
Misc changes from FreeBSD.
* libnetworking/net/if_pppvar.h: Add "extern C++" guards.
Add header guard.
* libnetworking/sys/signalvar.h: Comment out unused code.
* libnetworking/machine/in_cksum.h: Add missing includes.
* libnetworking/vm/vm_kern.h: Comment out unused vars.
* libnetworking/lib/ftpfs.c: Workaround for some firewalls.
* libnetworking/loop.h, libnetworking/net/if_loop.c,
libnetworking/rtems/rtems_glue.c, libmisc/dummy/dummy-networking.c:
Initialize loop back interface during normal initialization via
rtems_bsdnet_initialize_network().
* libnetworking/lib/ftpfs.c: Do not fall back to BOOTP server address
in case hostname was not specified.
* libnetworking/lib/ftpfs.c: Fixed a special case with no username and
password.
PR 1696/networking:
* libnetworking/arpa/inet.h: Partial update from FreeBSD.
#include <rtems/endian.h>.
Remove addr2ascii, ascii2addr.
* libnetworking/libc/addr2ascii.c,
libnetworking/libc/ascii2addr.c,
libnetworking/libc/addr2ascii.3: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* libcsupport/include/rtems/libio_.h: Removed rtems_filesystem_null_handlers.
* libcsupport/src/fs_null_handlers.c: Removed file.
* libcsupport/Makefile.am: Reflect change above.
* libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_creat.c,
libfs/src/imfs/imfs_init.c, libfs/src/imfs/miniimfs_init.c: Use
rtems_filesystem_handlers_default instead of
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c:
Initialize handler and operations table with proper defaults.
* libcsupport/include/rtems/libio.h: Removed file_info and handlers
fields in rtems_libio_t.
* libcsupport/src/close.c, libcsupport/src/fcntl.c,
libcsupport/src/fdatasync.c, libcsupport/src/fstat.c,
libcsupport/src/fsync.c, libcsupport/src/ftruncate.c,
libcsupport/src/getdents.c, libcsupport/src/ioctl.c,
libcsupport/src/libio_sockets.c, libcsupport/src/lseek.c,
libcsupport/src/open.c, libcsupport/src/read.c,
libcsupport/src/readv.c, libcsupport/src/write.c,
libcsupport/src/writev.c, libfs/src/devfs/devclose.c,
libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c,
libfs/src/devfs/devread.c, libfs/src/devfs/devwrite.c
libfs/src/dosfs/msdos_dir.c libfs/src/dosfs/msdos_file.c
libfs/src/imfs/deviceio.c libfs/src/imfs/imfs_directory.c
libfs/src/imfs/imfs_fifo.c libfs/src/imfs/memfile.c
libfs/src/nfsclient/src/nfs.c libfs/src/rfs/rtems-rfs-rtems-file.c
libfs/src/rfs/rtems-rfs-rtems.h libnetworking/lib/ftpfs.c: Reflect
changes above.
* libnetworking/rtems/rtems_syscall.c: Fix warning.
* libnetworking/rtems/rtems_syscall.c: Replaced null socket handlers
with default handlers. Null handlers are no longer allowed.
* libnetworking/lib/tftpDriver.c: rtems_tftp_ops and
rtems_tftp_handlers are now const and static.
* libnetworking/rtems/tftp.h: Removed
rtems_bsdnet_initialize_tftp_filesystem and rtems_tftp_ops.
* libnetworking/rtems/mkrootfs.h: doxygen cosmetics.
* libnetworking/netinet/if_ether.c: Misc. 64bit fixes from FreeBSD.
PR 1566/filesystem
* libnetworking/rtems/mkrootfs.c, libnetworking/rtems/mkrootfs.h:
Let rtems_rootfs_append_host_rec take an in_addr_t as first arg.
* libnetworking/rtems/rtems_dhcp.c, libnetworking/nfs/bootp_subr.c:
* libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c,
libnetworking/nfs/bootp_subr.c: Misc. 64bit-compatibility fixes.
* libnetworking/netinet/ip_fw.c, libnetworking/netinet/ip_input.c:
* libnetworking/rtems/mkrootfs.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/timestamp.h: Move 'extern "C"'.
* libnetworking/netinet/in_pcb.c:
Eliminate "ushort".
* libfs/src/pipe/fifo.c: Remove unused variable to fix warning.
* libnetworking/rtems/mkrootfs.c: Add include to fix warning.
* rtems/src/tasksetpriority.c: Fix spacing.
* libnetworking/rtems/ftpfs.h, libnetworking/lib/ftpfs.c: Removed
rtems_ftpfs_mount().
* libnetworking/rtems/ftpfs.h, libnetworking/lib/ftpfs.c: Added
rtems_ftpfs_mount() again. Documentation.
PR 1524/filesystem
* libcsupport/src/rtems_mkdir.c: New file.
* libcsupport/src/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Added rtems_mkdir().
* libmisc/fsmount/fsmount.h, libmisc/fsmount/fsmount.c,
libblock/src/bdpart-mount.c, libnetworking/rtems/mkrootfs.h,
libnetworking/rtems/mkrootfs.c, libfs/src/pipe/pipe.c: Use
rtems_mkdir(). Removed rtems_fsmount_create_mount_point() and
rtems_rootfs_mkdir().
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/imfs/miniimfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
* libnetworking/net/if.c:
Use uintptr_t and void* in _offsetof().
* libnetworking/netinet/raw_ip.c:
Cast nam to uintptr_t instead of int.
* libnetworking/libc/gethostnamadr.c:
Cast addr to uintptr_t instead of size_t.
Try to make crazy address arithmetic more portable.
