* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h:
Ansification, cosmetics from FreeBSD.
PR 755/rtems
* libnetworking/libc/res_init.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/nfs/bootp_subr.c: Include <rtems/bsdnet/servers.h>.
PR 755/rtems
* libnetworking/rtems_glue.c:
Rename rtems_bsdnet_nameservers to _rtems_bsdnet_nameservers.
Rename rtems_bsdnet_ntpservers to _rtems_bsdnet_ntpservers.
Add new rtems_bsdnet_nameservers, rtems_bsdnet_ntpservers as
pointers to _rtems_bsdnet_*servers arrays.
* libnetworking/rtems/rtems_bsdnet_internal.h: Remove
rtems_bsdnet_nameserver, rtems_bsdnet_nameserver_count.
* libnetworking/rtems/rtems_bsdnet.h: Remove
rtems_bsdnet_ntpserver, rtems_bsdnet_ntp_count.
* libnetworking/rtems/bsdnet/servers.h: New.
* libnetworking/opt_ipsec.h: New (BSD compatibility).
* libnetworking/Makefile.am: Reflect changes above.
* libnetworking/net/if_pppvar.h: Ansify.
* libnetworking/libc/res_debug.c: Added const to eliminate warnings.
* cpu_asm.S: Collected PR 601 changes for commit to cvshead
for rtems-4.7
* libnetworking/net/if_ethersubr.c,
libnetworking/net/radix.h,
libnetworking/netinet/if_ether.h,
libnetworking/netinet/igmp_var.h,
libnetworking/netinet/in_var.h,
libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c,
libnetworking/rtems/rtems_glue.c:
Misc. updates from FreeBSD and bugfixes tripped by GCC-4.0.0.
* libnetworking/kern/kern_sysctl.c,
libnetworking/sys/sysctl.h: Add SYSCTL_CHILDREN_SET
(Update from FreeBSD for GCC-4.0.0).
* libnetworking/kern/kern_sysctl.c, libnetworking/netinet/ip_mroute.c,
libnetworking/sys/socketvar.h: Remove warnings.
* libnetworking/net/radix.c, libnetworking/net/radix.h,
libnetworking/net/route.h, libnetworking/netinet/if_ether.h,
libnetworking/netinet/in_var.h, libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c, libnetworking/netinet/udp_var.h,
libnetworking/sys/callout.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h: Cosmetics from FreeBSD.
* libnetworking/machine/endian.h: Protect BYTE_ORDER from double
definition.
* libnetworking/Makefile.am: Reflect changes below.
* libnetworking/net/slcompress.h: New (from FreeBSD).
* libnetworking/net/slcompress.c: New (from FreeBSD).
* libnetworking/kern/kern_sysctl.c: Remove uintptr_t.
Cosmetics.
* libnetworking/opt_compat.h: New.
* libnetworking/opt_atalk.h, libnetworking/opt_bdg.h,
libnetworking/opt_inet.h, libnetworking/opt_inet6.h,
libnetworking/opt_ipx.h, libnetworking/opt_mac.h,
libnetworking/opt_netgraph.h: New (Stubs).
* libnetworking/net/if_loop.c: Cosmetical update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Update from FreeBSD.
* libnetworking/net/if.h: Update from FreeBSD.
* libnetworking/net/ethernet.h: Remove BYTE_PACK.
* libnetworking/net/ethernet.h: Update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Cosmetical updates from FreeBSD.
Add ether_sprintf.
* libnetworking/net/if.h; Cosmetical updates from FreeBSD.
Remove if_poll* (Not implemented in RTEMS, abandoned by FreeBSD).
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
PR 626/networking
* libnetworking/rtems/rtems_showifstat.c: Use unsigned char to avoid
printing leading FFFFFF for byte values > 127.
* libnetworking/kern/kern_sysctl.c: sysctl_register_all cannot be
static with RTEMS.
* libnetworking/netinet/in.c: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial updates from FreeBSD.
* libnetworking/netinet/igmp_var.h: Cosmetic updates from FreeBSD.
* libnetworking/sys/sysctl.h: Update from FreeBSD.
* libnetworking/sys/socketvar.h: Update from FreeBSD.
* libnetworking/sys/protosw.h: More partial updates from FreeBSD.
* libnetworking/net/route.c: Reflect changes to radix.h.
* libnetworking/net/radix.h, libnetworking/net/radix.c: Partial
* libnetworking/sys/socket.h: Further update from FreeBSD
(Add sa_family_t).
* libnetworking/sys/protosw.h: Partial update from FreeBSD.
* libnetworking/sys/socket.h: Partial update from FreeBSD.
* libnetworking/rtems/rtems_syscall.c: Reflect changes to socket.h.
* libnetworking/kern/uipc_socket.c: Partial update from FreeBSD
(Remove adv-clause from copyright notice).
* libnetworking/netinet/igmp_var.h: Partial update from FreeBSD.
* libnetworking/Makefile.am: Add -D_KERNEL to CPPFLAGS.
* libnetworking/net/bpf.h: Partial update from FreeBSD.
* libnetworking/sys/sysctl.h: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial update from FreeBSD.
