* sys/select.h: Add C++ to C external.
* kern/uipc_mbuf.c: Comment out m0 in m_copydata to suppress
warning.
* ChangeLog: Corrected.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
* libc/rcmd.c, netinet/in_cksum_arm.c: Removed warnings.
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* Makefile.am: Remove bogus reference to CHANGELOG.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* net/if_ethersubr.c: Add comments to #endif NETATALK to stop
gcc from complaining.
* netinet/tcp_var.h: Corrected typo in ARM alignment patch which
broke all other ports.
* netinet/in_cksum.c, netinet/ip_icmp.h, netinet/ip_input.c,
netinet/tcp_input.c, netinet/tcp_subr.c, netinet/tcp_var.h,
sys/queue.h: Address alignment requirements for the ARM.
* rtems/rtems_glue.c: Add IP aliasing ioctls SIOCAIFADDR and
SIOCDIFADDR.
* kern/uipc_socket.c: Make sure that small non-zero delays work.
Suggested cleanup from Eric Norum.
* rtems/mkrootfs.c: As part of PR283, remove redundant code that
creates /etc/passwd and /etc/group.
* netinet/Makefile.am, netinet/udp_usrreq.c: Back off some of
the IP_FORWARD patch as it appears to not compile in the
current tree.
* kern/uipc_socket.c: Fix case on SO_RCVTIMEO and SO_SNDTIMEO where
conversion into ticks can result in a 0 ticks timeout which is
the same as requesting no timeout. Reported by Sergei Organov
<osv@javad.ru>.
* kern/uipc_mbuf.c, sys/mbuf.h, netinet/udp_usrreq.c: Add
optional UDP broadcast forwarding support.
* netinet/Makefile.am: Defined FORWARD_PROTOCOL to enabled UDP
broadcast forwarding.
* netinet/in_cksum.c: #include <string.h> for puts in generic
routines.
* rtems/rtems_glue.c: Per PR270, the BSD network code expects that
the value of the number of seconds since boot is non-zero. The
RTEMS network initialization code assures this by waiting for a
second. A more efficient technique is to simply wait until the
* libc/getservent.c: Per PR265, add #include <netinet/in.h> for
ntohl() function.
* netinet/in.h: Per PR263, added include of <machine/endian.h>
to <netinet/in.h> so it includes prototypes of ntohl() family
of routines.
* machine/param.h, sys/syslimits.h: In the continued effort to
eliminate .h conflicts between newlib and RTEMS, these were moved to
newlib.
* machine/Makefile.am, sys/Makefile.am: Reflect above.
* wrapup/Makefile.am: Don't install.
* sys/param.h: Removed as a simpler version of this file is
now part of the RTEMS newlib support.
* sys/Makefile.am: Modified to reflect above.
* machine/types.h: Removed as a simpler version of this file is
* machine/Makefile.am, machine/endian.h, nfs/bootp_subr.c,
rtems/rtems_bsdnet_internal.h, sys/Makefile.am, sys/systm.h:
Minor modifications to use the simpler machine/types.h. Mostly
more complete sets of #include's to account for machine/types.h
no longer doing this.
* netinet/in_cksum.c, netinet/in_cksum_arm.c: Added ARM in_cksum
support.
* sys/select.h: Add a prototype of select() to avoid warnings.
In particular a C++ application using select() required a prototype.
* Makefile.am, libc/res_send.c: Do not install or use <poll.h>
since RTEMS does not support it.
* kern/Makefile.am: Use .$(OBJEXT) instead of .o.
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
* kern/Makefile.am: Eliminate LIBNAME.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h:
Modified to added packed attribute.o
* configure.ac: RTEMS_TOP(../..).
* Addition of a ftp client filesystem, comparable to the tftp one.
* lib/ftpfs.c, rtems/ftpfs.h: New files.
* lib/Makefile.am, rtems/Makefile.am: Modified to reflect above.
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* wrapup/Makefile.am: Don't preinstall libnetworking.a.
* Makefile.am: Remove commented out net-apps.
* arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* kern/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* lib/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* libc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* machine/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* net/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* sys/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* vm/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: include multilib.am instead of RTEMS_BSP.cfg.
* configure.ac: Remove RTEMS_CHECK_POSIX_API.
Remove RTEMS_ENABLE_POSIX.
Remove RTEMS_CHECK_CUSTOM_BSP.
Relocate c/src/libnetworking.
* Makefile.am: Reflect moval.
* machine/Makefile.am: Ditto.
* vm/Makefile.am: Ditto.
* sys/Makefile.am: Ditto.
* arpa/Makefile.am: Ditto.
* kern/Makefile.am: Ditto.
* configure.ac: Dittp.
* wrapup/Makefile.am: Ditto. Remove references to networking apps.
* rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
* rtems/mkrootfs.c: Add (relocated from libmisc/rootfs).
* rtems/mkrootfs.h: Ditto.
* rtems/Makefile.am: Reflect changes above.
* sys/ioctl.h: Remove.
* sys/sockio.h: Remove.
* sys/filio.h: Remove.
* sys/Makefile.am: Reflect changes above.
* ChangeLog: Corrected -- entry should have been in libchip.
* bootloader/Makefile.am, console/Makefile.am, pci/Makefile.am:
Per PR215 address the following issues:
- _IO_BASE, _ISA_MEM_BASE and PCI_DRAM_OFFSET
are no longer defined by libcpu (powerpc/shared/include/io.h)
but by the BSP (who is the only one to know the values)
- the affected BSP (shared/motorola) headers have been fixed
in a separate "libbsp/powerpc/shared" patch.
- the DEC 21140 driver (libchip/network/dec21140.c) has been
fixed to use PCI_DRAM_OFFSET instead of PREP_PCI_DRAM_OFFSET.
and PCI_MEM_BASE instead of PREP_ISA_MEM_BASE. PCI_MEM_BASE
is to be defined by the BSP who is using this driver.
- the DEC driver also has been fixed to use the newer
rtems_bsp_delay_in_bus_cycles() instead of the obsolete
delay_in_bus_cycles().
* network/dec21140.c: Per PR215 address the following issues:
