This makes the @file documentation independent of the actual file name.
Update #3707.
Fix for:
- tftpfs did not mount, when device field in mount entry is empty
- tftpfs needs to allocate fs structure before it fills it (avoid use of
uninitialized pointer)
- tftpfs needs to skip initial slash before hostname
These functions are provided by Newlib since 2002.
Update #3409.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Update #3530.
Update #3533.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
The man page installation is broken since 2004-01-11 (commit
8c31a89fdf9bc3351d837df6ec26045bc9d5f021). Nobody complained about
this, so just remove some dead code from the Makefile.am.
The <poll.h> is a POSIX header file and just includes <sys/poll.h> which
contains the real content.
Move the kernel space content of some Newlib provided header files to
RTEMS and libbsd. This allows to use the Newlib provided header files
with different FreeBSD baselines.
Update #3472.
Update #3419.
Move FTP client filesystem to separate library libftpfs.a.
Update #3419.
Move TFTP client filesystem to separate library libtftpfs.a.
Conditionally use legacy network stack features, e.g. BOOTP support.
Update #3419.
Install the network headers only if --enable-networking is specified.
Update #3254.
Update #2843.
Update #2843.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3117.
Update #3182.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
For whatever reason FreeBSD renames several functions provided by
<arpa/inet.h> and uses weak references to provide the standard function
names. This causes problems on targets lacking proper support for weak
references. We do not need this function renaming on RTEMS.lk:x
Update #2833.
Close #2877.
Move legacy network stack implementation specifics to
<rtems/rtems_bsdnet_internal.h>. Include missing header files. Add
interface flags compatibility.
Update #2833.
Update #2833.
Update #2833.
Prevent accidental use of legacy network header files.
Update #2833.
Move RTEMS specifics to <rtems/rtems_bsdnet.h>.
Introduce rtems_tap_ifreq. The interface tap support is RTEMS-specific
and only available in the legacy network stack.
Update #2833.
Do not rely on indirect includes via other header files.
Update #2833.
Some kernel-space header expect that <sys/param.h> is present.
Update #2833.
Update #2833.
Update #2833.
Do not use the MSIZE for the legacy network stack. Instead use
_SYS_MBUF_LEGACY_MSIZE.
Update #2833.
Update #2833.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
These kernel space header files must be provided for Newlib
172e2050d95b41861db858dd9bc43a3fb4a28987.
