* | Update icps_allecho counter. | Eric Norum | 2006-05-31 | 1 | -4/+7 |
* | Add flag to inhibit ICMP replies. | Eric Norum | 2006-05-30 | 3 | -3/+10 |
* | Provide customisable mbuf allocation. | Eric Norum | 2006-05-25 | 4 | -4/+53 |
| | | | | Patch from Steven Johnson <sjohnson@sakuraindustries.com> | ||||
* | 2006-04-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-13 | 1 | -1/+1 |
| | | | | | | | | PR 949/networking * libnetworking/sys/socket.h: GNU/Linux is wrong in making MSG_DONTWAIT public. It is strictly BSD and not SUSV. See http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html for clarification. | ||||
* | 2006-04-12 Lars Munch <lars@segv.dk> | Joel Sherrill | 2006-04-12 | 1 | -1/+1 |
| | | | | | PR 949/networking * libnetworking/sys/socket.h: Make MSG_DONTWAIT public as in GNU/Linux. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -7/+22 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -12/+16 |
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 1 | -14/+15 |
| | | | | * libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting. | ||||
* | removed a few spaces... | Till Straumann | 2005-11-14 | 1 | -2/+2 |
* | Reflect mii.h and if_media.h having moved. | Ralf Corsepius | 2005-11-14 | 1 | -3/+2 |
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-14 | 2 | -0/+733 |
| | | | | | * libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h: New (Moved from c/src/libchip). | ||||
* | 2005-11-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-11-08 | 2 | -2/+6 |
| | | | | | | | | * libnetworking/net/if.h: Add forward reference declaration to struct mbuf so ifru_tap callback is properly typed. * libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE which needs to be defined so various pieces of the .h files are visible to device drives. | ||||
* | Eliminate obsolete types. | Ralf Corsepius | 2005-11-06 | 2 | -3/+3 |
* | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-03 | 3 | -0/+421 |
| | | | | | | | | | * libnetworking/Makefile.am, libnetworking/preinstall.am: Added simple implementation of ethernet media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys. * libnetworking/rtems/rtems_mii_ioctl.c, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c: New files. | ||||
* | 2005-11-02 Fredic Praca <freebsd-fr.org> | Joel Sherrill | 2005-11-02 | 1 | -7/+7 |
| | | | | | | PR 842/networking * libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename dprintf to debugprintf(). | ||||
* | 2005-11-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-02 | 2 | -6405/+0 |
| | | | | | | * libnetworking/net/zlib.c: Remove. * libnetworking/net/zlib.h: Remove. * libnetworking/Makefile.am: Reflect changes above. | ||||
* | Update from FreeBSD. | Ralf Corsepius | 2005-10-27 | 2 | -39/+58 |
* | Remove. | Ralf Corsepius | 2005-10-27 | 1 | -11/+0 |
* | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -21/+28 |
| | | | | * libnetworking/Makefile.am: Don't install loop.h. | ||||
* | New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+11 |
* | Don't sign-extend address components. | Eric Norum | 2005-10-25 | 1 | -2/+2 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -218/+11 |
| | | | | | * libnetworking/sys/mount.h: Cosmetical update from FreeBSD. Remove non-implemented interfaces (vfs, nfs, fsstat, etc.). | ||||
* | Cosmetics | Ralf Corsepius | 2005-09-16 | 1 | -8/+6 |
* | Update from FreeBSD | Ralf Corsepius | 2005-09-16 | 1 | -46/+15 |
* | Remove superfluous includes. | Ralf Corsepius | 2005-09-16 | 1 | -4/+1 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-09-16 | 2 | -29/+27 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-09-16 | 1 | -77/+60 |
* | 2005-08-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-06 | 1 | -2/+0 |
| | | | | | * libnetworking/nfs/bootp_subr.c: Don't include nfs/nfs.h, nfs/krpc.h. | ||||
* | Regenerate. | Ralf Corsepius | 2005-08-05 | 1 | -4/+4 |
* | 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-05 | 1 | -490/+33 |
| | | | | | * Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-08-01 | 1 | -16/+15 |
* | 2005-07-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-06 | 1 | -4/+1 |
| | | | | | | * libnetworking/lib/syslog.c: Fix spelling mistake. * libnetworking/sys/uio.h: Partial update from FreeBSD. * libnetworking/kern/kern_subr.c: Reflect changes above. | ||||
* | Fix spelling mistake. | Ralf Corsepius | 2005-07-06 | 1 | -1/+1 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-07-06 | 1 | -13/+20 |
* | The DHCP header. | Chris Johns | 2005-06-30 | 1 | -0/+47 |
* | DHCP server for RTEMS. | Chris Johns | 2005-06-30 | 1 | -0/+1133 |
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 1 | -1/+2 |
| | | | | | * libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended dependencies added by the RTEMS specific tap interface. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-27 | 1 | -2/+3 |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-27 | 2 | -14/+8 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 1 | -1/+1 |
| | | | | * librpc/include/rpc/clnt.h: Partial update from FreeBSD. | ||||
* | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-27 | 1 | -3/+3 |
| | | | | | | * libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings. | ||||
* | Regenerate. | Ralf Corsepius | 2005-05-24 | 1 | -4/+0 |
* | Remove (Unused, Non-POSIX/SUSV3). | Ralf Corsepius | 2005-05-24 | 1 | -342/+0 |
* | Reflect changes to libnetworking/arpa/nameser.h. | Ralf Corsepius | 2005-05-24 | 1 | -1/+1 |
* | Update from FreeBSD. | Ralf Corsepius | 2005-05-24 | 1 | -25/+30 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-24 | 1 | -10/+7 |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-24 | 1 | -9/+14 |
| | | | | | Add __packed. Partial update from FreeBSD. | ||||
* | Add "ICMP panic avoided" diagnostic counter. | Eric Norum | 2005-05-24 | 2 | -2/+7 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-21 | 2 | -57/+45 |
* | 2005-05-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-21 | 1 | -31/+45 |
| | | | | | * libnetworking/netinet/ip_icmp.h: Update from FreeBSD. Abandon BYTE_PACK. |
