* libnetworking/netinet/in_cksum.c: Joel should have used int32_t not
uint32_t when removing warnings.
* libnetworking/net/if_loop.c: Remove warning.
* libcsupport/src/malloc.c, libnetworking/rtems/rtems_glue.c,
libnetworking/sys/mbuf.h: Remove warnings -- use uintptr_t or
properly sized integers.
* ftpd/ftpd.c, libcsupport/include/sys/ioccom.h,
libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c,
libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h,
libnetworking/net/if.c, libnetworking/net/if_ethersubr.c,
libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c,
libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings
due to improper use of int which shows up on 16 bit targets. Added
ioctl_command_t since IOCTL command argument does not reliably fit
into 16 bits.
* libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c,
libnetworking/net/ethernet.h, libnetworking/net/if.h,
libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c,
libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c,
libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c,
libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c,
libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h,
libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove
warnings. Most of the warnings were 16/32 bit integer sizing issues.
Some constants had L appended, some had casts add, some types were
changed to reflect a bit width requirement.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
* libcsupport/src/utsname.c, libnetworking/libc/res_debug.c,
libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c,
librpc/src/rpc/svc_simple.c: Remove printf format warnings.
Return error for unknown/unsupported ioctl command.
(Change merged from freeBSD).
* libnetworking/kern/kern_sysctl.c: Change int to int32_t.
* libnetworking/net/if_loop.c: Add cast to long.
These plus a patch to machine/param.h let the h8300 build multilib.
fixed wrong calculation of 1000baseTx autonegotiation
result.
read ANER and include partner's autoneg
capability when determining active link parameters.
* libnetworking/machine/in_cksum.h: Replaced PPC and
i386 assembly algorithms (must not assume carry bit is preserved
across multiple asms). Added packet header as a 'm' input
operand for all CPU variants. Added carry bit to clobber list.
* libnetworking/net/if_var.h: #include <sys/queue.h>.
Cosmetics from FreeBSD.
Patch from Steven Johnson <sjohnson@sakuraindustries.com>
PR 949/networking
* libnetworking/sys/socket.h: GNU/Linux is wrong in making
MSG_DONTWAIT public. It is strictly BSD and not SUSV. See
http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html for clarification.
PR 949/networking
* libnetworking/sys/socket.h: Make MSG_DONTWAIT public as in GNU/Linux.
* libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting.
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h:
New (Moved from c/src/libchip).
* libnetworking/net/if.h: Add forward reference declaration to
struct mbuf so ifru_tap callback is properly typed.
* libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE
which needs to be defined so various pieces of the .h files are
visible to device drives.
* libnetworking/Makefile.am,
libnetworking/preinstall.am: Added simple implementation of ethernet
media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys.
* libnetworking/rtems/rtems_mii_ioctl.c,
libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c: New files.
PR 842/networking
* libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename
dprintf to debugprintf().
* libnetworking/net/zlib.c: Remove.
* libnetworking/net/zlib.h: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* libnetworking/Makefile.am: Don't install loop.h.
* libnetworking/sys/mount.h: Cosmetical update from FreeBSD.
Remove non-implemented interfaces (vfs, nfs, fsstat, etc.).
* libnetworking/nfs/bootp_subr.c: Don't include
nfs/nfs.h, nfs/krpc.h.
* Makefile.am: Add libnetworking/memory.h
* libnetworking/Makefile.am: Remove memory.h
* libnetworking/lib/syslog.c: Fix spelling mistake.
* libnetworking/sys/uio.h: Partial update from FreeBSD.
* libnetworking/kern/kern_subr.c: Reflect changes above.
