PR networking/772.
* rtems_select.c (socket_select): fixed bug setting SB_WAIT flag
of so_rcv instead of so_snd when FWRITE.
PR 749/networking
* rtems/rtems_showroute.c: Avoid NULL dereference.
PR 676/networking
* nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead of DNS
servers.
PR 626/networking
* rtems/rtems_showifstat.c: Use unsigned char to avoid printing leading
FFFFFF for byte values > 127.
PR pppd/564
* net/if_ppp.c, net/if_pppvar.h, net/ppp_tty.c: ppp0 Interface lose
packets if the system use a slow baudrate for the modem or the
tcp/ip-packet is fragmented.
PR 481/networking
* net/ethernet.h, net/if_arp.h, netinet/if_ether.h: Network structs
should be packed
PR 482/networking
* rtems/rtems_glue.c: Network interfaces cant be taken down
PR 482/networking
* rtems/mkrootfs.c, rtems/mkrootfs.h: URL for license changed.
PR 476/networking
* machine/in_cksum.h: Fix in_cksum calculation on SPARC.
PR 435/networking
* rtems/rtems_showifstat.c: rtems_showifstat misses printing
the netmask
* rtems/rtems_syscall.c: Removed warnings.
* netinet/in.h:
PR406 - Added INET_ADDRSTRLEN per the SUSv3 standard.
PR 388/networking
* kern/kern_sysctl.c: Revert previous patch and use strlcpy() now that
it is available. Also fixed some warnings.
* kern/kern_sysctl.c: Converted from BSP strlcpy() to strncpy().
* rtems/rtems_bsdnet_malloc_starvation.c: Fixed name of include file.
PR 374/networking
* Makefile.am, rtems/rtems_bsdnet.h, rtems/rtems_glue.c:
The patch sent as part of PR270 got applied to the wrong place.
The effect was that (1) startup was no faster than before and
(2) malloc starvation messages came way too quickly. The attached
patch fixes both these problems and also provides a mechanism for
applications to handle malloc starvation conditions as they see fit.
* rtems/rtems_bsdnet_malloc_starvation.c: New file.
PR 356/bsps
* sys/linker_set.h: This patch makes RTEMS/PowerPC eabi compliant.
Declare all linker-script defined addresses as
variables of unknown size and not as short objects
like 'int', 'void*' etc. Since only addresses are used and never those
variable's values, the type used in a declaration is not important.
* configure.ac: Remove AC_CONFIG_AUX_DIR.
* netinet/in_chksum.c: Remove duplicate case to include
in_chksum_arm.c.
PR 351/networking
* nfs/bootp_subr.c: Fix ridiculous leak in bootp and use
strdup_bootp_realloc() everywhere for sake of consistency.
Sprout from master 2003-02-11 23:44:41 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2003-02-11 Joel Sherrill <joel@OARcorp.com>'
Cherrypick from rtemsdoc-4-5-branch 1997-05-27 12:40:10 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base RTEMS documentation':
doc/common/treedef.tex
Delete:
bootstrap
c/src/ada/.cvsignore
c/src/ada/ChangeLog
c/src/ada/Makefile.am
c/src/ada/rtems-multiprocessing.adb
c/src/ada/rtems-multiprocessing.ads
c/src/ada/rtems.adb
c/src/ada/rtems.ads
c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog
c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog
c/src/lib/libcpu/powerpc/old-exceptions/README
c/src/lib/libcpu/powerpc/old-exceptions/TODO
c/src/lib/libcpu/powerpc/old-exceptions/cpu.c
c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S
c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S
c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c
c/src/lib/libcpu/powerpc/old-exceptions/rtems/score/ppc_offs.h
c/src/libchip/shmdr/.cvsignore
c/src/libchip/shmdr/README
c/src/libchip/shmdr/addlq.c
c/src/libchip/shmdr/cnvpkt.c
c/src/libchip/shmdr/dump.c
c/src/libchip/shmdr/fatal.c
c/src/libchip/shmdr/getlq.c
c/src/libchip/shmdr/getpkt.c
c/src/libchip/shmdr/init.c
c/src/libchip/shmdr/initlq.c
c/src/libchip/shmdr/intr.c
c/src/libchip/shmdr/mpci.h
c/src/libchip/shmdr/mpisr.c
c/src/libchip/shmdr/poll.c
c/src/libchip/shmdr/receive.c
c/src/libchip/shmdr/retpkt.c
c/src/libchip/shmdr/send.c
c/src/libchip/shmdr/setckvec.c
c/src/libchip/shmdr/shm_driver.h
cpukit/ftpd/Makefile.am
cpukit/ftpd/ftpd.c
cpukit/ftpd/ftpd.h
cpukit/httpd/.cvsignore
cpukit/httpd/Makefile.am
cpukit/httpd/NOTES
cpukit/httpd/asp.c
cpukit/httpd/balloc.c
cpukit/httpd/default.c
cpukit/httpd/ej.h
cpukit/httpd/ejIntrn.h
cpukit/httpd/ejlex.c
cpukit/httpd/ejparse.c
cpukit/httpd/emfdb.c
cpukit/httpd/emfdb.h
cpukit/httpd/form.c
cpukit/httpd/h.c
cpukit/httpd/handler.c
cpukit/httpd/license.txt
cpukit/httpd/md5.h
cpukit/httpd/md5c.c
cpukit/httpd/mime.c
cpukit/httpd/misc.c
cpukit/httpd/ringq.c
cpukit/httpd/rom.c
cpukit/httpd/rtems_webserver.h
cpukit/httpd/security.c
cpukit/httpd/sock.c
cpukit/httpd/socket.c
cpukit/httpd/sym.c
cpukit/httpd/uemf.c
cpukit/httpd/uemf.h
cpukit/httpd/um.c
cpukit/httpd/um.h
cpukit/httpd/url.c
cpukit/httpd/value.c
cpukit/httpd/wbase64.c
cpukit/httpd/webcomp.c
cpukit/httpd/webmain.c
cpukit/httpd/webpage.c
cpukit/httpd/webrom.c
cpukit/httpd/webs.c
cpukit/httpd/webs.h
cpukit/httpd/websuemf.c
cpukit/httpd/wsIntrn.h
cpukit/libnetworking/netinet/in_cksum_arm.h
cpukit/libnetworking/netinet/in_cksum_i386.h
cpukit/libnetworking/netinet/in_cksum_m68k.h
cpukit/libnetworking/netinet/in_cksum_powerpc.h
cpukit/pppd/Makefile.am
cpukit/pppd/README
cpukit/pppd/STATUS
cpukit/pppd/auth.c
cpukit/pppd/cbcp.c
cpukit/pppd/cbcp.h
cpukit/pppd/ccp.c
cpukit/pppd/ccp.h
cpukit/pppd/chap.c
cpukit/pppd/chap.h
cpukit/pppd/chap_ms.c
cpukit/pppd/chap_ms.h
cpukit/pppd/chat.c
cpukit/pppd/demand.c
cpukit/pppd/example/Makefile-user
cpukit/pppd/example/README
cpukit/pppd/example/init.c
cpukit/pppd/example/netconfig.h
cpukit/pppd/example/ppp.conf
cpukit/pppd/example/pppd.options
cpukit/pppd/example/pppdapp.c
cpukit/pppd/example/system.h
cpukit/pppd/fsm.c
cpukit/pppd/fsm.h
cpukit/pppd/ipcp.c
cpukit/pppd/ipcp.h
cpukit/pppd/ipxcp.c
cpukit/pppd/ipxcp.h
cpukit/pppd/lcp.c
cpukit/pppd/lcp.h
cpukit/pppd/magic.c
cpukit/pppd/magic.h
cpukit/pppd/md4.c
cpukit/pppd/md4.h
cpukit/pppd/md5.c
cpukit/pppd/md5.h
cpukit/pppd/options.c
cpukit/pppd/patchlevel.h
cpukit/pppd/pathnames.h
cpukit/pppd/pppd.8
cpukit/pppd/pppd.h
cpukit/pppd/rtemsdialer.h
cpukit/pppd/rtemsmain.c
cpukit/pppd/rtemspppd.c
cpukit/pppd/rtemspppd.h
cpukit/pppd/sys-rtems.c
cpukit/pppd/upap.c
cpukit/pppd/upap.h
cpukit/pppd/utils.c
cpukit/rtems/src/clocktodtoseconds.c
cpukit/rtems/src/clocktodvalidate.c
cpukit/score/cpu/arm/rtems/asm.h
cpukit/score/cpu/c4x/rtems/asm.h
cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h
cpukit/score/cpu/h8300/rtems/asm.h
cpukit/score/cpu/i386/rtems/asm.h
cpukit/score/cpu/m68k/rtems/asm.h
cpukit/score/cpu/m68k/rtems/m68k/m68302.h
cpukit/score/cpu/m68k/rtems/m68k/m68360.h
cpukit/score/cpu/m68k/rtems/m68k/qsm.h
cpukit/score/cpu/m68k/rtems/m68k/sim.h
cpukit/score/cpu/mips/rtems/asm.h
cpukit/score/cpu/mips/rtems/mips/idtcpu.h
cpukit/score/cpu/mips/rtems/mips/iregdef.h
cpukit/score/cpu/no_cpu/rtems/asm.h
cpukit/score/cpu/or32/rtems/asm.h
cpukit/score/cpu/powerpc/rtems/asm.h
cpukit/score/cpu/sh/rtems/asm.h
cpukit/score/cpu/sparc/rtems/asm.h
cpukit/telnetd/Makefile.am
cpukit/telnetd/README
cpukit/telnetd/icmds.c
cpukit/telnetd/pty.c
cpukit/telnetd/pty.h
cpukit/telnetd/telnetd.c
cpukit/telnetd/telnetd.h
cpukit/zlib/doc/rfc1950.txt
cpukit/zlib/doc/rfc1951.txt
cpukit/zlib/doc/rfc1952.txt
testsuites/.cvsignore
testsuites/ChangeLog
testsuites/Makefile.am
testsuites/PROBLEMS
testsuites/README
testsuites/configure.ac
testsuites/itrontests/.cvsignore
testsuites/itrontests/ChangeLog
testsuites/itrontests/Makefile.am
testsuites/itrontests/README
testsuites/itrontests/configure.ac
testsuites/itrontests/itronhello/.cvsignore
testsuites/itrontests/itronhello/Makefile.am
testsuites/itrontests/itronhello/init.c
testsuites/itrontests/itronhello/itronhello.doc
testsuites/itrontests/itronhello/itronhello.scn
testsuites/itrontests/itronhello/system.h
testsuites/itrontests/itronmbf01/.cvsignore
testsuites/itrontests/itronmbf01/Makefile.am
testsuites/itrontests/itronmbf01/init.c
testsuites/itrontests/itronmbf01/itronmbf01.doc
testsuites/itrontests/itronmbf01/itronmbf01.scn
testsuites/itrontests/itronmbf01/system.h
testsuites/itrontests/itronmbox01/.cvsignore
testsuites/itrontests/itronmbox01/Makefile.am
testsuites/itrontests/itronmbox01/init.c
testsuites/itrontests/itronmbox01/itronmbox01.doc
testsuites/itrontests/itronmbox01/itronmbox01.scn
testsuites/itrontests/itronmbox01/system.h
testsuites/itrontests/itronsem01/.cvsignore
testsuites/itrontests/itronsem01/Makefile.am
testsuites/itrontests/itronsem01/init.c
testsuites/itrontests/itronsem01/itronsem01.doc
testsuites/itrontests/itronsem01/itronsem01.scn
testsuites/itrontests/itronsem01/system.h
testsuites/itrontests/itrontask01/.cvsignore
testsuites/itrontests/itrontask01/Makefile.am
testsuites/itrontests/itrontask01/init.c
testsuites/itrontests/itrontask01/itrontask01.doc
testsuites/itrontests/itrontask01/itrontask01.scn
testsuites/itrontests/itrontask01/system.h
testsuites/itrontests/itrontask01/task1.c
testsuites/itrontests/itrontask02/.cvsignore
testsuites/itrontests/itrontask02/Makefile.am
testsuites/itrontests/itrontask02/dormant.c
testsuites/itrontests/itrontask02/init.c
testsuites/itrontests/itrontask02/itrontask02.doc
testsuites/itrontests/itrontask02/itrontask02.scn
testsuites/itrontests/itrontask02/system.h
testsuites/itrontests/itrontask03/.cvsignore
testsuites/itrontests/itrontask03/Makefile.am
testsuites/itrontests/itrontask03/init.c
testsuites/itrontests/itrontask03/itrontask03.doc
testsuites/itrontests/itrontask03/itrontask03.scn
testsuites/itrontests/itrontask03/preempt.c
testsuites/itrontests/itrontask03/system.h
testsuites/itrontests/itrontask03/task1.c
testsuites/itrontests/itrontask03/task2.c
testsuites/itrontests/itrontask03/task3.c
testsuites/itrontests/itrontask04/.cvsignore
testsuites/itrontests/itrontask04/Makefile.am
testsuites/itrontests/itrontask04/init.c
testsuites/itrontests/itrontask04/itrontask04.doc
testsuites/itrontests/itrontask04/itrontask04.scn
testsuites/itrontests/itrontask04/system.h
testsuites/itrontests/itrontask04/task1.c
testsuites/itrontests/itrontask04/task2.c
testsuites/itrontests/itrontask04/task3.c
testsuites/itrontests/itrontests.am
testsuites/itrontests/itrontime01/.cvsignore
testsuites/itrontests/itrontime01/Makefile.am
testsuites/itrontests/itrontime01/init.c
testsuites/itrontests/itrontime01/itrontime01.doc
testsuites/itrontests/itrontime01/itrontime01.scn
testsuites/itrontests/itrontime01/system.h
testsuites/libtests/.cvsignore
testsuites/libtests/ChangeLog
testsuites/libtests/Makefile.am
testsuites/libtests/README
testsuites/libtests/configure.ac
testsuites/libtests/cpuuse/.cvsignore
testsuites/libtests/cpuuse/Makefile.am
testsuites/libtests/cpuuse/cpuuse.scn
testsuites/libtests/cpuuse/init.c
testsuites/libtests/cpuuse/system.h
testsuites/libtests/cpuuse/task1.c
testsuites/libtests/cpuuse/task2.c
testsuites/libtests/cpuuse/task3.c
testsuites/libtests/cpuuse/tswitch.c
testsuites/libtests/libtests.am
testsuites/libtests/malloctest/.cvsignore
testsuites/libtests/malloctest/Makefile.am
testsuites/libtests/malloctest/init.c
testsuites/libtests/malloctest/malloctest.scn
testsuites/libtests/malloctest/system.h
testsuites/libtests/malloctest/task1.c
testsuites/libtests/monitor/.cvsignore
testsuites/libtests/monitor/Makefile.am
testsuites/libtests/monitor/init.c
testsuites/libtests/monitor/system.h
testsuites/libtests/putenvtest/.cvsignore
testsuites/libtests/putenvtest/Makefile.am
testsuites/libtests/putenvtest/init.c
testsuites/libtests/rtems++/.cvsignore
testsuites/libtests/rtems++/Init.cc
testsuites/libtests/rtems++/Makefile.am
testsuites/libtests/rtems++/System.h
testsuites/libtests/rtems++/Task1.cc
testsuites/libtests/rtems++/Task2.cc
testsuites/libtests/rtems++/Task3.cc
testsuites/libtests/rtems++/rtems++.doc
testsuites/libtests/rtems++/rtems++.scn
testsuites/libtests/rtmonuse/.cvsignore
testsuites/libtests/rtmonuse/Makefile.am
testsuites/libtests/rtmonuse/getall.c
testsuites/libtests/rtmonuse/init.c
testsuites/libtests/rtmonuse/rtmonuse.scn
testsuites/libtests/rtmonuse/system.h
testsuites/libtests/rtmonuse/task1.c
testsuites/libtests/stackchk/.cvsignore
testsuites/libtests/stackchk/Makefile.am
testsuites/libtests/stackchk/blow.c
testsuites/libtests/stackchk/init.c
testsuites/libtests/stackchk/stackchk.scn
testsuites/libtests/stackchk/system.h
testsuites/libtests/stackchk/task1.c
testsuites/libtests/termios/.cvsignore
testsuites/libtests/termios/Makefile.am
testsuites/libtests/termios/README
testsuites/libtests/termios/init.c
testsuites/mptests/.cvsignore
testsuites/mptests/ChangeLog
testsuites/mptests/Makefile.am
testsuites/mptests/README
testsuites/mptests/configure.ac
testsuites/mptests/mp01/.cvsignore
testsuites/mptests/mp01/Makefile.am
testsuites/mptests/mp01/init.c
testsuites/mptests/mp01/node1/.cvsignore
testsuites/mptests/mp01/node1/Makefile.am
testsuites/mptests/mp01/node1/mp01.doc
testsuites/mptests/mp01/node1/mp01.scn
testsuites/mptests/mp01/node2/.cvsignore
testsuites/mptests/mp01/node2/Makefile.am
testsuites/mptests/mp01/node2/mp01.doc
testsuites/mptests/mp01/node2/mp01.scn
testsuites/mptests/mp01/system.h
testsuites/mptests/mp01/task1.c
testsuites/mptests/mp02/.cvsignore
testsuites/mptests/mp02/Makefile.am
testsuites/mptests/mp02/init.c
testsuites/mptests/mp02/node1/.cvsignore
testsuites/mptests/mp02/node1/Makefile.am
testsuites/mptests/mp02/node1/mp02.doc
testsuites/mptests/mp02/node1/mp02.scn
testsuites/mptests/mp02/node2/.cvsignore
testsuites/mptests/mp02/node2/Makefile.am
testsuites/mptests/mp02/node2/mp02.doc
testsuites/mptests/mp02/node2/mp02.scn
testsuites/mptests/mp02/system.h
testsuites/mptests/mp02/task1.c
testsuites/mptests/mp03/.cvsignore
testsuites/mptests/mp03/Makefile.am
testsuites/mptests/mp03/delay.c
testsuites/mptests/mp03/init.c
testsuites/mptests/mp03/node1/.cvsignore
testsuites/mptests/mp03/node1/Makefile.am
testsuites/mptests/mp03/node1/mp03.doc
testsuites/mptests/mp03/node1/mp03.scn
testsuites/mptests/mp03/node2/.cvsignore
testsuites/mptests/mp03/node2/Makefile.am
testsuites/mptests/mp03/node2/mp03.doc
testsuites/mptests/mp03/node2/mp03.scn
testsuites/mptests/mp03/system.h
testsuites/mptests/mp03/task1.c
testsuites/mptests/mp04/.cvsignore
testsuites/mptests/mp04/Makefile.am
testsuites/mptests/mp04/init.c
testsuites/mptests/mp04/node1/.cvsignore
testsuites/mptests/mp04/node1/Makefile.am
testsuites/mptests/mp04/node1/mp04.doc
testsuites/mptests/mp04/node1/mp04.scn
testsuites/mptests/mp04/node2/.cvsignore
testsuites/mptests/mp04/node2/Makefile.am
testsuites/mptests/mp04/node2/mp04.doc
testsuites/mptests/mp04/node2/mp04.scn
testsuites/mptests/mp04/system.h
testsuites/mptests/mp04/task1.c
testsuites/mptests/mp05/.cvsignore
testsuites/mptests/mp05/Makefile.am
testsuites/mptests/mp05/asr.c
testsuites/mptests/mp05/init.c
testsuites/mptests/mp05/node1/.cvsignore
testsuites/mptests/mp05/node1/Makefile.am
testsuites/mptests/mp05/node1/mp05.doc
testsuites/mptests/mp05/node1/mp05.scn
testsuites/mptests/mp05/node2/.cvsignore
testsuites/mptests/mp05/node2/Makefile.am
testsuites/mptests/mp05/node2/mp05.doc
testsuites/mptests/mp05/node2/mp05.scn
testsuites/mptests/mp05/system.h
testsuites/mptests/mp05/task1.c
testsuites/mptests/mp06/.cvsignore
testsuites/mptests/mp06/Makefile.am
testsuites/mptests/mp06/init.c
testsuites/mptests/mp06/node1/.cvsignore
testsuites/mptests/mp06/node1/Makefile.am
testsuites/mptests/mp06/node1/mp06.doc
testsuites/mptests/mp06/node1/mp06.scn
testsuites/mptests/mp06/node2/.cvsignore
testsuites/mptests/mp06/node2/Makefile.am
testsuites/mptests/mp06/node2/mp06.doc
testsuites/mptests/mp06/node2/mp06.scn
testsuites/mptests/mp06/system.h
testsuites/mptests/mp06/task1.c
testsuites/mptests/mp07/.cvsignore
testsuites/mptests/mp07/Makefile.am
testsuites/mptests/mp07/init.c
testsuites/mptests/mp07/node1/.cvsignore
testsuites/mptests/mp07/node1/Makefile.am
testsuites/mptests/mp07/node1/mp07.doc
testsuites/mptests/mp07/node1/mp07.scn
testsuites/mptests/mp07/node2/.cvsignore
testsuites/mptests/mp07/node2/Makefile.am
testsuites/mptests/mp07/node2/mp07.doc
testsuites/mptests/mp07/node2/mp07.scn
testsuites/mptests/mp07/system.h
testsuites/mptests/mp07/task1.c
testsuites/mptests/mp08/.cvsignore
testsuites/mptests/mp08/Makefile.am
testsuites/mptests/mp08/init.c
testsuites/mptests/mp08/node1/.cvsignore
testsuites/mptests/mp08/node1/Makefile.am
testsuites/mptests/mp08/node1/mp08.doc
testsuites/mptests/mp08/node1/mp08.scn
testsuites/mptests/mp08/node2/.cvsignore
testsuites/mptests/mp08/node2/Makefile.am
testsuites/mptests/mp08/node2/mp08.doc
testsuites/mptests/mp08/node2/mp08.scn
testsuites/mptests/mp08/system.h
testsuites/mptests/mp08/task1.c
testsuites/mptests/mp09/.cvsignore
testsuites/mptests/mp09/Makefile.am
testsuites/mptests/mp09/init.c
testsuites/mptests/mp09/node1/.cvsignore
testsuites/mptests/mp09/node1/Makefile.am
testsuites/mptests/mp09/node1/mp09.doc
testsuites/mptests/mp09/node1/mp09.scn
testsuites/mptests/mp09/node2/.cvsignore
testsuites/mptests/mp09/node2/Makefile.am
testsuites/mptests/mp09/node2/mp09.doc
testsuites/mptests/mp09/node2/mp09.scn
testsuites/mptests/mp09/recvmsg.c
testsuites/mptests/mp09/sendmsg.c
testsuites/mptests/mp09/system.h
testsuites/mptests/mp09/task1.c
testsuites/mptests/mp10/.cvsignore
testsuites/mptests/mp10/Makefile.am
testsuites/mptests/mp10/init.c
testsuites/mptests/mp10/node1/.cvsignore
testsuites/mptests/mp10/node1/Makefile.am
testsuites/mptests/mp10/node1/mp10.doc
testsuites/mptests/mp10/node1/mp10.scn
testsuites/mptests/mp10/node2/.cvsignore
testsuites/mptests/mp10/node2/Makefile.am
testsuites/mptests/mp10/node2/mp10.doc
testsuites/mptests/mp10/node2/mp10.scn
testsuites/mptests/mp10/system.h
testsuites/mptests/mp10/task1.c
testsuites/mptests/mp10/task2.c
testsuites/mptests/mp10/task3.c
testsuites/mptests/mp11/.cvsignore
testsuites/mptests/mp11/Makefile.am
testsuites/mptests/mp11/init.c
testsuites/mptests/mp11/node1/.cvsignore
testsuites/mptests/mp11/node1/Makefile.am
testsuites/mptests/mp11/node1/mp11.doc
testsuites/mptests/mp11/node1/mp11.scn
testsuites/mptests/mp11/node2/.cvsignore
testsuites/mptests/mp11/node2/Makefile.am
testsuites/mptests/mp11/node2/mp11.doc
testsuites/mptests/mp11/node2/mp11.scn
testsuites/mptests/mp11/system.h
testsuites/mptests/mp12/.cvsignore
testsuites/mptests/mp12/Makefile.am
testsuites/mptests/mp12/init.c
testsuites/mptests/mp12/node1/.cvsignore
testsuites/mptests/mp12/node1/Makefile.am
testsuites/mptests/mp12/node1/mp12.doc
testsuites/mptests/mp12/node1/mp12.scn
testsuites/mptests/mp12/node2/.cvsignore
testsuites/mptests/mp12/node2/Makefile.am
testsuites/mptests/mp12/node2/mp12.doc
testsuites/mptests/mp12/node2/mp12.scn
testsuites/mptests/mp12/system.h
testsuites/mptests/mp13/.cvsignore
testsuites/mptests/mp13/Makefile.am
testsuites/mptests/mp13/init.c
testsuites/mptests/mp13/node1/.cvsignore
testsuites/mptests/mp13/node1/Makefile.am
testsuites/mptests/mp13/node1/mp13.doc
testsuites/mptests/mp13/node1/mp13.scn
testsuites/mptests/mp13/node2/.cvsignore
testsuites/mptests/mp13/node2/Makefile.am
testsuites/mptests/mp13/node2/mp13.doc
testsuites/mptests/mp13/node2/mp13.scn
testsuites/mptests/mp13/system.h
testsuites/mptests/mp13/task1.c
testsuites/mptests/mp13/task2.c
testsuites/mptests/mp14/.cvsignore
testsuites/mptests/mp14/Makefile.am
testsuites/mptests/mp14/delay.c
testsuites/mptests/mp14/evtask1.c
testsuites/mptests/mp14/evtmtask.c
testsuites/mptests/mp14/exit.c
testsuites/mptests/mp14/init.c
testsuites/mptests/mp14/msgtask1.c
testsuites/mptests/mp14/node1/.cvsignore
testsuites/mptests/mp14/node1/Makefile.am
testsuites/mptests/mp14/node1/mp14.doc
testsuites/mptests/mp14/node1/mp14.scn
testsuites/mptests/mp14/node2/.cvsignore
testsuites/mptests/mp14/node2/Makefile.am
testsuites/mptests/mp14/node2/mp14.doc
testsuites/mptests/mp14/node2/mp14.scn
testsuites/mptests/mp14/pttask1.c
testsuites/mptests/mp14/smtask1.c
testsuites/mptests/mp14/system.h
testsuites/mptests/mptests.am
testsuites/psxtests/.cvsignore
testsuites/psxtests/ChangeLog
testsuites/psxtests/Makefile.am
testsuites/psxtests/configure.ac
testsuites/psxtests/include/.cvsignore
testsuites/psxtests/include/Makefile.am
testsuites/psxtests/include/pmacros.h
testsuites/psxtests/psx01/.cvsignore
testsuites/psxtests/psx01/Makefile.am
testsuites/psxtests/psx01/init.c
testsuites/psxtests/psx01/psx01.scn
testsuites/psxtests/psx01/system.h
testsuites/psxtests/psx01/task.c
testsuites/psxtests/psx02/.cvsignore
testsuites/psxtests/psx02/Makefile.am
testsuites/psxtests/psx02/init.c
testsuites/psxtests/psx02/psx02.scn
testsuites/psxtests/psx02/system.h
testsuites/psxtests/psx02/task.c
testsuites/psxtests/psx03/.cvsignore
testsuites/psxtests/psx03/Makefile.am
testsuites/psxtests/psx03/init.c
testsuites/psxtests/psx03/psx03.scn
testsuites/psxtests/psx03/system.h
testsuites/psxtests/psx03/task.c
testsuites/psxtests/psx04/.cvsignore
testsuites/psxtests/psx04/Makefile.am
testsuites/psxtests/psx04/init.c
testsuites/psxtests/psx04/psx04.scn
testsuites/psxtests/psx04/system.h
testsuites/psxtests/psx04/task1.c
testsuites/psxtests/psx04/task2.c
testsuites/psxtests/psx04/task3.c
testsuites/psxtests/psx05/.cvsignore
testsuites/psxtests/psx05/Makefile.am
testsuites/psxtests/psx05/init.c
testsuites/psxtests/psx05/psx05.scn
testsuites/psxtests/psx05/system.h
testsuites/psxtests/psx05/task.c
testsuites/psxtests/psx05/task2.c
testsuites/psxtests/psx05/task3.c
testsuites/psxtests/psx06/.cvsignore
testsuites/psxtests/psx06/Makefile.am
testsuites/psxtests/psx06/init.c
testsuites/psxtests/psx06/psx06.scn
testsuites/psxtests/psx06/system.h
testsuites/psxtests/psx06/task.c
testsuites/psxtests/psx06/task2.c
testsuites/psxtests/psx07/.cvsignore
testsuites/psxtests/psx07/Makefile.am
testsuites/psxtests/psx07/init.c
testsuites/psxtests/psx07/psx07.scn
testsuites/psxtests/psx07/system.h
testsuites/psxtests/psx07/task.c
testsuites/psxtests/psx08/.cvsignore
testsuites/psxtests/psx08/Makefile.am
testsuites/psxtests/psx08/init.c
testsuites/psxtests/psx08/psx08.scn
testsuites/psxtests/psx08/system.h
testsuites/psxtests/psx08/task1.c
testsuites/psxtests/psx08/task2.c
testsuites/psxtests/psx08/task3.c
testsuites/psxtests/psx09/.cvsignore
testsuites/psxtests/psx09/Makefile.am
testsuites/psxtests/psx09/init.c
testsuites/psxtests/psx09/psx09.scn
testsuites/psxtests/psx09/system.h
testsuites/psxtests/psx10/.cvsignore
testsuites/psxtests/psx10/Makefile.am
testsuites/psxtests/psx10/init.c
testsuites/psxtests/psx10/psx10.scn
testsuites/psxtests/psx10/system.h
testsuites/psxtests/psx10/task.c
testsuites/psxtests/psx10/task2.c
testsuites/psxtests/psx10/task3.c
testsuites/psxtests/psx11/.cvsignore
testsuites/psxtests/psx11/Makefile.am
testsuites/psxtests/psx11/init.c
testsuites/psxtests/psx11/psx11.scn
testsuites/psxtests/psx11/system.h
testsuites/psxtests/psx11/task.c
testsuites/psxtests/psx12/.cvsignore
testsuites/psxtests/psx12/Makefile.am
testsuites/psxtests/psx12/init.c
testsuites/psxtests/psx12/psx12.scn
testsuites/psxtests/psx12/system.h
testsuites/psxtests/psx12/task.c
testsuites/psxtests/psx13/.cvsignore
testsuites/psxtests/psx13/Makefile.am
testsuites/psxtests/psx13/main.c
testsuites/psxtests/psx13/psx13.scn
testsuites/psxtests/psx13/test.c
testsuites/psxtests/psxcancel/.cvsignore
testsuites/psxtests/psxcancel/Makefile.am
testsuites/psxtests/psxcancel/init.c
testsuites/psxtests/psxcancel/psxcancel.scn
testsuites/psxtests/psxchroot01/.cvsignore
testsuites/psxtests/psxchroot01/Makefile.am
testsuites/psxtests/psxchroot01/main.c
testsuites/psxtests/psxchroot01/psxchroot01.scn
testsuites/psxtests/psxchroot01/test.c
testsuites/psxtests/psxfile01/.cvsignore
testsuites/psxtests/psxfile01/Makefile.am
testsuites/psxtests/psxfile01/main.c
testsuites/psxtests/psxfile01/psxfile01.scn
testsuites/psxtests/psxfile01/test.c
testsuites/psxtests/psxfile01/test_cat.c
testsuites/psxtests/psxfile01/test_extend.c
testsuites/psxtests/psxfile01/test_write.c
testsuites/psxtests/psxhdrs/.cvsignore
testsuites/psxtests/psxhdrs/Makefile.am
testsuites/psxtests/psxhdrs/clock01.c
testsuites/psxtests/psxhdrs/clock02.c
testsuites/psxtests/psxhdrs/clock03.c
testsuites/psxtests/psxhdrs/clock04.c
testsuites/psxtests/psxhdrs/clock05.c
testsuites/psxtests/psxhdrs/clock06.c
testsuites/psxtests/psxhdrs/cond01.c
testsuites/psxtests/psxhdrs/cond02.c
testsuites/psxtests/psxhdrs/cond03.c
testsuites/psxtests/psxhdrs/cond04.c
testsuites/psxtests/psxhdrs/cond05.c
testsuites/psxtests/psxhdrs/cond06.c
testsuites/psxtests/psxhdrs/cond07.c
testsuites/psxtests/psxhdrs/cond08.c
testsuites/psxtests/psxhdrs/cond09.c
testsuites/psxtests/psxhdrs/cond10.c
testsuites/psxtests/psxhdrs/key01.c
testsuites/psxtests/psxhdrs/key02.c
testsuites/psxtests/psxhdrs/key03.c
testsuites/psxtests/psxhdrs/key04.c
testsuites/psxtests/psxhdrs/mutex01.c
testsuites/psxtests/psxhdrs/mutex02.c
testsuites/psxtests/psxhdrs/mutex03.c
testsuites/psxtests/psxhdrs/mutex04.c
testsuites/psxtests/psxhdrs/mutex05.c
testsuites/psxtests/psxhdrs/mutex06.c
testsuites/psxtests/psxhdrs/mutex07.c
testsuites/psxtests/psxhdrs/mutex08.c
testsuites/psxtests/psxhdrs/mutex09.c
testsuites/psxtests/psxhdrs/mutex10.c
testsuites/psxtests/psxhdrs/mutex11.c
testsuites/psxtests/psxhdrs/mutex12.c
testsuites/psxtests/psxhdrs/mutex13.c
testsuites/psxtests/psxhdrs/mutex14.c
testsuites/psxtests/psxhdrs/mutex15.c
testsuites/psxtests/psxhdrs/mutex16.c
testsuites/psxtests/psxhdrs/proc01.c
testsuites/psxtests/psxhdrs/proc02.c
testsuites/psxtests/psxhdrs/proc03.c
testsuites/psxtests/psxhdrs/proc04.c
testsuites/psxtests/psxhdrs/proc05.c
testsuites/psxtests/psxhdrs/proc06.c
testsuites/psxtests/psxhdrs/proc07.c
testsuites/psxtests/psxhdrs/proc08.c
testsuites/psxtests/psxhdrs/proc09.c
testsuites/psxtests/psxhdrs/proc10.c
testsuites/psxtests/psxhdrs/proc11.c
testsuites/psxtests/psxhdrs/proc12.c
testsuites/psxtests/psxhdrs/proc13.c
testsuites/psxtests/psxhdrs/proc14.c
testsuites/psxtests/psxhdrs/pthread01.c
testsuites/psxtests/psxhdrs/pthread02.c
testsuites/psxtests/psxhdrs/pthread03.c
testsuites/psxtests/psxhdrs/pthread04.c
testsuites/psxtests/psxhdrs/pthread05.c
testsuites/psxtests/psxhdrs/pthread06.c
testsuites/psxtests/psxhdrs/pthread07.c
testsuites/psxtests/psxhdrs/pthread08.c
testsuites/psxtests/psxhdrs/pthread09.c
testsuites/psxtests/psxhdrs/pthread10.c
testsuites/psxtests/psxhdrs/pthread11.c
testsuites/psxtests/psxhdrs/pthread12.c
testsuites/psxtests/psxhdrs/pthread13.c
testsuites/psxtests/psxhdrs/pthread14.c
testsuites/psxtests/psxhdrs/pthread15.c
testsuites/psxtests/psxhdrs/pthread16.c
testsuites/psxtests/psxhdrs/pthread17.c
testsuites/psxtests/psxhdrs/pthread18.c
testsuites/psxtests/psxhdrs/pthread19.c
testsuites/psxtests/psxhdrs/pthread20.c
testsuites/psxtests/psxhdrs/pthread21.c
testsuites/psxtests/psxhdrs/pthread22.c
testsuites/psxtests/psxhdrs/pthread23.c
testsuites/psxtests/psxhdrs/pthread24.c
testsuites/psxtests/psxhdrs/pthread25.c
testsuites/psxtests/psxhdrs/pthread26.c
testsuites/psxtests/psxhdrs/pthread27.c
testsuites/psxtests/psxhdrs/pthread28.c
testsuites/psxtests/psxhdrs/pthread29.c
testsuites/psxtests/psxhdrs/pthread30.c
testsuites/psxtests/psxhdrs/pthread31.c
testsuites/psxtests/psxhdrs/pthread32.c
testsuites/psxtests/psxhdrs/pthread33.c
testsuites/psxtests/psxhdrs/pthread34.c
testsuites/psxtests/psxhdrs/pthread35.c
testsuites/psxtests/psxhdrs/pthread36.c
testsuites/psxtests/psxhdrs/sched01.c
testsuites/psxtests/psxhdrs/sched02.c
testsuites/psxtests/psxhdrs/sched03.c
testsuites/psxtests/psxhdrs/sched04.c
testsuites/psxtests/psxhdrs/sched05.c
testsuites/psxtests/psxhdrs/sched06.c
testsuites/psxtests/psxhdrs/sched07.c
testsuites/psxtests/psxhdrs/sched08.c
testsuites/psxtests/psxhdrs/signal01.c
testsuites/psxtests/psxhdrs/signal02.c
testsuites/psxtests/psxhdrs/signal03.c
testsuites/psxtests/psxhdrs/signal04.c
testsuites/psxtests/psxhdrs/signal05.c
testsuites/psxtests/psxhdrs/signal06.c
testsuites/psxtests/psxhdrs/signal07.c
testsuites/psxtests/psxhdrs/signal08.c
testsuites/psxtests/psxhdrs/signal09.c
testsuites/psxtests/psxhdrs/signal10.c
testsuites/psxtests/psxhdrs/signal11.c
testsuites/psxtests/psxhdrs/signal12.c
testsuites/psxtests/psxhdrs/signal13.c
testsuites/psxtests/psxhdrs/signal14.c
testsuites/psxtests/psxhdrs/signal15.c
testsuites/psxtests/psxhdrs/signal16.c
testsuites/psxtests/psxhdrs/signal17.c
testsuites/psxtests/psxhdrs/signal18.c
testsuites/psxtests/psxhdrs/signal19.c
testsuites/psxtests/psxhdrs/signal20.c
testsuites/psxtests/psxhdrs/signal21.c
testsuites/psxtests/psxhdrs/signal22.c
testsuites/psxtests/psxhdrs/time01.c
testsuites/psxtests/psxhdrs/time02.c
testsuites/psxtests/psxhdrs/time03.c
testsuites/psxtests/psxhdrs/time04.c
testsuites/psxtests/psxhdrs/time05.c
testsuites/psxtests/psxhdrs/time06.c
testsuites/psxtests/psxhdrs/time07.c
testsuites/psxtests/psxhdrs/time08.c
testsuites/psxtests/psxhdrs/time09.c
testsuites/psxtests/psxhdrs/time10.c
testsuites/psxtests/psxhdrs/time11.c
testsuites/psxtests/psxhdrs/time12.c
testsuites/psxtests/psxhdrs/time13.c
testsuites/psxtests/psxhdrs/timer01.c
testsuites/psxtests/psxhdrs/timer02.c
testsuites/psxtests/psxhdrs/timer03.c
testsuites/psxtests/psxhdrs/timer04.c
testsuites/psxtests/psxhdrs/timer05.c
testsuites/psxtests/psxhdrs/timer06.c
testsuites/psxtests/psxmount/.cvsignore
testsuites/psxtests/psxmount/Makefile.am
testsuites/psxtests/psxmount/main.c
testsuites/psxtests/psxmount/psxmount.scn
testsuites/psxtests/psxmount/test.c
testsuites/psxtests/psxmsgq01/.cvsignore
testsuites/psxtests/psxmsgq01/Makefile.am
testsuites/psxtests/psxmsgq01/init.c
testsuites/psxtests/psxmsgq01/psxmsgq01.scn
testsuites/psxtests/psxmsgq01/system.h
testsuites/psxtests/psxreaddir/.cvsignore
testsuites/psxtests/psxreaddir/Makefile.am
testsuites/psxtests/psxreaddir/main.c
testsuites/psxtests/psxreaddir/psxreaddir.scn
testsuites/psxtests/psxreaddir/test.c
testsuites/psxtests/psxsem01/.cvsignore
testsuites/psxtests/psxsem01/Makefile.am
testsuites/psxtests/psxsem01/init.c
testsuites/psxtests/psxsem01/psxsem01.scn
testsuites/psxtests/psxsem01/system.h
testsuites/psxtests/psxstat/.cvsignore
testsuites/psxtests/psxstat/Makefile.am
testsuites/psxtests/psxstat/main.c
testsuites/psxtests/psxstat/psxstat.scn
testsuites/psxtests/psxstat/test.c
testsuites/psxtests/psxtests.am
testsuites/psxtests/psxtime/.cvsignore
testsuites/psxtests/psxtime/Makefile.am
testsuites/psxtests/psxtime/main.c
testsuites/psxtests/psxtime/psxtime.scn
testsuites/psxtests/psxtime/test.c
testsuites/psxtests/psxtimer/.cvsignore
testsuites/psxtests/psxtimer/Makefile.am
testsuites/psxtests/psxtimer/psxtimer.c
testsuites/psxtests/psxtimer/psxtimer.scn
testsuites/psxtests/psxtimer/system.h
testsuites/samples/.cvsignore
testsuites/samples/ChangeLog
testsuites/samples/Makefile.am
testsuites/samples/README
testsuites/samples/base_mp/.cvsignore
testsuites/samples/base_mp/Makefile.am
testsuites/samples/base_mp/apptask.c
testsuites/samples/base_mp/init.c
testsuites/samples/base_mp/node1/.cvsignore
testsuites/samples/base_mp/node1/Makefile.am
testsuites/samples/base_mp/node1/base_mp.doc
testsuites/samples/base_mp/node1/base_mp.scn
testsuites/samples/base_mp/node2/.cvsignore
testsuites/samples/base_mp/node2/Makefile.am
testsuites/samples/base_mp/node2/base_mp.doc
testsuites/samples/base_mp/node2/base_mp.scn
testsuites/samples/base_mp/system.h
testsuites/samples/base_sp/.cvsignore
testsuites/samples/base_sp/Makefile.am
testsuites/samples/base_sp/apptask.c
testsuites/samples/base_sp/base_sp.doc
testsuites/samples/base_sp/base_sp.scn
testsuites/samples/base_sp/init.c
testsuites/samples/base_sp/system.h
testsuites/samples/cdtest/.cvsignore
testsuites/samples/cdtest/Makefile.am
testsuites/samples/cdtest/cdtest.scn
testsuites/samples/cdtest/init.c
testsuites/samples/cdtest/main.cc
testsuites/samples/cdtest/system.h
testsuites/samples/configure.ac
testsuites/samples/hello/.cvsignore
testsuites/samples/hello/Makefile.am
testsuites/samples/hello/hello.doc
testsuites/samples/hello/hello.scn
testsuites/samples/hello/init.c
testsuites/samples/hello/system.h
testsuites/samples/loopback/.cvsignore
testsuites/samples/loopback/Makefile.am
testsuites/samples/loopback/README
testsuites/samples/loopback/init.c
testsuites/samples/loopback/loopback.scn
testsuites/samples/minimum/.cvsignore
testsuites/samples/minimum/Makefile.am
testsuites/samples/minimum/init.c
testsuites/samples/minimum/minimum.doc
testsuites/samples/minimum/minimum.scn
testsuites/samples/paranoia/.cvsignore
testsuites/samples/paranoia/Makefile.am
testsuites/samples/paranoia/init.c
testsuites/samples/paranoia/paranoia.c
testsuites/samples/paranoia/paranoia.doc
testsuites/samples/paranoia/system.h
testsuites/samples/sample.am
testsuites/samples/ticker/.cvsignore
testsuites/samples/ticker/Makefile.am
testsuites/samples/ticker/init.c
testsuites/samples/ticker/system.h
testsuites/samples/ticker/tasks.c
testsuites/samples/ticker/ticker.doc
testsuites/samples/ticker/ticker.scn
testsuites/samples/unlimited/.cvsignore
testsuites/samples/unlimited/Makefile.am
testsuites/samples/unlimited/init.c
testsuites/samples/unlimited/system.h
testsuites/samples/unlimited/test1.c
testsuites/samples/unlimited/test2.c
testsuites/samples/unlimited/test3.c
testsuites/samples/unlimited/unlimited.doc
testsuites/samples/unlimited/unlimited.scn
testsuites/sptests/.cvsignore
testsuites/sptests/ChangeLog
testsuites/sptests/Makefile.am
testsuites/sptests/README
testsuites/sptests/configure.ac
testsuites/sptests/sp01/.cvsignore
testsuites/sptests/sp01/Makefile.am
testsuites/sptests/sp01/init.c
testsuites/sptests/sp01/sp01.doc
testsuites/sptests/sp01/sp01.scn
testsuites/sptests/sp01/system.h
testsuites/sptests/sp01/task1.c
testsuites/sptests/sp02/.cvsignore
testsuites/sptests/sp02/Makefile.am
testsuites/sptests/sp02/init.c
testsuites/sptests/sp02/preempt.c
testsuites/sptests/sp02/sp02.doc
testsuites/sptests/sp02/sp02.scn
testsuites/sptests/sp02/system.h
testsuites/sptests/sp02/task1.c
testsuites/sptests/sp02/task2.c
testsuites/sptests/sp02/task3.c
testsuites/sptests/sp03/.cvsignore
testsuites/sptests/sp03/Makefile.am
testsuites/sptests/sp03/init.c
testsuites/sptests/sp03/sp03.doc
testsuites/sptests/sp03/sp03.scn
testsuites/sptests/sp03/system.h
testsuites/sptests/sp03/task1.c
testsuites/sptests/sp03/task2.c
testsuites/sptests/sp04/.cvsignore
testsuites/sptests/sp04/Makefile.am
testsuites/sptests/sp04/init.c
testsuites/sptests/sp04/sp04.doc
testsuites/sptests/sp04/sp04.scn
testsuites/sptests/sp04/system.h
testsuites/sptests/sp04/task1.c
testsuites/sptests/sp04/task2.c
testsuites/sptests/sp04/task3.c
testsuites/sptests/sp04/tswitch.c
testsuites/sptests/sp05/.cvsignore
testsuites/sptests/sp05/Makefile.am
testsuites/sptests/sp05/init.c
testsuites/sptests/sp05/sp05.doc
testsuites/sptests/sp05/sp05.scn
testsuites/sptests/sp05/system.h
testsuites/sptests/sp05/task1.c
testsuites/sptests/sp05/task2.c
testsuites/sptests/sp05/task3.c
testsuites/sptests/sp06/.cvsignore
testsuites/sptests/sp06/Makefile.am
testsuites/sptests/sp06/init.c
testsuites/sptests/sp06/sp06.doc
testsuites/sptests/sp06/sp06.scn
testsuites/sptests/sp06/system.h
testsuites/sptests/sp06/task1.c
testsuites/sptests/sp06/task2.c
testsuites/sptests/sp06/task3.c
testsuites/sptests/sp07/.cvsignore
testsuites/sptests/sp07/Makefile.am
testsuites/sptests/sp07/init.c
testsuites/sptests/sp07/sp07.doc
testsuites/sptests/sp07/sp07.scn
testsuites/sptests/sp07/system.h
testsuites/sptests/sp07/task1.c
testsuites/sptests/sp07/task2.c
testsuites/sptests/sp07/task3.c
testsuites/sptests/sp07/task4.c
testsuites/sptests/sp07/taskexit.c
testsuites/sptests/sp07/tcreate.c
testsuites/sptests/sp07/tdelete.c
testsuites/sptests/sp07/trestart.c
testsuites/sptests/sp07/tstart.c
testsuites/sptests/sp08/.cvsignore
testsuites/sptests/sp08/Makefile.am
testsuites/sptests/sp08/init.c
testsuites/sptests/sp08/sp08.doc
testsuites/sptests/sp08/sp08.scn
testsuites/sptests/sp08/system.h
testsuites/sptests/sp08/task1.c
testsuites/sptests/sp09/.cvsignore
testsuites/sptests/sp09/Makefile.am
testsuites/sptests/sp09/delay.c
testsuites/sptests/sp09/init.c
testsuites/sptests/sp09/isr.c
testsuites/sptests/sp09/screen01.c
testsuites/sptests/sp09/screen02.c
testsuites/sptests/sp09/screen03.c
testsuites/sptests/sp09/screen04.c
testsuites/sptests/sp09/screen05.c
testsuites/sptests/sp09/screen06.c
testsuites/sptests/sp09/screen07.c
testsuites/sptests/sp09/screen08.c
testsuites/sptests/sp09/screen09.c
testsuites/sptests/sp09/screen10.c
testsuites/sptests/sp09/screen11.c
testsuites/sptests/sp09/screen12.c
testsuites/sptests/sp09/screen13.c
testsuites/sptests/sp09/screen14.c
testsuites/sptests/sp09/sp09.doc
testsuites/sptests/sp09/sp09.scn
testsuites/sptests/sp09/system.h
testsuites/sptests/sp09/task1.c
testsuites/sptests/sp09/task2.c
testsuites/sptests/sp09/task3.c
testsuites/sptests/sp09/task4.c
testsuites/sptests/sp11/.cvsignore
testsuites/sptests/sp11/Makefile.am
testsuites/sptests/sp11/init.c
testsuites/sptests/sp11/sp11.doc
testsuites/sptests/sp11/sp11.scn
testsuites/sptests/sp11/system.h
testsuites/sptests/sp11/task1.c
testsuites/sptests/sp11/task2.c
testsuites/sptests/sp11/timer.c
testsuites/sptests/sp12/.cvsignore
testsuites/sptests/sp12/Makefile.am
testsuites/sptests/sp12/init.c
testsuites/sptests/sp12/pridrv.c
testsuites/sptests/sp12/pritask.c
testsuites/sptests/sp12/sp12.doc
testsuites/sptests/sp12/sp12.scn
testsuites/sptests/sp12/system.h
testsuites/sptests/sp12/task1.c
testsuites/sptests/sp12/task2.c
testsuites/sptests/sp12/task3.c
testsuites/sptests/sp12/task4.c
testsuites/sptests/sp12/task5.c
testsuites/sptests/sp13/.cvsignore
testsuites/sptests/sp13/Makefile.am
testsuites/sptests/sp13/fillbuff.c
testsuites/sptests/sp13/init.c
testsuites/sptests/sp13/putbuff.c
testsuites/sptests/sp13/sp13.doc
testsuites/sptests/sp13/sp13.scn
testsuites/sptests/sp13/system.h
testsuites/sptests/sp13/task1.c
testsuites/sptests/sp13/task2.c
testsuites/sptests/sp13/task3.c
testsuites/sptests/sp14/.cvsignore
testsuites/sptests/sp14/Makefile.am
testsuites/sptests/sp14/asr.c
testsuites/sptests/sp14/init.c
testsuites/sptests/sp14/sp14.doc
testsuites/sptests/sp14/sp14.scn
testsuites/sptests/sp14/system.h
testsuites/sptests/sp14/task1.c
testsuites/sptests/sp14/task2.c
testsuites/sptests/sp15/.cvsignore
testsuites/sptests/sp15/Makefile.am
testsuites/sptests/sp15/init.c
testsuites/sptests/sp15/sp15.doc
testsuites/sptests/sp15/sp15.scn
testsuites/sptests/sp15/system.h
testsuites/sptests/sp15/task1.c
testsuites/sptests/sp16/.cvsignore
testsuites/sptests/sp16/Makefile.am
testsuites/sptests/sp16/init.c
testsuites/sptests/sp16/sp16.doc
testsuites/sptests/sp16/sp16.scn
testsuites/sptests/sp16/system.h
testsuites/sptests/sp16/task1.c
testsuites/sptests/sp16/task2.c
testsuites/sptests/sp16/task3.c
testsuites/sptests/sp16/task4.c
testsuites/sptests/sp16/task5.c
testsuites/sptests/sp17/.cvsignore
testsuites/sptests/sp17/Makefile.am
testsuites/sptests/sp17/asr.c
testsuites/sptests/sp17/init.c
testsuites/sptests/sp17/sp17.doc
testsuites/sptests/sp17/sp17.scn
testsuites/sptests/sp17/system.h
testsuites/sptests/sp17/task1.c
testsuites/sptests/sp17/task2.c
testsuites/sptests/sp19/.cvsignore
testsuites/sptests/sp19/Makefile.am
testsuites/sptests/sp19/first.c
testsuites/sptests/sp19/fptask.c
testsuites/sptests/sp19/fptest.h
testsuites/sptests/sp19/init.c
testsuites/sptests/sp19/inttest.h
testsuites/sptests/sp19/sp19.doc
testsuites/sptests/sp19/sp19.scn
testsuites/sptests/sp19/system.h
testsuites/sptests/sp19/task1.c
testsuites/sptests/sp20/.cvsignore
testsuites/sptests/sp20/Makefile.am
testsuites/sptests/sp20/getall.c
testsuites/sptests/sp20/init.c
testsuites/sptests/sp20/sp20.doc
testsuites/sptests/sp20/sp20.scn
testsuites/sptests/sp20/system.h
testsuites/sptests/sp20/task1.c
testsuites/sptests/sp21/.cvsignore
testsuites/sptests/sp21/Makefile.am
testsuites/sptests/sp21/init.c
testsuites/sptests/sp21/sp21.doc
testsuites/sptests/sp21/sp21.scn
testsuites/sptests/sp21/system.h
testsuites/sptests/sp21/task1.c
testsuites/sptests/sp22/.cvsignore
testsuites/sptests/sp22/Makefile.am
testsuites/sptests/sp22/delay.c
testsuites/sptests/sp22/init.c
testsuites/sptests/sp22/prtime.c
testsuites/sptests/sp22/sp22.doc
testsuites/sptests/sp22/sp22.scn
testsuites/sptests/sp22/system.h
testsuites/sptests/sp22/task1.c
testsuites/sptests/sp23/.cvsignore
testsuites/sptests/sp23/Makefile.am
testsuites/sptests/sp23/init.c
testsuites/sptests/sp23/sp23.doc
testsuites/sptests/sp23/sp23.scn
testsuites/sptests/sp23/system.h
testsuites/sptests/sp23/task1.c
testsuites/sptests/sp24/.cvsignore
testsuites/sptests/sp24/Makefile.am
testsuites/sptests/sp24/init.c
testsuites/sptests/sp24/resume.c
testsuites/sptests/sp24/sp24.doc
testsuites/sptests/sp24/sp24.scn
testsuites/sptests/sp24/system.h
testsuites/sptests/sp24/task1.c
testsuites/sptests/sp25/.cvsignore
testsuites/sptests/sp25/Makefile.am
testsuites/sptests/sp25/init.c
testsuites/sptests/sp25/sp25.doc
testsuites/sptests/sp25/sp25.scn
testsuites/sptests/sp25/system.h
testsuites/sptests/sp25/task1.c
testsuites/sptests/sp26/.cvsignore
testsuites/sptests/sp26/Makefile.am
testsuites/sptests/sp26/init.c
testsuites/sptests/sp26/sp26.doc
testsuites/sptests/sp26/sp26.scn
testsuites/sptests/sp26/system.h
testsuites/sptests/sp26/task1.c
testsuites/sptests/sp27/.cvsignore
testsuites/sptests/sp27/Makefile.am
testsuites/sptests/sp27/init.c
testsuites/sptests/sp27/sp27.doc
testsuites/sptests/sp27/sp27.scn
testsuites/sptests/sp28/.cvsignore
testsuites/sptests/sp28/Makefile.am
testsuites/sptests/sp28/init.c
testsuites/sptests/sp28/sp28.doc
testsuites/sptests/sp28/sp28.scn
testsuites/sptests/sp29/.cvsignore
testsuites/sptests/sp29/Makefile.am
testsuites/sptests/sp29/init.c
testsuites/sptests/sp29/sp29.doc
testsuites/sptests/sp29/sp29.scn
testsuites/sptests/sp30/.cvsignore
testsuites/sptests/sp30/Makefile.am
testsuites/sptests/sp30/init.c
testsuites/sptests/sp30/resume.c
testsuites/sptests/sp30/sp30.doc
testsuites/sptests/sp30/sp30.scn
testsuites/sptests/sp30/system.h
testsuites/sptests/sp30/task1.c
testsuites/sptests/sp31/.cvsignore
testsuites/sptests/sp31/Makefile.am
testsuites/sptests/sp31/delay.c
testsuites/sptests/sp31/init.c
testsuites/sptests/sp31/prtime.c
testsuites/sptests/sp31/sp31.doc
testsuites/sptests/sp31/sp31.scn
testsuites/sptests/sp31/system.h
testsuites/sptests/sp31/task1.c
testsuites/sptests/sp32/.cvsignore
testsuites/sptests/sp32/Makefile.am
testsuites/sptests/sp32/init.c
testsuites/sptests/sp32/sp32.scn
testsuites/sptests/spfatal/.cvsignore
testsuites/sptests/spfatal/Makefile.am
testsuites/sptests/spfatal/README
testsuites/sptests/spfatal/fatal.c
testsuites/sptests/spfatal/init.c
testsuites/sptests/spfatal/puterr.c
testsuites/sptests/spfatal/spfatal.doc
testsuites/sptests/spfatal/spfatal.scn
testsuites/sptests/spfatal/system.h
testsuites/sptests/spfatal/task1.c
testsuites/sptests/spsize/.cvsignore
testsuites/sptests/spsize/Makefile.am
testsuites/sptests/spsize/getint.c
testsuites/sptests/spsize/init.c
testsuites/sptests/spsize/size.c
testsuites/sptests/spsize/size.scn
testsuites/sptests/spsize/system.h
testsuites/sptests/sptests.am
testsuites/support/.cvsignore
testsuites/support/ChangeLog
testsuites/support/Makefile.am
testsuites/support/configure.ac
testsuites/support/include/.cvsignore
testsuites/support/include/buffer_test_io.h
testsuites/support/include/tmacros.h
testsuites/tmitrontests/.cvsignore
testsuites/tmitrontests/ChangeLog
testsuites/tmitrontests/Makefile.am
testsuites/tmitrontests/README
testsuites/tmitrontests/configure.ac
testsuites/tmitrontests/include/.cvsignore
testsuites/tmitrontests/include/Makefile.am
testsuites/tmitrontests/include/timesys.h
testsuites/tmitrontests/tmitronsem01/.cvsignore
testsuites/tmitrontests/tmitronsem01/Makefile.am
testsuites/tmitrontests/tmitronsem01/init.c
testsuites/tmitrontests/tmitronsem01/system.h
testsuites/tmitrontests/tmitronsem01/tmitronsem01.doc
testsuites/tmitrontests/tmitrontests.am
testsuites/tmtests/.cvsignore
testsuites/tmtests/ChangeLog
testsuites/tmtests/Makefile.am
testsuites/tmtests/README
testsuites/tmtests/configure.ac
testsuites/tmtests/include/.cvsignore
testsuites/tmtests/include/Makefile.am
testsuites/tmtests/include/timesys.h
testsuites/tmtests/tm01/.cvsignore
testsuites/tmtests/tm01/Makefile.am
testsuites/tmtests/tm01/system.h
testsuites/tmtests/tm01/task1.c
testsuites/tmtests/tm01/tm01.doc
testsuites/tmtests/tm02/.cvsignore
testsuites/tmtests/tm02/Makefile.am
testsuites/tmtests/tm02/system.h
testsuites/tmtests/tm02/task1.c
testsuites/tmtests/tm02/tm02.doc
testsuites/tmtests/tm03/.cvsignore
testsuites/tmtests/tm03/Makefile.am
testsuites/tmtests/tm03/system.h
testsuites/tmtests/tm03/task1.c
testsuites/tmtests/tm03/tm03.doc
testsuites/tmtests/tm04/.cvsignore
testsuites/tmtests/tm04/Makefile.am
testsuites/tmtests/tm04/system.h
testsuites/tmtests/tm04/task1.c
testsuites/tmtests/tm04/tm04.doc
testsuites/tmtests/tm05/.cvsignore
testsuites/tmtests/tm05/Makefile.am
testsuites/tmtests/tm05/system.h
testsuites/tmtests/tm05/task1.c
testsuites/tmtests/tm05/tm05.doc
testsuites/tmtests/tm06/.cvsignore
testsuites/tmtests/tm06/Makefile.am
testsuites/tmtests/tm06/system.h
testsuites/tmtests/tm06/task1.c
testsuites/tmtests/tm06/tm06.doc
testsuites/tmtests/tm07/.cvsignore
testsuites/tmtests/tm07/Makefile.am
testsuites/tmtests/tm07/system.h
testsuites/tmtests/tm07/task1.c
testsuites/tmtests/tm07/tm07.doc
testsuites/tmtests/tm08/.cvsignore
testsuites/tmtests/tm08/Makefile.am
testsuites/tmtests/tm08/system.h
testsuites/tmtests/tm08/task1.c
testsuites/tmtests/tm08/tm08.doc
testsuites/tmtests/tm09/.cvsignore
testsuites/tmtests/tm09/Makefile.am
testsuites/tmtests/tm09/system.h
testsuites/tmtests/tm09/task1.c
testsuites/tmtests/tm09/tm09.doc
testsuites/tmtests/tm10/.cvsignore
testsuites/tmtests/tm10/Makefile.am
testsuites/tmtests/tm10/system.h
testsuites/tmtests/tm10/task1.c
testsuites/tmtests/tm10/tm10.doc
testsuites/tmtests/tm11/.cvsignore
testsuites/tmtests/tm11/Makefile.am
testsuites/tmtests/tm11/system.h
testsuites/tmtests/tm11/task1.c
testsuites/tmtests/tm11/tm11.doc
testsuites/tmtests/tm12/.cvsignore
testsuites/tmtests/tm12/Makefile.am
testsuites/tmtests/tm12/system.h
testsuites/tmtests/tm12/task1.c
testsuites/tmtests/tm12/tm12.doc
testsuites/tmtests/tm13/.cvsignore
testsuites/tmtests/tm13/Makefile.am
testsuites/tmtests/tm13/system.h
testsuites/tmtests/tm13/task1.c
testsuites/tmtests/tm13/tm13.doc
testsuites/tmtests/tm14/.cvsignore
testsuites/tmtests/tm14/Makefile.am
testsuites/tmtests/tm14/system.h
testsuites/tmtests/tm14/task1.c
testsuites/tmtests/tm14/tm14.doc
testsuites/tmtests/tm15/.cvsignore
testsuites/tmtests/tm15/Makefile.am
testsuites/tmtests/tm15/system.h
testsuites/tmtests/tm15/task1.c
testsuites/tmtests/tm15/tm15.doc
testsuites/tmtests/tm16/.cvsignore
testsuites/tmtests/tm16/Makefile.am
testsuites/tmtests/tm16/system.h
testsuites/tmtests/tm16/task1.c
testsuites/tmtests/tm16/tm16.doc
testsuites/tmtests/tm17/.cvsignore
testsuites/tmtests/tm17/Makefile.am
testsuites/tmtests/tm17/system.h
testsuites/tmtests/tm17/task1.c
testsuites/tmtests/tm17/tm17.doc
testsuites/tmtests/tm18/.cvsignore
testsuites/tmtests/tm18/Makefile.am
testsuites/tmtests/tm18/system.h
testsuites/tmtests/tm18/task1.c
testsuites/tmtests/tm18/tm18.doc
testsuites/tmtests/tm19/.cvsignore
testsuites/tmtests/tm19/Makefile.am
testsuites/tmtests/tm19/system.h
testsuites/tmtests/tm19/task1.c
testsuites/tmtests/tm19/tm19.doc
testsuites/tmtests/tm20/.cvsignore
testsuites/tmtests/tm20/Makefile.am
testsuites/tmtests/tm20/system.h
testsuites/tmtests/tm20/task1.c
testsuites/tmtests/tm20/tm20.doc
testsuites/tmtests/tm21/.cvsignore
testsuites/tmtests/tm21/Makefile.am
testsuites/tmtests/tm21/system.h
testsuites/tmtests/tm21/task1.c
testsuites/tmtests/tm21/tm21.doc
testsuites/tmtests/tm22/.cvsignore
testsuites/tmtests/tm22/Makefile.am
testsuites/tmtests/tm22/system.h
testsuites/tmtests/tm22/task1.c
testsuites/tmtests/tm22/tm22.doc
testsuites/tmtests/tm23/.cvsignore
testsuites/tmtests/tm23/Makefile.am
testsuites/tmtests/tm23/system.h
testsuites/tmtests/tm23/task1.c
testsuites/tmtests/tm23/tm23.doc
testsuites/tmtests/tm24/.cvsignore
testsuites/tmtests/tm24/Makefile.am
testsuites/tmtests/tm24/system.h
testsuites/tmtests/tm24/task1.c
testsuites/tmtests/tm24/tm24.doc
testsuites/tmtests/tm25/.cvsignore
testsuites/tmtests/tm25/Makefile.am
testsuites/tmtests/tm25/system.h
testsuites/tmtests/tm25/task1.c
testsuites/tmtests/tm25/tm25.doc
testsuites/tmtests/tm26/.cvsignore
testsuites/tmtests/tm26/Makefile.am
testsuites/tmtests/tm26/fptest.h
testsuites/tmtests/tm26/system.h
testsuites/tmtests/tm26/task1.c
testsuites/tmtests/tm26/tm26.doc
testsuites/tmtests/tm27/.cvsignore
testsuites/tmtests/tm27/Makefile.am
testsuites/tmtests/tm27/system.h
testsuites/tmtests/tm27/task1.c
testsuites/tmtests/tm27/tm27.doc
testsuites/tmtests/tm28/.cvsignore
testsuites/tmtests/tm28/Makefile.am
testsuites/tmtests/tm28/system.h
testsuites/tmtests/tm28/task1.c
testsuites/tmtests/tm28/tm28.doc
testsuites/tmtests/tm29/.cvsignore
testsuites/tmtests/tm29/Makefile.am
testsuites/tmtests/tm29/system.h
testsuites/tmtests/tm29/task1.c
testsuites/tmtests/tm29/tm29.doc
testsuites/tmtests/tmck/.cvsignore
testsuites/tmtests/tmck/Makefile.am
testsuites/tmtests/tmck/system.h
testsuites/tmtests/tmck/task1.c
testsuites/tmtests/tmck/tmck.doc
testsuites/tmtests/tmoverhd/.cvsignore
testsuites/tmtests/tmoverhd/Makefile.am
testsuites/tmtests/tmoverhd/dumrtems.h
testsuites/tmtests/tmoverhd/empty.c
testsuites/tmtests/tmoverhd/system.h
testsuites/tmtests/tmoverhd/testtask.c
testsuites/tmtests/tmoverhd/tmoverhd.doc
testsuites/tmtests/tmtests.am
testsuites/tools/.cvsignore
testsuites/tools/ChangeLog
testsuites/tools/Makefile.am
testsuites/tools/configure.ac
testsuites/tools/generic/.cvsignore
testsuites/tools/generic/ChangeLog
testsuites/tools/generic/Makefile.am
testsuites/tools/generic/configure.ac
testsuites/tools/generic/difftest.in
testsuites/tools/generic/sorttimes.in
* rtems/rtems_glue.c: A small patch to the network daemon task
code. I just added code to check the return value of
the rtems_bsdnet_event_receive function. Only when
this function returns a SUCCESSFUL status, will the
event flags be checked. This is more of a code cleanup issue
than a bug. The patch will just ensure the ipintr() and
arpintr() functions are only called when a event is signaled.
PR 342/networking
* kern/uipc_mbuf.c: The RTEMS version of the m_copyback is changing
the m_len value of the mbuf. I looked into the source from another
BSD system and the mbuf length is not changed inside this function.
The m_copyback function is only being used in the net/rtsock.c file.
So I think this problem is only visable under certain routing table
conditions.
PR 341/networking
* lib/ftpfs.c: Account for NULL at end of strings when malloc()'ing
memory.
* Makefile.am: Add kern/kern_sysctl.c to Makefile.am so networking
tests build. This was subsequently reported as PR337 before I
committed the fix.
* libc/getproto.c, libc/getprotoname.c: modification to call
getprotoent_static() if fopen() on /etc/protocols fails.
* netinet/tcp_subr.c: Add args to INP_INFO_RLOCK, INP_INFO_RUNLOCK,
INP_LOCK, INP_UNLOCK macros.
* netinet/udp_usrreq.c: Add args to INP_INFO_RLOCK, INP_INFO_RUNLOCK,
* sys/queue.h: Fix alignment problem on ARM.
* Makefile.am: Added sys/linker_set.h
* kern/Makefile.am: Added kern_mib.c and kern_sysctl.c.
* kern/uipc_socket.c: OID changed from KERN_SOMAXCONN to KIPC_SOMAXCONN.
* kern/uipc_socket2.c: OID changed from KERN_MAXSOCKBUF to
KIPC_MAXSOCKBUF.
* net/if_ethersubr.c: FreeBSD 2.2.2 does not have a _net_link node
while 5.0 does.
* net/if_ppp.c: Removed the TEXT_SET define as these macros are
now implemented.
* net/rtsock.c: Enable sysctl support plus fix the bug with the
lastest FreeBSD sysctl header file.
* netinet/icmp_var.h: FreeBSD 2.2.2 does not have a _net_inet_icmp
node while 5.0 does.
* netinet/if_ether.c: FreeBSD 2.2.2 does not have a _net_link_ether
* netinet/igmp_var.h: FreeBSD 2.2.2 does not have a _net_inet_igmp
* netinet/in_pcb.c: Fixed the arguments to the sysctl call. Add
inp_gencnt and ipi_count. These are used when listing connections.
* netinet/in_pcb.h: Added counters to aid the listing of connections.
* netinet/in_var.h: Provide the _net_inet_ip and _net_inet_raw nodes.
* netinet/ip_fw.c: Disable the firewall sysctl calls.
* netinet/tcp_subr.c: Merge tcp_pcblist from the lastest FreeBSD source.
* netinet/tcp_var.h: Add structures needed by net-snmp to list
connections.
* netinet/udp_usrreq.c: Merged udp_pcblist from the lastest FreeBSD
source.
* netinet/udp_var.h: Added the sysctl id UDPCTL_PCBLIST. Used by
net-snmp.
* rtems_glue.c: Call sysctl_register_all when initialising the
network stack to register all the sysctl calls. These are in the
special sections and required an updated linker script.
* rtems/rtems_syscall.c: Add the sysctl call.
* sys/kernel.h: Use the lastest FreeBSD method of handling sysctl
structures. This now held in the sys/linker_set.h file.
* sys/queue.h: This is from the lastest FreeBSD code with the circular
code merged back in as it is not used in the lastest FreeBSD kernel.
* sys/sysctl.h: The lastest sysctl. This was needed to use with the new
linker set method. The FreeBSD 2.2.2 version has asm hacks. The lastest
version of the FreeBSD does not have these hacks. It uses gcc attribute
directives.
* Makefile.am: Merge-in kern/Makefile.am, net/Makefile.am,
netinet/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
rtems/Makefile.am.
* kern/Makefile.am: Remove.
* net/Makefile.am: Remove.
* netinet/Makefile.am: Remove.
* nfs/Makefile.am: Remove.
* rtems/Makefile.am: Remove.
* configure.ac: Ditto.
* kern/Makefile.am: Remove C_O_FILES;
Don't let all-local depend on $OBJS)
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* configure.ac: Fix package name.
* Makefile.am: Merge-in HEADER-handling from
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am.
* net/Makefile.am: Remove *_HEADERS.
* netinet/Makefile.am: Remove *_HEADERS.
* nfs/Makefile.am: Remove *_HEADERS.
* Makefile.am: Merge-in arpa/Makefile.am, machine/Makefile.am,
sys/Makefile.am, vm/Makefile.am.
Add . to SUBDIRS.
* arpa/Makefile.am: Remove.
* machine/Makefile.am: Remove.
* sys/Makefile.am: Remove.
* vm/Makefile.am: Remove.
* sys/select.h: Add C++ to C external.
* kern/uipc_mbuf.c: Comment out m0 in m_copydata to suppress
warning.
* ChangeLog: Corrected.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
* libc/rcmd.c, netinet/in_cksum_arm.c: Removed warnings.
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
