The missing disconnect left the socket in an unusable state. Each send
request resulted in an EISCONN error.
Update #2375.
ensure that node_access is comparable in unmount()
Update #2375.
from 4.10.2-15-g5b21eb6
to eb7753437ff858ebe34a08baef7dfdb45eb0f018
Update #2375.
closes #2376.
Access memory using a byte stream when copying to avoid unaligned
access. update #1401
Waiting for mbufs at this level is a bad solution. It would be better
to try to allocate a new mbuf chain before we hand over the current mbuf
chain to the upper layer. In case the allocation fails we should drop
the current packet and use its mbuf chain for a new packet.
PR 1983/networking
* libnetworking/libc/gethostbyht.c (gethostent_r):
Abort if (!hostf).
PR 1381/networking
* libnetworking/netinet/ip_output.c: If a null or unreachable gateway
is specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno 118 Host
PR 1776/networking
* libnetworking/rtems/rtems_glue.c: Higher resolution microtime()
for SO_TIMESTAMP.
* posix/include/aio.h, posix/src/aio_return.c:
Let aio_return return ssize_t (Mandated by POSIX).
* libnetworking/libc/addr2ascii.c,
libnetworking/libc/ascii2addr.c,
libnetworking/libc/addr2ascii.3: Remove.
* libnetworking/Makefile.am: Reflect changes above.
PR 1667/cpukit
* libnetworking/rtems/mkrootfs.c: Include <rtems/libio.h>.
* libnetworking/lib/tftpDriver.c: rtems_tftp_ops and
rtems_tftp_handlers are now const and static.
* libnetworking/rtems/tftp.h: Removed
rtems_bsdnet_initialize_tftp_filesystem and rtems_tftp_ops.
* libcsupport/src/unmount.c: Removed obsolete declarations. Fixed
invalid memory free.
2010-06-10 Sebastian Huber <sebastian.huber@embedded-brains.de>
* libnetworking/rtems/ftpfs.h, libnetworking/lib/ftpfs.c: Removed
rtems_ftpfs_mount().
* libcsupport/src/mount-mktgt.c: New file.
* libcsupport/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Declare
mount_and_make_target_path().
2010-06-09 Sebastian Huber <sebastian.huber@embedded-brains.de>
* libnetworking/rtems/ftpfs.h, libnetworking/lib/ftpfs.c: Added
rtems_ftpfs_mount() again. Documentation.
* libcsupport/include/rtems/libio.h, sapi/include/confdefs.h: Added
and use defines for file system types.
* libcsupport/src/mount.c: Fixed NULL pointer access.
* libcsupport/include/rtems/libio.h: Documentation.
2010-06-08 Sebastian Huber <sebastian.huber@embedded-brains.de>
PR 1524/filesystem
* libcsupport/src/rtems_mkdir.c: New file.
* libcsupport/src/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Added rtems_mkdir().
* libmisc/fsmount/fsmount.h, libmisc/fsmount/fsmount.c,
libblock/src/bdpart-mount.c, libnetworking/rtems/mkrootfs.h,
libnetworking/rtems/mkrootfs.c: Use rtems_mkdir(). Removed
rtems_fsmount_create_mount_point() and rtems_rootfs_mkdir().
* libnetworking/rtems/mkrootfs.h: doxygen cosmetics.
* libnetworking/netinet/if_ether.c: Misc. 64bit fixes from FreeBSD.
* libfs/src/nfsclient/src/rpcio.c: Misc. 64bit fixes.
PR 1566/filesystem
* libnetworking/rtems/mkrootfs.c, libnetworking/rtems/mkrootfs.h:
Let rtems_rootfs_append_host_rec take an in_addr_t as first arg.
* libnetworking/rtems/rtems_dhcp.c, libnetworking/nfs/bootp_subr.c:
* libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c,
libnetworking/nfs/bootp_subr.c: Misc. 64bit-compatibility fixes.
* libnetworking/netinet/ip_fw.c, libnetworking/netinet/ip_input.c:
* libnetworking/rtems/mkrootfs.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/timestamp.h: Move 'extern "C"'.
* libnetworking/netinet/in_pcb.c:
Eliminate "ushort".
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/imfs/miniimfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
* libnetworking/net/if.c:
Use uintptr_t and void* in _offsetof().
* libnetworking/netinet/raw_ip.c:
Cast nam to uintptr_t instead of int.
* libnetworking/libc/gethostnamadr.c:
Cast addr to uintptr_t instead of size_t.
Try to make crazy address arithmetic more portable.
* libnetworking/netinet/raw_ip.c,
libnetworking/netinet/udp_usrreq.c:
Cast mbufs to uintptr_t instead of u_long.
* libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c:
Use uint32_t instead of int as ioctl cmd arg.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c:
Use size_t instead of int for pathnamelen.
* libnetworking/sys/socketvar.h (struct sockbuf):
Use void* instead of caddr_t.
* libnetworking/sys/socket.h (struct sockwakeup):
* libnetworking/lib/ftpfs.c: Format changes. Fixed pathname
allocation in rtems_ftpfs_eval_path(). Send QUIT command during
file close.
* libnetworking/libc/map_v4v6.c: Use uintptr_t instead of u_long for
better 16bit target compliance.
* libnetworking/sys/mbuf.h: Use uintptr_t instead of u_long
for 16bit target compliance.
* libnetworking/libc/gethostbydns.c: Use uintptr_t instead of u_long
* libnetworking/sys/sysctl.h: Change sysctl_oid->arg2 into int32_t
* libnetworking/lib/ftpfs.c: 16bit target fixes:
Use ioctl_command_t as arg to rtems_ftpfs_do_ioctl.
Explicitly cast to uint32_t in char[] to uint32_t
conversion.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
