path: root/cpukit/libnetworking/vm (follow)
* 2007-02-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-02-071-58/+1
| | | | | * libnetworking/vm/vm_extern.h: Remove non-implemented/unused functions.
* 2005-02-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-182-17/+11
| | | | | * libnetworking/vm/vm_extern.h, libnetworking/vm/vm_kern.h: Update from FreeBSD.
* 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-171-46/+14
| | | | * libnetworking/vm/vm_param.h: Update from FreeBSD.
* Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance.Ralf Corsepius2004-04-203-6/+6
* Unused.Ralf Corsepius2004-03-081-2/+0
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-23/+0
| | | | | | | | | | | * Makefile.am: Merge-in arpa/Makefile.am, machine/Makefile.am, sys/Makefile.am, vm/Makefile.am. Add . to SUBDIRS. * arpa/Makefile.am: Remove. * machine/Makefile.am: Remove. * sys/Makefile.am: Remove. * vm/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-1/+1
| | | | | | | | | | | | | | | | | * arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am. * kern/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * lib/Makefile.am: Include $(top_srcdir)/../automake/*.am. * libc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * machine/Makefile.am: Include $(top_srcdir)/../automake/*.am. * net/Makefile.am: Include $(top_srcdir)/../automake/*.am. * netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am. * nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am. * sys/Makefile.am: Include $(top_srcdir)/../automake/*.am. * vm/Makefile.am: Include $(top_srcdir)/../automake/*.am. * wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-291-1/+1
| | | | | | | | | | | | | | | | | | Relocate c/src/libnetworking. * Makefile.am: Reflect moval. * machine/Makefile.am: Ditto. * net/Makefile.am: Ditto. * lib/Makefile.am: Ditto. * netinet/Makefile.am: Ditto. * vm/Makefile.am: Ditto. * libc/Makefile.am: Ditto. * sys/Makefile.am: Ditto. * arpa/Makefile.am: Ditto. * nfs/Makefile.am: Ditto. * kern/Makefile.am: Ditto. * rtems/Makefile.am: Ditto. * configure.ac: Dittp. * wrapup/Makefile.am: Ditto. Remove references to networking apps.
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | | | | | | | | | | * machine/Makefile.am: Use 'PREINSTALL_FILES ='. * net/Makefile.am: Use 'PREINSTALL_FILES ='. * netinet/Makefile.am: Use 'PREINSTALL_FILES ='. * vm/Makefile.am: Use 'PREINSTALL_FILES ='. * pppd/Makefile.am: Use 'PREINSTALL_FILES ='. * sys/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='. * arpa/Makefile.am: Use 'PREINSTALL_FILES ='. * nfs/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+5
| | | | | | | | | | | * Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, sys/Makefile.am, vm/Makefile.am: Apply include_*HEADERS instead of H_FILES. * include/Makefile.am: Remove. * Makefile.am: Add handling of *.h files. * configure.in: Remove include/Makefile.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+16
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-031-0/+9
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Base filesJoel Sherrill1998-08-194-0/+425
