* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 2011-03-24 | 1 | -1/+1 |
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-08-01 | 1 | -16/+15 |
* | Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance. | Ralf Corsepius | 2004-04-20 | 1 | -4/+4 |
* | Added port of ppp-2.3.5 from Tomasz Domin <dot@comarch.pl> of ComArch SA. | Joel Sherrill | 1999-11-30 | 1 | -2/+3 |
| | | | | | | | | | | Tomasz only tested this on the mpc823. The official site for the original source for this PPP implementation is: ftp://cs.anu.edu.au/pub/software/ppp NOTE: As of 11/30/1999, the current version of this source is 2.3.10. | ||||
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+194 |
