* | select.h, rtems_select.c, nds select: Add restrict keyword | Daniel Ramirez | 2013-11-20 | 1 | -4/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
* | #include <sys/time.h>. | Ralf Corsepius | 2010-04-02 | 1 | -0/+2 |
* | Remove selrecord, selwakeup (Unused). | Ralf Corsepius | 2007-03-29 | 1 | -7/+0 |
* | Remove __P(). | Ralf Corsepius | 2007-03-18 | 1 | -2/+2 |
* | Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance. | Ralf Corsepius | 2004-04-20 | 1 | -1/+1 |
* | Need to be extern C for use by C++. | Chris Johns | 2002-11-09 | 1 | -0/+8 |
* | 2002-07-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-24 | 1 | -0/+10 |
| | | | | | * sys/select.h: Add a prototype of select() to avoid warnings. In particular a C++ application using select() required a prototype. | ||||
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+57 |
