* | libnetworking/sys/libkern.h: Disable non-POSIX prototype that is actually unused | Joel Sherrill | 2016-03-24 | 1 | -0/+2 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 2011-03-24 | 1 | -1/+1 |
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Update from FreeBSD | Ralf Corsepius | 2005-05-01 | 1 | -25/+30 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 1 | -0/+2 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+87 |
