Update copyright notice.
Remove unused/non-implemented declarations.
* libnetworking/sys/conf.h: Remove non-implemented/unused symbols.
* libnetworking/sys/conf.h: Remove linesw, struct linesw, nlinesw.
(Clash with termiostypes.h - PR 1229).
