Update #3850
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Move legacy network stack implementation specifics to
<rtems/rtems_bsdnet_internal.h>. Include missing header files. Add
interface flags compatibility.
Update #2833.
Update #2833.
Import the <arpa/inet.h> from current FreeBSD. Necessary due to changes
in <netinet/in.h>. Remove BSD hack from <arpa/inet.h>.
Clean up problems with htonl(). These functions are defined in
<arpa/inet.h>. This lead to some problems because they are defined in
<rtems/endian.h> too. Add NTOHL, ... to
* libnetworking/kern/kern_sysctl.c, libnetworking/libc/inet_ntop.c,
libnetworking/net/if_ppp.c, libnetworking/net/pppcompress.c,
libnetworking/net/slcompress.c, libnetworking/netinet/ip_output.c,
libnetworking/netinet/udp_usrreq.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_select.c,
libnetworking/rtems/rtems_showifstat.c,
libnetworking/rtems/rtems_showroute.c,
libnetworking/rtems/rtems_syscall.c: Fixed type mismatch and
uninitialized variable warnings.
PR 626/networking
* libnetworking/rtems/rtems_showifstat.c: Use unsigned char to avoid
printing leading FFFFFF for byte values > 127.
PR 435/networking
* rtems/rtems_showifstat.c: rtems_showifstat misses printing
the netmask
The old system would panic when the loopback interface was included as
part of the network initialation structures. With the printf you get an
message, but the interface is still properly initialized.
