Update #3850
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
* rtems/rtems_bsdnet_malloc_starvation.c: Fixed name of include file.
PR 374/networking
* Makefile.am, rtems/rtems_bsdnet.h, rtems/rtems_glue.c:
The patch sent as part of PR270 got applied to the wrong place.
The effect was that (1) startup was no faster than before and
(2) malloc starvation messages came way too quickly. The attached
patch fixes both these problems and also provides a mechanism for
applications to handle malloc starvation conditions as they see fit.
* rtems/rtems_bsdnet_malloc_starvation.c: New file.
