* | Removed definition of USHRT_MAX to remove lots of redefinition warnings. | Joel Sherrill | 2000-01-10 | 1 | -2/+0 |
* | Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease | Joel Sherrill | 1999-04-19 | 1 | -1/+1 |
| | | | | porting of ACE to RTEMS. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to improve parsing of | Joel Sherrill | 1999-03-23 | 1 | -0/+2 |
| | | | | | network interface names. This change does not introduce any compatibility problems. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to eliminate external | Joel Sherrill | 1999-03-01 | 1 | -2/+0 |
| | | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine. | ||||
* | Patch from Eric Norum to correct bug induced by select() patch. | Joel Sherrill | 1999-02-05 | 1 | -0/+3 |
* | Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer | Joel Sherrill | 1999-01-26 | 1 | -1/+1 |
| | | | | so that the libc code did not have to know about (struct socket). | ||||
* | Made to compile after hacking tftp driver into beginnings of a mini-filesystem. | Joel Sherrill | 1999-01-21 | 1 | -1/+15 |
* | Patch from Ian Lance Taylor <ian@airs.com>: | Joel Sherrill | 1998-12-07 | 1 | -1/+1 |
| | | | | | | | | | | | | | RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to set a timeout for most socket I/O operations. However, in RTEMS 4.0.0, those options do not affect connect or accept. I don't know of any way to put a timeout on those calls in RTEMS 4.0.0; can anybody point to one. Since it is frequently useful to have a timeout on accept, and sometimes useful to have a timeout on connect shorter than the BSD system default of 75 seconds, the following patch causes SO_RCVTIMEO to affect connect and accept. | ||||
* | Added header files per request from Chris Johns to avoid problems | Joel Sherrill | 1998-10-12 | 1 | -0/+4 |
| | | | | in include file order. | ||||
* | All warnings removed. | Joel Sherrill | 1998-08-21 | 1 | -1/+17 |
* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 1 | -0/+2 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 1 | -1/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+156 |
