path: root/cpukit/libnetworking/opt_inet.h (unfollow)
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-4/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2004-10-222004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-0/+0
* libnetworking/opt_atalk.h, libnetworking/opt_bdg.h, libnetworking/opt_inet.h, libnetworking/opt_inet6.h, libnetworking/opt_ipx.h, libnetworking/opt_mac.h, libnetworking/opt_netgraph.h: New (Stubs). * libnetworking/net/if_loop.c: Cosmetical update from FreeBSD.
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
1998-08-20Added CVS IdsJoel Sherrill1-0/+6
1998-08-19Base filesJoel Sherrill1-0/+0
