path: root/cpukit/libnetworking/nfs (follow)
* 2001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill2001-09-191-3/+81
| | | | | | | * nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h, rtems/rtems_bsdnet_internal.h Added support for populating the initial "root" filesystem with information obtained via the DHCP response.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-4/+4
| | | | | | | | | | | * Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, sys/Makefile.am, vm/Makefile.am: Apply include_*HEADERS instead of H_FILES. * include/Makefile.am: Remove. * Makefile.am: Add handling of *.h files. * configure.in: Remove include/Makefile.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-3/+4
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-5/+17
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-031-0/+35
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Patch from Eric Norum <eric@cls.usask.ca> which includes:Joel Sherrill1999-11-101-8/+2
| | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP.
* Patch from Eric Norum <eric@cls.usask.ca> to add NTP BOOTP support becauseJoel Sherrill1999-11-091-1/+32
| | | | | | | | EPICS needs a synchronized time-of-day clock. This patch is the changes needed to get NTP server information from a BOOTP server. This patch also adds NTP server information to the network configuration structure, too.
* Patch from D. V. Henkel-Wallace <gumby@zembu.com> to remove compilerJoel Sherrill1999-05-171-1/+1
| | | | warnings.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-11-191-169/+212
| | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP.
* Fixed many warnings.Joel Sherrill1998-08-201-4/+12
* Base filesJoel Sherrill1998-08-197-0/+2379
