* libnetworking/rtems/rtems_dhcp.c: Removed panic()s. Added
interface for rtems_dhcp_failsafe.
* libnetworking/rtems/rtems_dhcp.h: Added interface for
2008-05-01 Arnout Vandecappelle <arnout@mind.be>
* libnetworking/nfs/bootp_subr: Allow some errors for sosend() and
return on timeout in bootpc_call(). Removed panic()s.
* libnetworking/rtems/rtems_glue.c: Fix the cast for the
SIOCAIFADDR ioctl call.
* libnetworking/rtems/rtems_dhcp_failsafe.c,
libnetworking/rtems/rtems_dhcp_failsafe.h: New.
* libnetworking/Makefile.am, libnetworking/preinstall.am: Added
rtems_dhcp_failsafe.c and rtems_dhcp_failsafe.h files.
* ftpd/ftpd.c, libcsupport/include/sys/ioccom.h,
libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c,
libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h,
libnetworking/net/if.c, libnetworking/net/if_ethersubr.c,
libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c,
libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings
due to improper use of int which shows up on 16 bit targets. Added
ioctl_command_t since IOCTL command argument does not reliably fit
into 16 bits.
* libnetworking/nfs/bootp_subr.c: Don't include
nfs/nfs.h, nfs/krpc.h.
* libnetworking/kern/kern_sysctl.c, libnetworking/libc/inet_ntop.c,
libnetworking/net/if_ppp.c, libnetworking/net/pppcompress.c,
libnetworking/net/slcompress.c, libnetworking/netinet/ip_output.c,
libnetworking/netinet/udp_usrreq.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_select.c,
libnetworking/rtems/rtems_showifstat.c,
libnetworking/rtems/rtems_showroute.c,
libnetworking/rtems/rtems_syscall.c: Fixed type mismatch and
uninitialized variable warnings.
PR 755/rtems
* libnetworking/libc/res_init.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/nfs/bootp_subr.c: Include <rtems/bsdnet/servers.h>.
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
PR 351/networking
* nfs/bootp_subr.c: Fix ridiculous leak in bootp and use
strdup_bootp_realloc() everywhere for sake of consistency.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* machine/types.h: Removed as a simpler version of this file is
now part of the RTEMS newlib support.
* machine/Makefile.am, machine/endian.h, nfs/bootp_subr.c,
rtems/rtems_bsdnet_internal.h, sys/Makefile.am, sys/systm.h:
Minor modifications to use the simpler machine/types.h. Mostly
more complete sets of #include's to account for machine/types.h
no longer doing this.
* PR144
* nfs/bootp_subr.c bootpc_init(): Performs a write to memory address
0 when called for the first time. This is done when trying to clear
the variable "dhcp_hostname".
* nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h,
rtems/rtems_bsdnet_internal.h Added support for populating the
initial "root" filesystem with information obtained via the DHCP
response.
Patches against 1105 snapshot to add NTP server support to network
configuration/BOOTP.
EPICS needs a synchronized time-of-day clock. This patch is the changes
needed to get NTP server information from a BOOTP server.
This patch also adds NTP server information to the network configuration
structure, too.
warnings.
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
