* | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-02-05 | 2 | -0/+26 | |
| | | | | | | | | | | | * libnetworking/kern/uipc_socket2.c, libnetworking/netinet/tcp_usrreq.c, libnetworking/netinet/udp_usrreq.c, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c: Add configuration parameters for network stack efficiency multiplier and default socket buffer sizes. Change default multiplier from 8 to 2 to match GNU/Linux. This has no impact on performance on the BSPs tested. | |||||
* | 2007-11-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-27 | 1 | -1/+2 | |
| | | | | | * libnetworking/netinet/in_cksum.c: ARM optimized version does not support Thumb. | |||||
* | 2007-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-07-30 | 1 | -1/+1 | |
| | | | | | * libnetworking/netinet/in_cksum_m68k.h: Use __mcoldfire__ to identify coldfire cpus. | |||||
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 2 | -2/+2 | |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 17 | -17/+17 | |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 2 | -2/+2 | |
* | Include <rtems/endian.h> instead of <machine/endian.h>. | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 | |
* | Further _IP_VHL removal preps. | Ralf Corsepius | 2007-03-29 | 3 | -2/+32 | |
* | 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-29 | 1 | -1/+3 | |
| | | | | * libnetworking/netinet/ip.h: Add FreeBSD's alignement macros. | |||||
* | Preps to eliminate _IP_VHL (Abandoned in FreeBSD). Misc mergers from ↵ | Ralf Corsepius | 2007-03-29 | 2 | -22/+65 | |
| | | | | upstream FreeBSD. | |||||
* | Preps to eliminate _IP_VHL (Abandoned in FreeBSD). | Ralf Corsepius | 2007-03-29 | 1 | -1/+30 | |
* | Preps to eliminate _IP_VHL (Abandoned in FreeBSD). | Ralf Corsepius | 2007-03-29 | 2 | -2/+14 | |
* | Partial update from FreeBSD. | Ralf Corsepius | 2007-03-29 | 1 | -23/+22 | |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-29 | 1 | -15/+15 | |
* | Use uint32_t optlen. | Ralf Corsepius | 2007-03-28 | 1 | -2/+2 | |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 5 | -16/+16 | |
* | Reflect changes to sys/protosw.h. | Ralf Corsepius | 2007-03-28 | 1 | -4/+4 | |
* | 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-28 | 1 | -10/+11 | |
| | | | | | * libnetworking/netinet/ip_input.c: Eliminate __P(). Change "int next" to "int32_t next" for 16bit targets. | |||||
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 2 | -7/+7 | |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 2 | -6/+6 | |
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -17/+17 | |
| | | | | * libnetworking/netinet/ip_mroute.c: Eliminate __P(). | |||||
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -10/+19 | |
| | | | | * libnetworking/netinet/ip_mroute.h: Partial update from FreeBSD. | |||||
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-26 | 1 | -5/+5 | |
| | | | | * libnetworking/netinet/if_ether.h: Eliminate __P(). | |||||
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-26 | 1 | -14/+14 | |
| | | | | * libnetworking/netinet/ip_var.h: Eliminate __P(). | |||||
* | Fix typo in previous patch. | Ralf Corsepius | 2007-03-26 | 1 | -1/+1 | |
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-26 | 1 | -4/+4 | |
| | | | | * libnetworking/netinet/in.h: Eliminate __P(). | |||||
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-26 | 1 | -6/+6 | |
| | | | | * libnetworking/netinet/tcp_var.h: Eliminate __P(). | |||||
* | 2007-03-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-25 | 1 | -7/+11 | |
| | | | | | * libnetworking/netinet/udp_var.h: Cosmetics from FreeBSD. Remove __P(); | |||||
* | More partial updates from FreeBSD. | Ralf Corsepius | 2007-03-25 | 1 | -4/+12 | |
* | Remove __P(). | Ralf Corsepius | 2007-03-25 | 2 | -6/+6 | |
* | Partial updates from FreeBSD. | Ralf Corsepius | 2007-03-25 | 1 | -41/+29 | |
* | 2007-03-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-25 | 1 | -3/+3 | |
| | | | | * libnetworking/netinet/if_ether.c: Remove __P(). | |||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2006-12-08 | 1 | -19/+13 | |
* | 2006-09-11 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-09-11 | 1 | -2/+2 | |
| | | | | | * libnetworking/netinet/in_cksum.c: Joel should have used int32_t not uint32_t when removing warnings. | |||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 3 | -3/+3 | |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-31 | 1 | -4/+4 | |
| | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. | |||||
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 4 | -18/+21 | |
| | | | | | | | | | | | | | | * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement. | |||||
* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 1 | -0/+2 | |
* | Update icps_allecho counter. | Eric Norum | 2006-05-31 | 1 | -4/+7 | |
* | Add flag to inhibit ICMP replies. | Eric Norum | 2006-05-30 | 2 | -3/+9 | |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-09-16 | 1 | -14/+12 | |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-27 | 2 | -14/+8 | |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 1 | -1/+1 | |
| | | | | * librpc/include/rpc/clnt.h: Partial update from FreeBSD. | |||||
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-24 | 1 | -10/+7 | |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-24 | 1 | -9/+14 | |
| | | | | | Add __packed. Partial update from FreeBSD. | |||||
* | Add "ICMP panic avoided" diagnostic counter. | Eric Norum | 2005-05-24 | 1 | -1/+5 | |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-21 | 1 | -7/+4 | |
* | 2005-05-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-21 | 1 | -31/+45 | |
| | | | | | * libnetworking/netinet/ip_icmp.h: Update from FreeBSD. Abandon BYTE_PACK. | |||||
* | 2005-05-20 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2005-05-20 | 1 | -3/+4 | |
| | | | | | | PR 793/networking * libnetworking/netinet/ip_icmp.c: Malicious ICMP packet causes panic. Just ignore it. | |||||
* | 2005-05-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-14 | 2 | -50/+28 | |
| | | | | | * libnetworking/netinet/tcp_usrreq.c: Cosmetics from FreeBSD. * libnetworking/netinet/tcp_subr.c: Partical update from FreeBSD. |
