These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* libnetworking/netinet/ip_icmp.c, libnetworking/netinet/ip_icmp.h:
Misc. changes from FreeBSD.
* libnetworking/netinet/tcp_var.h: Include <netinet/tcp_timer.h>.
* libnetworking/netinet/in_systm.h,
libnetworking/netinet/tcp_debug.c,
libnetworking/netinet/tcp_debug.h, libnetworking/netinet/tcp_seq.h,
libnetworking/netinet/tcp_var.h, libnetworking/netinet/tcpip.h:
Misc changes from FreeBSD.
* libnetworking/netinet/tcp_var.h: Eliminate __P().
* libnetworking/netinet/tcp_var.h: Partial update from FreeBSD.
* libnetworking/netinet/tcp_input.c: Reflect changes to tcp_var.h.
* cpu_asm.S: Collected PR 601 changes for commit to cvshead
for rtems-4.7
* Makefile.am: Added sys/linker_set.h
* kern/Makefile.am: Added kern_mib.c and kern_sysctl.c.
* kern/uipc_socket.c: OID changed from KERN_SOMAXCONN to KIPC_SOMAXCONN.
* kern/uipc_socket2.c: OID changed from KERN_MAXSOCKBUF to
KIPC_MAXSOCKBUF.
* net/if_ethersubr.c: FreeBSD 2.2.2 does not have a _net_link node
while 5.0 does.
* net/if_ppp.c: Removed the TEXT_SET define as these macros are
now implemented.
* net/rtsock.c: Enable sysctl support plus fix the bug with the
lastest FreeBSD sysctl header file.
* netinet/icmp_var.h: FreeBSD 2.2.2 does not have a _net_inet_icmp
node while 5.0 does.
* netinet/if_ether.c: FreeBSD 2.2.2 does not have a _net_link_ether
* netinet/igmp_var.h: FreeBSD 2.2.2 does not have a _net_inet_igmp
* netinet/in_pcb.c: Fixed the arguments to the sysctl call. Add
inp_gencnt and ipi_count. These are used when listing connections.
* netinet/in_pcb.h: Added counters to aid the listing of connections.
* netinet/in_var.h: Provide the _net_inet_ip and _net_inet_raw nodes.
* netinet/ip_fw.c: Disable the firewall sysctl calls.
* netinet/tcp_subr.c: Merge tcp_pcblist from the lastest FreeBSD source.
* netinet/tcp_var.h: Add structures needed by net-snmp to list
connections.
* netinet/udp_usrreq.c: Merged udp_pcblist from the lastest FreeBSD
source.
* netinet/udp_var.h: Added the sysctl id UDPCTL_PCBLIST. Used by
net-snmp.
* rtems_glue.c: Call sysctl_register_all when initialising the
network stack to register all the sysctl calls. These are in the
special sections and required an updated linker script.
* rtems/rtems_syscall.c: Add the sysctl call.
* sys/kernel.h: Use the lastest FreeBSD method of handling sysctl
structures. This now held in the sys/linker_set.h file.
* sys/queue.h: This is from the lastest FreeBSD code with the circular
code merged back in as it is not used in the lastest FreeBSD kernel.
* sys/sysctl.h: The lastest sysctl. This was needed to use with the new
linker set method. The FreeBSD 2.2.2 version has asm hacks. The lastest
version of the FreeBSD does not have these hacks. It uses gcc attribute
directives.
* netinet/tcp_var.h: Corrected typo in ARM alignment patch which
broke all other ports.
* netinet/in_cksum.c, netinet/ip_icmp.h, netinet/ip_input.c,
netinet/tcp_input.c, netinet/tcp_subr.c, netinet/tcp_var.h,
sys/queue.h: Address alignment requirements for the ARM.
