2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-03-02 | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 1 | -1/+1 | |
2010-03-28 | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 1 | -0/+4 | |
2008-12-22 | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 1 | -1/+1 | |
2008-09-01 | Stop using old-style function definitions. | Ralf Corsepius | 1 | -20/+9 | |
2008-02-05 | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+13 | |
* libnetworking/kern/uipc_socket2.c, libnetworking/netinet/tcp_usrreq.c, libnetworking/netinet/udp_usrreq.c, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c: Add configuration parameters for network stack efficiency multiplier and default socket buffer sizes. Change default multiplier from 8 to 2 to match GNU/Linux. This has no impact on performance on the BSPs tested. | |||||
2007-05-10 | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 1 | -1/+1 | |
2007-03-28 | Reflect changes to sys/protosw.h. | Ralf Corsepius | 1 | -4/+4 | |
2007-03-28 | Eliminate __P(). | Ralf Corsepius | 1 | -2/+2 | |
2005-05-14 | 2005-05-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -6/+6 | |
* libnetworking/netinet/tcp_usrreq.c: Cosmetics from FreeBSD. * libnetworking/netinet/tcp_subr.c: Partical update from FreeBSD. | |||||
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 1 | -1/+0 | |
1998-08-19 | Base files | Joel Sherrill | 1 | -0/+840 | |
