* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 1 | -1/+1 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 1 | -1/+1 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -20/+9 |
* | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-02-05 | 1 | -0/+13 |
| | | | | | | | | | | | * libnetworking/kern/uipc_socket2.c, libnetworking/netinet/tcp_usrreq.c, libnetworking/netinet/udp_usrreq.c, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c: Add configuration parameters for network stack efficiency multiplier and default socket buffer sizes. Change default multiplier from 8 to 2 to match GNU/Linux. This has no impact on performance on the BSPs tested. | ||||
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Reflect changes to sys/protosw.h. | Ralf Corsepius | 2007-03-28 | 1 | -4/+4 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 1 | -2/+2 |
* | 2005-05-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-14 | 1 | -6/+6 |
| | | | | | * libnetworking/netinet/tcp_usrreq.c: Cosmetics from FreeBSD. * libnetworking/netinet/tcp_subr.c: Partical update from FreeBSD. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+840 |
