* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2011-02-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-24 | 1 | -4/+4 |
| | | | | | | | | * libnetworking/netinet/in_systm.h, libnetworking/netinet/tcp_debug.c, libnetworking/netinet/tcp_debug.h, libnetworking/netinet/tcp_seq.h, libnetworking/netinet/tcp_var.h, libnetworking/netinet/tcpip.h: Misc changes from FreeBSD. | ||||
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 1 | -3/+3 |
| | | | | | | | | | | | | | | * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement. | ||||
* | Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance. | Ralf Corsepius | 2004-04-20 | 1 | -2/+2 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+102 |
