path: root/cpukit/libnetworking/netinet/tcp_seq.h (follow)
* 2011-02-24 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-241-4/+4
| | | | | | | | * libnetworking/netinet/in_systm.h, libnetworking/netinet/tcp_debug.c, libnetworking/netinet/tcp_debug.h, libnetworking/netinet/tcp_seq.h, libnetworking/netinet/tcp_var.h, libnetworking/netinet/tcpip.h: Misc changes from FreeBSD.
* 2006-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-08-301-3/+3
| | | | | | | | | | | | | | * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement.
* Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance.Ralf Corsepius2004-04-201-2/+2
* Base filesJoel Sherrill1998-08-191-0/+102
