* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 1 | -1/+1 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 1 | -1/+1 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -4/+4 |
* | Remove BSD "Add clause" (From FreeBSD). | Ralf Corsepius | 2008-09-01 | 1 | -4/+0 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+755 |
