2011-03-24 | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 1 | -1/+1 | |
2007-05-10 | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 1 | -1/+1 | |
2006-08-30 | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -13/+16 | |
* libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement. | |||||
2005-05-12 | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -20/+31 | |
* libnetworking/netinet/tcp.h: Partial update from FreeBSD. Remove BYTE_PACK. | |||||
2005-05-12 | Define BYTE_PACK. | Ralf Corsepius | 1 | -0/+4 | |
2002-07-17 | 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 1 | -7/+7 | |
* netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h: Modified to added packed attribute.o | |||||
1998-08-19 | Base files | Joel Sherrill | 1 | -0/+122 | |
